Control Plan Compliance [PPAP 3.1] & Drop Shipments
Douglas E. Purdy
If a control plan shows a receiving inspection of product from one out-sourced supplier before shipping the product to another out-sourced supplier, what compliance issues are there when purchasing goes and drop ships from the one supplier to the other?
Thanks,
Doug
V
vanputten
How does your organization confirm that the first outsource supplier did their job?
The receiving inspection control point (listed on the control plan) is not a control point when the purchasisng dept. drop shipped from one outsource supplier to the other.
I can't find my copy of the 4th edition of PPAP so I cannot look up section 3.1. I have an external document control problem today.
Regards,
Dirk
Thanks,
Doug
I'm confused. Section 3.1 of the 4th Edition PPAP manual is about customer notification and submission requirements, and I'm not sure how your question relates to it, or to PPAP in general. I don't think that outside operations belong in a control plan, because I believe that control plans should include only those processes which you actually control directly. We should be able to see the routing of material in your process flow diagram, and the possibilities for bad things to happen should be addressed in the PFMEA, but that doesn't mean that you also have to address them in your control plan. For PPAP purposes, you can include a copies of sub-tier documentation (your suppliers' control plans) but you shouldn't do that unless your customer actually wants to see them.
Douglas E. Purdy
Regards,
Dirk
We receive a certificate of conformance from the outsourced suppliers. The case I have in mind for this thread is where we send product out for brazing and then we send the brazed product out for plating.
Thanks,
Doug
Douglas E. Purdy
Sorry for the confusion, I was naturally thinking that I had a compliance issue if I had an inspection point on the control plan and it was not carried out due to the drop shipment.
As for outsourced activity not being on the control plan, I will have to do more investigation into that.
Thanks,
Doug
Thanks,
Doug
Does the material normally come back to you after brazing, and a purchasing cowboy (or girl) decided to have the brazing contact send it to the plater instead? If that's the case, and your PFD and control plan show the non-cowboy process flow, then you're correct--it is a problem. You can solve it by following my earlier advice and not including processes you don't control in your control plan, or you can put a branch on your PFD that allows for either method, and also update the PFMEA and control plan accordingly.
V
vanputten
Jim:
I question the line of thinking that control points outside of the organization don't have to be on control plans. If organizations are still responsible for outsourced process, and the organization shall ensure control over outsourced processes, then I would think that the controls over the outsourced process could or even should go on the control plan.
I hope there is some direct control over the outsourced processes especially if one pays for the outsourced processing or has a contract.
Just wondering on this. I have no reference points to say one approach is better or worse, right or wrong.
Doug: If the control plan states that the control is the receipt of the C of C, then I don't think there is any problem with the drop ship.
Regards,
Dirk
Jim:
Regards,
Dirk
My rationale on the subject: PPAP and related APQP requirements are supposed to be "flowed down" to sub-tier suppliers. This means that they are supposed to develop their own APQP processes, PFMEAs, flow diagrams and control plans. My control plan should be about what I can directly control in my processes. If my customer is interested in sub-tier controls, I can include a copies of their control plans in PPAP submissions. Which would you rather have as a customer--direct evidence, or hearsay?
Douglas E. Purdy
Yea, you got it.
Thanks,
Doug
Douglas E. Purdy
Jim:
Regards,
Dirk
The CoC is the Control Method for the Brazing Operation (Outsourced) but the next step is the receiving verification at our place. It is to be a visual for damage or defective product at a given sampling.
I tend to agree with the outsourced activity being on the control plan, but I would not over-ride Jim's position.
Thanks,
Doug
O Process Flow Diagram, DFMEA, PFMEA, Control Plan integrated softwares FMEA and Control Plans 4
V Over 60 dimensions CMM measurement in control plan APQP and PPAP 4
G FMEA versus control plan IATF 16949 - Automotive Quality Systems Standard 6
K ISO 2859-5 (single run production) control plan issues FMEA and Control Plans 2
S Control plan - Multiple batches Manufacturing and Related Processes 2
Q Control Plan and the frequency of sampling FMEA and Control Plans 11
C Control Plan APQP and PPAP 7
S Control plan for "highly automated processes" FMEA and Control Plans 3
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
B QM Plan vs Control Plan IATF 16949 - Automotive Quality Systems Standard 3
N AS 13004 Control Plan and AQL FMEA and Control Plans 1
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 19
S Linking control chart with control plan Statistical Analysis Tools, Techniques and SPC 5
S Operation of possible rework in control plan FMEA and Control Plans 8
M Process & Product Characteristic in Control Plan FMEA and Control Plans 17
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
A Control plan for IATF - example? FMEA and Control Plans 1
S Maintenence related action in Control plan FMEA and Control Plans 3
R Control Methods in Control Plan FMEA and Control Plans 5
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
A Prototype control plan FMEA and Control Plans 2
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 10
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
D Supplied Product on Control Plan - Lot ranging in 40,000 pcs per product FMEA and Control Plans 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
M Dynamic Control Plan Draft - need review FMEA and Control Plans 2
Ashland78 IATF 16949 Control Plan Authorizations IATF 16949 - Automotive Quality Systems Standard 2
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 6
Rameshwar25 What is a Control Plan at "Material Level"? IATF 16949 - Automotive Quality Systems Standard 4
leftoverture Control Plan - Multiple Process Steps FMEA and Control Plans 8
W Purchased Part Control Plan (IATF 16949) FMEA and Control Plans 7
J VDA audit, control plan - My hair is almost gone now VDA Standards - Germany's Automotive Standards 5
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
Jeff Putman EQI Prelaunch Control Plan - Definition Customer and Company Specific Requirements 0
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
N Control plan references FMEA and Control Plans 6
