Control of Electronic Forms and Documents Embedded in Software
Hello all,
I need to know how others handle forms etc. that are embedded in software.
Our shop control software generates stock pick lists, and shop travelers, plus loads of reports. None of these "documents" will have the usual control signatures.
I am sure there is some simple verbage I can put in my Doc control procedure for this but it seems to be eluding me.
Any Ideas?
James:frust:
Marc
They will be referenced within your documentation where you explain what document types exist and what they are. This is rarely a significant issue in a company your size. I will bet you will find that your MRP (or MRP like) software will have control features necessary for what they are used for.
There is a concept here I will bring out. Controlled documents do not all need signatures for approval and such. Most do not need approval signatures per se. There are other methods. Don't take the signatures thing too far. Make sure there is a very good reason before you have people signing things.
Thoughts from others?
SteelMaiden
I take your same approach Marc. Forms are controlled here when they are created on a computer and filled out by hand. Approval is documented when someone sends me a revised file to place in the system I save their e-mail in a special folder called e-approval making sure that the document name is the subject (we use an intranet system, forms are saved by me in .pdf so if someone needs a clean one at 3a.m., all they need to do is hit the link to open it, then hit print)
As far as forms in software....let's use the example of corrective actions being done using some software package. I do not use form numbers, approvals, or anything else. The quality manual states that the controlled records reside in the computer system and all paper copies are used only for reference and are not controlled. It is obvious in this case that if you are using software that resides on a server, all employees will be using the same version, the computer system is secure and has the appropriate security, and records are backed up per the policy/procedures documented within the quality system. Also, if the "record" is filled out within the computer, anything you print becomes a report, not a form.
There are a lot of ways to approach the requirements, be inventive and try to find the least labor intensive method that makes sense to your organization.
m-rome1
I would agree to the posts above.
When QS9000 started all of our forms had signatures. It became very time consuming if there was ever a change in a document. Now our whole system is NT based with no signatures. The computer has the original controlled document, while any hardcopy can be treated as an uncontrolled or reference document. Document permissions are setup within the computer to make sure only the authorised people can make changes to the document.
I believe that most companies are doing it this way now. One possible suggestion if you are not comfortable with not having any reference details on the forms is to export the form to Word or Excel (or else print the form) and manually give it a form number. Treat this form as the controlled document and the computer system form that is used as the reference document. However I would tend to agree with the comments from the last post. :bigwave:
Marc
Originally posted by SteelMaiden
.....if the "record" is filled out within the computer, anything you print becomes a report, not a form.
This is an important concept for everyone to understand. And the 'record' is in the database, though many companies do printouts and identify them as quality (or other) records. :thedeal:
Michel Saad
Change control?
Interesting subject.
We are in the process of transfering a lot of forms to electronic. I understand and agree with the previous post when it comes to the use of the form, what I am questionning is how do you manage the changes to the forms if no one approves them? Couldn't you wind up with a lot of garbage on a form if its anybody's wish list that changes it?
Intersersted on how others do it.
Marc
You need my Implementation files... (Unabashed plug :rolleyes: ). Review and approval can be evidenced by the fact that the file resides where it is. If it's in the 'publish' directory (or whatever you want to call it), directory permissions allow you to restrict who can put a file there. Ergo, if a file is there the person who reviewed and approved it did so (if your system describes your system in this way). Many companies have departmental protected directories, maybe a 'quality' directory, etc. This is shown in the example document control flow chart in the one of the Implementation files.
If your document control procedure tells how this is done you don't need signatures and such. Since it's electronic, any update precludes someone using the wrong version (with the notable exception in situations where printouts are part of the system).
See http://Elsmar.com/Imp/ for some thoughts. :thedeal:
Michel Saad
Good try Marc.
You are still talking about the mecanics of changing the form on the system and access control. My question pertains more to the management of the content of the form. If I am the only person authorised to change the CAR form, should I be allowed to get rid of 3 steps (from an 8D) without anyone else approving the change? Of course not ! Then if no one approves the form itself, how do you show that changes were warranted? Through a document change control form (or ECN system) maybe? Thats what seems to be proposed in your chart.
I am simply looking for best praticises.
SteelMaiden
The person who has access to change any forms should be someone that the company trusts to do the right thing. i.e. I am the only approver necessary for publishing new or revised forms. Anybody in the facility can ask for changes, after I check with the area supervisor or manager to see if it is OK, I approve it and publish.
As long as you state WHO, it doesn't matter if it is the janitor, as long as they meet the expectations and don't do stupid things, what does it matter? I myself am not about to jeapordize my job by sabotaging forms. I guess I just can't imagine working in an environment where you can't find a one or two folks that can't be trusted to do their job without fearing they'll change things on a whim or deliberately mess up? Am I missing your point, I have a feeling I must be?:confused:
Michel Saad
Thanks for the response.
