Hello, Covers! Long time listener, first time caller.
First of all, many thanks for the help you guys have (unknowingly) given me over the years. You have been a light in the darkness. I was thrown unprepared into the ISO realm, and I leaned on this forum frequently to survive.
My situation: I am helping my old company transition to the 9001: 2015 version. They do light assembly, kitting, rework, etc., nothing too technical. They have over 100 customers and only 2 of them mandate an ISO certification. Management has decided they want to limit the scope of the QMS to just the areas that involve those 2 customers, and call the rest of the operation “ISO Compliant”. I have found a registrar who will do this.
I don’t want to start a discussion as to the validity of this approach. FWIW, I see this as a bastardization of the ISO intentions, and, in a way, this is “cheating”. I imagine most of you do too. However, this company has no chance of passing an audit of the entire operation, and limiting the scope is their only hope. I’m just trying to do the job they are paying me to do.
I now have 2 sets of documents: one is the exiting set, that will be kept for the “Compliant” areas, and one for the 2 auditable areas. Some documents will be exactly the same for both areas, while some will have slight tweaks, and some are completely new.
I have gotten myself confused on documentation.
1. I am thinking of renaming the auditable set of docs, with the prefix LS (Limited Scope), to set them apart. They would each have their own table of contents on the company intranet. Should I rename the docs that are the same in both systems?
2. Revison history. For instance, the Quality Manual has a revison level of M. If I rename it LS – Quality Manual, and call it an Original Issue, should I wipe out the revison history, even though that doc has been changed several times over the years? How would I handle new revisons if I keep the same history for both?
3. Are there other issues am I not seeing? Am I overthinking the whole thing?
Thanks in advance, and sorry for the length of this post. As I said, I have been left alone in this task, and sometimes my logic gets circular with no one to bounce things off of.
