Control of equipment instruction manuals
John Mann
At present, our control of instruction manuals is bad to non-existant. Many are out of date and this needs to be addressed. I see two possibilities:
(1) Treat them exactly the same as controlled company documents.
(2) Treat them as products in their own right and control them that way.
In both cases a mechanism would be needed to ensure the manual gets updated with the product to which it refers.
A third suggestion has come from the software developers who say that manuals could be controlled under the software versioning system they use, however management don't like this suggestion.
I would be interested to hear how others approach this.
Thanks,
John.
qusys
Thanks,
John.
I think that approach number 1 is good. Remember that it is up to the organization to define how to control the documents of "external origin" and states it in the document control procedure as per 4.2.3 of ISO 9001.
They can be considered as " controlled document" at all effects.
John Mann
I should have explained that these are the instruction manuals we produce relating to the products we make, so they are not external origin.
qusys
Yes, I was wrong in the interpretation. I had understood.
However I think that you should put in place activities to meet clause 7.2.3 of ISO 9001. They can fall under communication with customer.
Jen Kirley
Quality and Auditing Expert
My experience with equipment manuals is that they usually don't change once they are published for a given piece of equipment. Therefore, some of the controls in the various standards' document control elements may seem overmuch. Maybe that is why the requirement for them tends to be more specific, as in know what you have and make a plan to control the distribution. My guess is that is for readiness more than anything else; the manuals need to be where people require them to be in order to use them for their work, to the extent they do so.
steve hussain
They should be treated as your other documents; that is changed when required with the necessary records to prove when such changes occured. these updated versions must be in use with the old one removed completely (normal system used for clause 4.2.3). It is good if you have a list of all documents (including the equipment instruction manuals) to display your current documents.
i hope is helps.:cool:
qusys
Hi to all.
Probably there was a misunderstanding. The original poster refers to the instruction manuals that the organization prepares together their software products, not the manual for equipment.
steve hussain
My interpretations of what you have are written instructions develop my the company for a particular equipment making a specific product. What you need to do is first have identification codes for each one of them (say this under clause 4.2.3) and list them under a master list of control documents. Whenever they are changes necessary, go through a document change procedure and update the revision number and date ensuring all outdated ones are removed. These work instructions should be at the station where they are used (you need to state the storage areas).
I do hope this helps;)
somashekar
Your equipment instructions manual is not a document under any document control. It is a part of your Bill Of Material (BOM)
It will have a revision level and will be in control as long as your BOM is in control.
The revision level of this manual as appearing in your BOM must also appear somewhere on the manual, printed in small font at the right bottom of your page 1 or page last or anywhere else for identification (your convenience)
Wes Bucey
Prophet of Profit
To recap:
OP's company
  1. creates software for others
  2. creates operating/instruction manuals to accompany software
  3. has question related to updating manual as either software version changes or additional info related to original version becomes available form ANY source (in-house, customer, third party critic.)
When I was part of an aerospace company, we were required to include detailed manuals with each installation of equipment. If some new information became available on an existing installation, we were required to either issue a supplement detailing that info or to withdraw the original manual and replace with new.
Sometimes, because of the configuration of an aircraft, each individual installation could be completely unique despite the underlying equipment being the same. In those cases, a unique manual was compiled for the unique installation.
In simple terms, this ALL comes under Configuration Management - the basis of which is to avoid confusion between documents and the versions to which they pertain. It would be kind of silly, for example, if a trucking company changed its entire fleet from "stick" [standard] shift transmissions to automatic transmissions, but did not update the operating manuals to reflect the change. It would be even sillier if the manufacturer of those trucks did not supply manuals for automatic transmissions, but kept on supplying manuals for standard transmissions with vehicles equipped with automatic.