No it is not for deliberately messing up a form. It is more the lack of understanding all the effects that the change might cause. We have a lot of systems and a lot of people. For some things it is straight foward. I use the form, I change it. There are some forms that affect the entire organization (part creation in the production sofware, ECN form, etc...). It is not easy for a single person to know the impacts on everyone else.
I guess that some need no approval and others need a change control form.
Regards,
T ISO 9001:2008 Forms Control for Electronic Built-In Template Document Control Systems, Procedures, Forms and Templates 2
E Control of Electronic Traveler and SPC Forms Document Control Systems, Procedures, Forms and Templates 1
C Control, Identification and Content of Corporate Electronic Forms Document Control Systems, Procedures, Forms and Templates 7
A Electronic Forms control - Making sure the most current version of a form was used Document Control Systems, Procedures, Forms and Templates 13
C Document Control of Electronic Forms Document Control Systems, Procedures, Forms and Templates 6
D Control of Computer Generated (Electronic) Forms - TS 16949 Control Requirements Document Control Systems, Procedures, Forms and Templates 9
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
A How a test flow can be build for a car electronic sunroof control Reliability Analysis - Predictions, Testing and Standards 6
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
M Control of email (and other electronic media) as Records - 4.2.4 Records and Data - Quality, Legal and Other Evidence 10
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
T Electronic Document Control - Posting a process at work station ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
D 21 CFR 11 Tools Validation - Electronic Document and Records Control Qualification and Validation (including 21 CFR Part 11) 5
R A simple electronic (software) document control question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Electronic Record Control (Specifically editable records not fixed documents!) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Computerised (Electronic) Document Control Insights Customer Complaints 1
JoCam Moisture Control - Receiving Moisture Sensitive Electronic Components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Process Mapping Electronic Document Control Software Recommendations Quality Tools, Improvement and Analysis 5
D Converting to Electronic Document Control - Procedure Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D Electronic Document Control System suitable for TS 16949 Requirements Document Control Systems, Procedures, Forms and Templates 2
V Electronic Document Control Software suggestions wanted Document Control Systems, Procedures, Forms and Templates 14
C Electronic Document Control in a Company - Organization of Files Document Control Systems, Procedures, Forms and Templates 16
R Electronic Templates for making Paper Control Charts Document Control Systems, Procedures, Forms and Templates 9
V Electronic Document Control Sharepoint Questions Document Control Systems, Procedures, Forms and Templates 2
S Best way to control blueprints? Electronic or paper? Document Control Systems, Procedures, Forms and Templates 1
A Control of Document - Manual and Electronic Document Control Systems, Procedures, Forms and Templates 5
S Electronic Document Printing Restrictions and Access Control Document Control Systems, Procedures, Forms and Templates 4
F Looking for Electronic Document Control Software Quality Assurance and Compliance Software Tools and Solutions 14
M What is the best Electronic Document Control Management System? Document Control Systems, Procedures, Forms and Templates 46
R Procedure for Control of Data, Documented & Electronic needed Document Control Systems, Procedures, Forms and Templates 3
C Electronic work instructions - recommendations for electronic data control software. Document Control Systems, Procedures, Forms and Templates 3
M How to Control Electronic Records Records and Data - Quality, Legal and Other Evidence 5
R Control plans for attribute hydraulic/electronic test equipment FMEA and Control Plans 1
a_bardi Help me define way of control electronic data files - Logs, etc Records and Data - Quality, Legal and Other Evidence 3
D Document Control - How can I switch to electronic signatures? Document Control Systems, Procedures, Forms and Templates 12
I Electronic Document Control - How do we handle document signoffs? Document Control Systems, Procedures, Forms and Templates 8
N Anybody with experience with Sharepoint portal for electronic document control? Document Control Systems, Procedures, Forms and Templates 53
A What Electronic Document Control Software are you using? 'Canned' or In-House? Document Control Systems, Procedures, Forms and Templates 10
A The cost of document control - Electronic vs. Paper Document Control Systems, Procedures, Forms and Templates 20
A Electronic Control Design Company - Can We Register to TS 16949? Design and Development of Products and Processes 11
Geoff Cotton TS 16949 - Control of Electronic Data Document Control Systems, Procedures, Forms and Templates 3
J Electronic Document and Records Control Software Records and Data - Quality, Legal and Other Evidence 28
A Document Control: Controlling Electronic Email (E-mail) Document Control Systems, Procedures, Forms and Templates 7
P Control Plans - Intending to transfer our control plans to electronic format Document Control Systems, Procedures, Forms and Templates 7
B Electronic Doc Control Software Packages Document Control Systems, Procedures, Forms and Templates 3
A Document and Data Control - We are not satisfied with electronic document security Other ISO and International Standards and European Regulations 3
V Control of electronic media documents Document Control Systems, Procedures, Forms and Templates 5
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
