Control of Obsolete Documents
insect warfare
QA=Question Authority
At a minimum you must have these controls in place for obsolete documents...
1) Dispose of them in such a manner that they cannot be re-used, or
2) If you intend to retain copies for whatever purpose, segregate them from relevant versions of the same document to prevent unintended use by others.
The main point is to keep outdated information from being applied in the workplace. Other than that, you need not do much else other than following your document and record control procedures.
Brian :rolleyes:
Randy Lefferts
Is it necessary to rev a document when obsoleting it?
Short answer is no. Insect warfare already provided you with what you must do when obsoleting but assigning a new rev level to a document when obsoleting it is not necessary, required or even realistic. It already has a rev level, that is now obsolete.
If you were to feel the need to stamp "obsolete" across the face of the document I suppose that some very anal auditor may claim that is a revision to the document and would need to be shown with new revision identification. That would be one very sick auditor.
In other words, forgetaboutit.
Jen Kirley
Quality and Auditing Expert
It depends on your system. Is it a system of paper documents? If so, a stamp and segregation might work.
If it's in an electronic system that stores documents with the most recent revision available, they might be moved but it might be safer and easier to identify their revision as "OBS" or the like, because the standards ask us to make the documents' status available/identifiable to the user.
Should it go through the review process when obsoleting? Again, that depends on your system. Do your documents have related documents that would need updating? Do certain people need to be informed that a document is being obsoleted? If so, putting them on a review and approval loop might get the job done.
Remember the method to achieve this required identification is more about what your organization would benefit from, and less about what would satisfy an auditor.
wooden nickle
I believe ISO 13485 is telling us differently in clause 4.2.3 Control of Documents;
"The organization shall ensure that changes to documents are reviewed and approved either by the original approving function or another designated function which has access to pertinent background information upon which to base its decisions".
I believe that to obsolete a document without the originators approval is contrary to the standard. Obsoleting a document is definitely changing it, there may be ramifications the Quality System Coordinator is not aware of. All original reviewers should be in agreement that the document needs to be obsoleted.
I moved this into the 13485 forum for better exposure. I'm not an expert in this area, but I think you're asking a different question than the original one, which was whether you have to "rev" a document when it becomes obsolete. I take this to mean that you would, in rendering a revision "A" document obsolete, change the revision to "B." That wouldn't make much sense to me, but it does make sense that obsolescence would be a matter of consensus of the responsible parties rather than a unilateral action.
wooden nickle
Thank you Jim, but isn't it true that the only way you can document the approval to obsolete the document of all the signers of the document is through rev control.
G
Geoff Withnell
It is not a requirement, but I have found it very useful, when obsoleting a document, to issue a new revision. A one page document which says Document No. xxxxxxxx "yyy yyy yyy" has been obsoleted as of month day year, without replacement, or is replaced by Document No. zzzzzzzzz. That way, if someone unfamiliar runs across a reference to the document, they get the story.
M Document Control - Applying Suitable Identification to Obsolete Documents ISO 13485:2016 - Medical Device Quality Management Systems 5
T Document Control Master List for Obsolete Documents Document Control Systems, Procedures, Forms and Templates 6
B Reusing paper of Obsolete Documents to Control Waste Document Control Systems, Procedures, Forms and Templates 12
P AS9100 4.2.3 Control Of Documents - Requirement to retain Obsolete Documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J Control of Obsolete Documents - Changing document control software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained? Document Control Systems, Procedures, Forms and Templates 7
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
E Control Charts ISO 17025 related Discussions 6
E Control of Sterile Barriers made by the supplier Design and Development of Products and Processes 4
E Do anyone have document of automotive production risk and control of risk? Lean in Manufacturing and Service Industries 1
M X-MR Control Chart Rules (Particularly the MR) Statistical Analysis Tools, Techniques and SPC 3
I Clinical study suppliers (service providers) -- extent of control ISO 13485:2016 - Medical Device Quality Management Systems 4
P Product Requirements Control during Design Changes Design and Development of Products and Processes 3
T Control Excel template Document Control Systems, Procedures, Forms and Templates 5
J Document Control of Online Management Software ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
R 8.7 Control of Nonconforming Outputs AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
W Document control Document Control Systems, Procedures, Forms and Templates 10
S Control plan - Multiple batches Manufacturing and Related Processes 2
Q Control Plan and the frequency of sampling FMEA and Control Plans 11
A ISO 9001:2015 8.5.6 and 7.5.3 Document Control Questions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
qualprod Sheets into a spreadsheet document control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Rene Minassian Control of (TMME) Testing and Measurement Equipment Oil and Gas Industry Standards and Regulations 2
C Control Plan APQP and PPAP 7
D Control of Records ISO 13485:2016 - Medical Device Quality Management Systems 7
L Control of Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 29
S Control plan for "highly automated processes" FMEA and Control Plans 3
D Document Control Question involving DocuSign US Food and Drug Administration (FDA) 6
R SCORING OF MILLER MARITAL LOCUS OF CONTROL SCALE Coffee Break and Water Cooler Discussions 2
M Document Control ISO and FDA ISO 13485:2016 - Medical Device Quality Management Systems 7
M Design Control Procedure Medical Device and FDA Regulations and Standards News 4
D 8.5.1.2 Validation and control of special processes requirements for Heat Treat External Processor AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R Humane Pest Control Food Safety - ISO 22000, HACCP (21 CFR 120) 1
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
B QM Plan vs Control Plan IATF 16949 - Automotive Quality Systems Standard 3
N AS 13004 Control Plan and AQL FMEA and Control Plans 1
R Does anyone use iQMS for their ISO based document control? Manufacturing and Related Processes 1
qualprod Traceability with no rules to control labels? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
B Doubt about the correct control chart Statistical Analysis Tools, Techniques and SPC 14
G Change Control for Test Samples Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Z Change color or shape of individual data point in control chart Using Minitab Software 6
Z Setting the Control limits on Minitab Using Minitab Software 4
C Elaborating a control chart with skewed data Manufacturing and Related Processes 4
M Who is performing quality control? IATF 16949 - Automotive Quality Systems Standard 2
S Risk control through Information for safety ISO 14971 - Medical Device Risk Management 8
D Locking Control Limits and SPC Sample Sizes (AIAG/Automotive Requirements) Six Sigma 2
Q Control limits Six Sigma 6
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
T Control of Nonconforming Material AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
G Control of Approved Supplier List (ASL) When Employees Make Purchases Supplier Quality Assurance and other Supplier Issues 6
