Control of Electronic Traveler and SPC Forms
E
eturkan
In cases where the traveler and SPC forms are kept in an access based software;
-How document revisions should be maintained ?
-Does the software require a validation per TS 16949 or big OEM CSR?
-If we add a introduce a new part to the traveler (it is basically a lookup function based on the P/N) do we need to bump up the rev?
qusys
There could be multiple solutions. I would like to suggest some of them just to share ideas, not knowing your systems and documented procedures for this scope.
1. Document revision could be maintained by mean of an engineering change request number associated for each change. It is a matter of change mgmt process and your organization could also set the responsibility for approvals and notification.
2. You could simulate the functionality of the software checking at random the macro included in the program , using another sheet and verifying if the result is the expected one. This could fall in 7.6 but I do not know if it also encompasses the case your are referring to. We need additional details to establish
3. It could be linked to the process of new product introduction. It depends on the procedure you have and how you believe it functional to your process and customer requirements. Probably you should estimate what you mean "revision". Is it related to the functionality of the program or to the content and information of the traveller?
In my opinion , it is still question of change mgmt and you could proceed with new revision ( clause 7.1.4 of ISO TS).
Hope this helps , waiting for new considerations of more expert Covers.:bigwave:
M Design Control - Management of Electronic CAD files Design and Development of Products and Processes 11
U Electronic templates for making paper control charts Reliability Analysis - Predictions, Testing and Standards 2
A How a test flow can be build for a car electronic sunroof control Reliability Analysis - Predictions, Testing and Standards 6
Q Real Time Electronic SPC/Control Charting Statistical Analysis Tools, Techniques and SPC 4
M Control of email (and other electronic media) as Records - 4.2.4 Records and Data - Quality, Legal and Other Evidence 10
D How to approach Paper and Electronic Record Control for ISO 9001:2008 Records and Data - Quality, Legal and Other Evidence 7
T Electronic Document Control - Posting a process at work station ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
T ISO 9001:2008 Forms Control for Electronic Built-In Template Document Control Systems, Procedures, Forms and Templates 2
D 21 CFR 11 Tools Validation - Electronic Document and Records Control Qualification and Validation (including 21 CFR Part 11) 5
R A simple electronic (software) document control question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
P Electronic Record Control (Specifically editable records not fixed documents!) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Computerised (Electronic) Document Control Insights Customer Complaints 1
JoCam Moisture Control - Receiving Moisture Sensitive Electronic Components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
C Process Mapping Electronic Document Control Software Recommendations Quality Tools, Improvement and Analysis 5
D Converting to Electronic Document Control - Procedure Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D Electronic Document Control System suitable for TS 16949 Requirements Document Control Systems, Procedures, Forms and Templates 2
V Electronic Document Control Software suggestions wanted Document Control Systems, Procedures, Forms and Templates 14
C Electronic Document Control in a Company - Organization of Files Document Control Systems, Procedures, Forms and Templates 16
R Electronic Templates for making Paper Control Charts Document Control Systems, Procedures, Forms and Templates 9
V Electronic Document Control Sharepoint Questions Document Control Systems, Procedures, Forms and Templates 2
S Best way to control blueprints? Electronic or paper? Document Control Systems, Procedures, Forms and Templates 1
A Control of Document - Manual and Electronic Document Control Systems, Procedures, Forms and Templates 5
S Electronic Document Printing Restrictions and Access Control Document Control Systems, Procedures, Forms and Templates 4
F Looking for Electronic Document Control Software Quality Assurance and Compliance Software Tools and Solutions 14
M What is the best Electronic Document Control Management System? Document Control Systems, Procedures, Forms and Templates 46
R Procedure for Control of Data, Documented & Electronic needed Document Control Systems, Procedures, Forms and Templates 3
C Control, Identification and Content of Corporate Electronic Forms Document Control Systems, Procedures, Forms and Templates 7
C Electronic work instructions - recommendations for electronic data control software. Document Control Systems, Procedures, Forms and Templates 3
M How to Control Electronic Records Records and Data - Quality, Legal and Other Evidence 5
A Electronic Forms control - Making sure the most current version of a form was used Document Control Systems, Procedures, Forms and Templates 13
R Control plans for attribute hydraulic/electronic test equipment FMEA and Control Plans 1
C Document Control of Electronic Forms Document Control Systems, Procedures, Forms and Templates 6
a_bardi Help me define way of control electronic data files - Logs, etc Records and Data - Quality, Legal and Other Evidence 3
D Document Control - How can I switch to electronic signatures? Document Control Systems, Procedures, Forms and Templates 12
I Electronic Document Control - How do we handle document signoffs? Document Control Systems, Procedures, Forms and Templates 8
D Control of Computer Generated (Electronic) Forms - TS 16949 Control Requirements Document Control Systems, Procedures, Forms and Templates 9
N Anybody with experience with Sharepoint portal for electronic document control? Document Control Systems, Procedures, Forms and Templates 53
A What Electronic Document Control Software are you using? 'Canned' or In-House? Document Control Systems, Procedures, Forms and Templates 10
A The cost of document control - Electronic vs. Paper Document Control Systems, Procedures, Forms and Templates 20
A Electronic Control Design Company - Can We Register to TS 16949? Design and Development of Products and Processes 11
Geoff Cotton TS 16949 - Control of Electronic Data Document Control Systems, Procedures, Forms and Templates 3
J Control of Electronic Forms and Documents Embedded in Software Document Control Systems, Procedures, Forms and Templates 12
J Electronic Document and Records Control Software Records and Data - Quality, Legal and Other Evidence 28
A Document Control: Controlling Electronic Email (E-mail) Document Control Systems, Procedures, Forms and Templates 7
P Control Plans - Intending to transfer our control plans to electronic format Document Control Systems, Procedures, Forms and Templates 7
B Electronic Doc Control Software Packages Document Control Systems, Procedures, Forms and Templates 3
A Document and Data Control - We are not satisfied with electronic document security Other ISO and International Standards and European Regulations 3
V Control of electronic media documents Document Control Systems, Procedures, Forms and Templates 5
D Use Error Risk Controls and Control Verification ISO 14971 - Medical Device Risk Management 5
S Maintenence related action in Control plan FMEA and Control Plans 3
