Dear Brothers,
I’m working in services field “Travel & Tourism “and I face resistance form employees to implement control of nonconforming services as per ISO 9001 requirements. They do not like to document any cases of nonconformities What should I do? How can I encourage them to implement it?
You are one of the countless quality professionals faced with this daunting task of trying to convince employees to implement non-conformity control! And I am one of them!
Unfortunately, this is a very common problem in the Middle East, with employees trying to cover up on NC's just because they don't want to be in the picture, or they don't want people's or their own problems to be exposed! This is what their perception is!
With the solution I have tried to implement, whatever little I did achieve was to my pre-calculated satisfaction. Although, the achievement was not ground-breaking; it has helped people begin to accept NCs more willingly!
1. Identify all relevant reasons (which are excuses) for which employees are hesitant to accept / identify / give a nonconformity. By and large, they are the same - They feel shy to expose themselves or others!
2. Strictly use the
process-is-at-fault approach NOT the
process-owner-is-at-fault approach
, unless ofcourse the root-cause boils down to the process owner!
3. Reflect the same in the NC control procedure
4. When internal auditors come to audit you, make sure you are forthcoming for the smallest negative observation with high willingness and taking it as an opportunity to
IMPROVE THE PROCESS and gain more knowledge. Ditto for NC's.
5. Conduct 2 training sessions in a month at a 15-day interval - the same training - 'NC Implementation' - but different training name, different approach; the process NC approach. Examples are of great importance here. Use the same real-life examples of your company ensuring the finger is pointing to the process not the process owner, albeit for the purpose of improvement.
6. However, do not forget that the responsibility for closing the NC's remains with the process owner; offer ready assistance (and assistance only) to close the NC's.
7. Notice the difference over a period of 2-3 months. Ofcourse, you will not get any results earlier than this.
If the above does not work, my solution probably worked for just me.
Boscoeee has presented a very good solution, however, if you don't already have cost of quality/dollar value determined, this is a separate project altogether.
Ciao.
