Control of Manufacturers Calibration Procedures
moiraknows
I am creating a procedure for document control and am wondering if we have to internally issue any manufacturer calibration procedures a unique identificaion number.
Mo
Stijloor
Re: Control of Manufacturers Procedures
I am creating a procedure for document control and am wondering if we have to internally issue any manufacturer calibration procedures a unique identification number.
Mo
Hello Mo,
I assume that you are referring to calibration procedures (hard copy) provided by the measuring and test equipment manufacturer? I've seen it done this way: Put them all in a binder, add a table of contents. Put a label on the binder and call it "Calibration Instructions." Done deal.
Electronic? Scan them in, name them, put them in a folder called: "Calibration Instructions." Because calibration instructions are equipment related, they are typically not subject to change. Keep it simple. Bottom line? Do what works best for you and your employees. You'll be OK.
Hope this helps.
Stijloor.
moiraknows
Hello Mo,
Hope this helps.
Stijloor.
Thanks.
Now for my next question. As I write the manual, is it alright to say, as far as calibration procedures are concerned, something to the effect the manufacturer's procedures will be followed. If no procedures have been supplied by a supplier, and internal procedure will be created.
Thanks again
BradM
Hello, Mo!
I guess I am still trying to figure out what you are doing, here. Are you actually calibrating instruments at your facility according to the mfg. procedures? Or, are you having instruments calibrated at the mfg. facility using their own procedure? Who is actually doing the calibration?
Stijloor offers one good viable option. If you are doing the calibration work and you have a high degree of confidence nothing will ever need to deviate from that procedure, then that method will work (and that may entirely be the case).
However, if (and this is all dependent on how you write your procedures) you list which standards to use, possible have a limited range outside the mfg. range, etc., then you may end of with a revised document. That case, you might want to approach it a little different. You could still do it in a manner similar to how Stijloor suggested.
Too, I've seen a lot of mfg. calibration procedures. Some of them were pretty good; some of them were quite odd. We would perform calibration in a manner more in-line with how we were using the piece of equipment.
K
Kevin H
Another option, depending on the equipment is to just reference a pertinent calibration standard, such as ASTM E18 for hardness testing, or E4 for force verification of testing machines.
moiraknows
Hello, Mo!
At the moment we calibrate pressure equipment.
We are in the process of opening a cal lab for 17025 accred.
I have developed a QA system for neuclear industry but this is my first stab at ISO.
I thank you all for the great advise:thanx:
Benjamin28
Yes the statement is acceptable. The key here is not just to have a documented procedure for calibration, but to have THE procedure YOU utilize documented for every calibration type you are seeking accreditation for.
One thing to keep in mind though, manufacturer calibration procedures are prone to being quite specific to certain item models, design, etc. If you plan on having a long term accreditted laboratory it may be beneficial to have internal procedures which are more flexible to a family of instruments. In this way you maintain less cumbersome procedures while being accreditted to calibrate a wide range of instrument designs.
Hershal
Metrologist-Auditor
A couple of things to remember.....
For procedures of "external origin" (e.g., manufacturer's procedures), per ISO/IEC 17025 Clause 4.3.1, you must have a procedure to control them. That does not require a separate number unless you want to, but the control is what must be described.
For internall developed procedures, they must be validated, per Clauses 5.4.1 through 5.4.5.3 inclusive.
You selected accrediting body which I presume will be SCC/CLAS (given your location) can provide additional guidance in their CAN-P series documents.
Hope this helps.
M FDA News USFDA Draft Guidance – Clarification of Radiation Control Regulations for Manufacturers of Diagnostic X-Ray Equipment Medical Device and FDA Regulations and Standards News 0
Sidney Vianna ISO/TS 22002-1:2009 gives food manufacturers new tool to control hazards Food Safety - ISO 22000, HACCP (21 CFR 120) 0
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
C UDI Questions on Control Units Other US Medical Device Regulations 6
A Quality Control Datasheets Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
M Control-self assessment Internal Auditing 5
GreatNate Master Control QMS software Quality Tools, Improvement and Analysis 0
A Prototype control plan FMEA and Control Plans 2
shimonv Document Control Procedure Header Content Document Control Systems, Procedures, Forms and Templates 3
W FMEA - Current control and occurrence rating FMEA and Control Plans 3
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
N What are the software audit and control steps Reliability Analysis - Predictions, Testing and Standards 2
A Fabric roll inspection - What type of Control Chart to use? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
C Monitoring and Control Instruments RoHS, REACH, ELV, IMDS and Restricted Substances 3
M ISO14971:2019 - Verification of implementation and effectiveness of risk control ISO 14971 - Medical Device Risk Management 3
T Risks arising from control measures vs. ineffective control measures ISO 14971 - Medical Device Risk Management 11
J Need Change Control Yes/No Decision Tree Template ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
P IQ, OQ, PQ protocol, and report templates for Distributed Control Systems in Pharmaceutical Manufacturing Systems. Qualification and Validation (including 21 CFR Part 11) 0
R Risk control measures as per ISO 14971 ISO 14971 - Medical Device Risk Management 6
T Linking Control Plans and PFMEA's FMEA and Control Plans 3
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
C 8.5.1.1 Control of Equipment, Tools, and Software Programs - Questions about the extent of control of NC programs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
Q Version/Revision Control of CAD files Document Control Systems, Procedures, Forms and Templates 2
Sravan Manchikanti How to interpret '8.3 Control of nonconforming product' for SaMD device while implementing ISO 13485 & MDSAP ISO 13485:2016 - Medical Device Quality Management Systems 7
Z Putting back excluded rows/data points in a control chart Using Minitab Software 0
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
W Need for current design or process control FMEA and Control Plans 2
Q ISO 9001 8.5.1 - Control of production and service performance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
A Beginners help with ISO3951-2 Combined control s-method n>5 what is Phi ?? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 0
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
B Control chart and sample time Statistical Analysis Tools, Techniques and SPC 1
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
J Control chart for huge sample size Statistical Analysis Tools, Techniques and SPC 9
K Contamination Control - Class Is medical devices (Clause 6.4.2 ISO 13485:2016 (E)) ISO 13485:2016 - Medical Device Quality Management Systems 12
J 510(k) for a control kit for an external IVD test kit 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Assessing Hazard-Related Use Scenarios where control measures exist through standards IEC 62366 - Medical Device Usability Engineering 32
adir88 Documenting Risk Control Option Analysis ISO 14971 - Medical Device Risk Management 8