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D Infrastructure: Equipment, Work Environment and Contamination Control ISO 13485:2016 - Medical Device Quality Management Systems 4
E ISO 13485 7.6 Control of monitoring and measuring equipment - Assess the Validity ISO 13485:2016 - Medical Device Quality Management Systems 4
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
P Do we need equipment stock control for security company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
M Can Scope of Equipment Control be Tied to Risk? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
A ISO 9001 Control of Production Equipment - CNC Machines ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Control of R&D (Research and Development) Parts and Equipment ISO 13485:2016 - Medical Device Quality Management Systems 3
A Calibration Interval - AS9100 - Control of Monitoring and Measuring Equipment Calibration Frequency (Interval) 8
D Does 7.6 Control of Monitoring and Measuring Equipment align with ISO 17025 ISO 17025 related Discussions 4
G Control of Monitoring and Measuring Equipment for Servicing Photocopiers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S ISO9001 Exclusion 7.6 Control of Monitoring and Measuring Equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
H Measurement System in Control if the Equipment requires Daily Calibration? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
S Control of the Content in the Master Calibration Equipment form Document Control Systems, Procedures, Forms and Templates 2
M 7.6 Control of Monitoring and Measuring Equipment - Monitoring vs. Measuring IATF 16949 - Automotive Quality Systems Standard 2
G 7.6 Control of Monitoring and Measuring Equipment vs. 7.6.1 Measurement Systems Analy IATF 16949 - Automotive Quality Systems Standard 15
T Control of Production Equipment - Seventh Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Medical Diagnostic Equipment Control Computer Repair Other US Medical Device Regulations 3
D MSA Requirements for Equipment Referenced on Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 7
QMMike Control of Measurement Equipment on your Shop Floor Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
Q MSA Studies on each Equipment, each Measurement System or Family in Control Plan? IATF 16949 - Automotive Quality Systems Standard 35
R Control of Monitoring & Measurement Equipment - ISO 9001:2008, Clause 7.6 c) General Measurement Device and Calibration Topics 9
A Equipment List - Control or not to Control (Controlled Documents) Document Control Systems, Procedures, Forms and Templates 8
C Control of Equipment Manuals - ISO 17025 Clause 4.3.1 ISO 17025 related Discussions 6
N Control of Measuring and test Equipment - Flowchart wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Q Equipment Parameters in Control Plan? IATF 16949 - Automotive Quality Systems Standard 4
D Control of monitoring and measuring equipment - infrared thermometer for cross-check ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
W Computer Software - ISO 9001 Clause 7.6 Control of Monitoring and Measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Difference between control & audit - Cleaning manufacturing equipment Internal Auditing 5
hogheavenfarm Extending control of measuring equipment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
L Control of Production Equipment, Tools and NC Programs: 7.5.1.3 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 12
A Control of Production Equipment,Tools and Numerical Control (N.C.) Machine Programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
M Control of Equipment General Measurement Device and Calibration Topics 1
E Control Charts for OEE (Overall Equipment Efficiency) Statistical Analysis Tools, Techniques and SPC 19
Q Proprietary Information and Control Plans - Equipment, Materials, Specifications FMEA and Control Plans 3
R Control plans for attribute hydraulic/electronic test equipment FMEA and Control Plans 1
M 4.11 Control of Inspection Measurement and Test Equipment Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
R Control Methods in Control Plan FMEA and Control Plans 0
M Design Control - Management of Electronic CAD files Design and Development of Products and Processes 11
S TSCA (Toxic Substances Control Act) PIP 3:1 RoHS, REACH, ELV, IMDS and Restricted Substances 0
S Use of Attributes Control Charts Statistical Analysis Tools, Techniques and SPC 1
U Appraiser Out of Control Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
Z AS9100 Control of Nonconforming Outputs - Rework Dispositions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K ASME, ANSI, ASTM and similar specifications and their requirements for document control. Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
Z Software for design control ISO 13485:2016 - Medical Device Quality Management Systems 3
K Quality Control/Assurance in the Metal Industry Quality Tools, Improvement and Analysis 10
K Defining risk control measures IEC 62304 - Medical Device Software Life Cycle Processes 14
J Warehouse temperature and humidity control EU Medical Device Regulations 7
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
