Control Plan - Links to Customer Documents (e.g. Print) or the Actual Specifications?
CliffK
#11
Re: Control Plan - Links to Customer Documents (e.g. Print) or the Actual Specificati
If your Operators are gaging/measuring the part by their Machine then yes the Tolerance +/- should be in the Shop order, but if this is not the case and you have a first piece station which is measuring the part , then I would just include in the Control plan " Check to approved First piece" . Hope this helps :)
I don't think this gets you out of the need to specify a tolerance, unless the variation in your parts is below the resolution of your instrumentation so that all parts look identical.
Or maybe you have zero variation?;)
try2makeit
#12
The tolerances are specified in the First piece Inspection sheet and Prints for each part we produce. Once the part has been approved by First piece it is recorded in the Data sheet, the part is tagged and returned to the Operator so they can do their frequency check per the Control plan. The operator matches in-production parts to the first piece, and looks for blown Cavities i.e holes, abnormal cut etc. If anything like the before mentioned occurs, when you match it up to the first piece it is very easily identifiable. Now if there is anything that the Operator has to watch out for during the Production run that might jeopardize the form or fit of the part it is stated clearly under his operation and if you are a good Quality person have it recorded in your Control plan and PFEMA :yes:
The only time ever the Operator has to measure a Tolerance is if the Customer requests a X & R for each Production run and most of our Customers have gotten away from that. The last time we had a major Customer wanting us to do that was in 2003. Now it is only done during the initital PPAP Process. Does this clarify it a bit better? I think sometimes I don't write it correctly ( being German and all):notme: and then people get confused :confused:
Q
Quality101
#13
I also reference other documents in my control plan and pass audits.
On the other hand Ford wants everything in the contol plan, so I only do it for ford.:mad:
CliffK
#14
Are you doing dimension checks?
I'm not criticizing, I'm just trying to understand.
Howard Atkins
Forum Administrator
#15
As an auditor I take the control plan and when I get to a station that refers to Form ZYX or Spec 123 or calls out drawing DDD, I have no problem with that as long as the relevant document is at the position and the operator can produce it for me.
I then check that he is working according to these documents.
The control plan should be for you to overlook the process and not become a burden.
If we look at Annex A it says
Each part shall have a control plan but, in many cases, family control plans may cover a number of similar parts produced using a common process. Control plans are an output of the quality plan.
IMO then the must be the possibility to refer to dimensions, tolerances etc in other documents as if the "family" had the same characteristics it would the same part and not a family.
try2makeit
#16
I know. Yes we do at First Piece and then the operator does his in production checks to the approved first piece. The most common checks for the majority of our Parts produced are length, width and if there is a hole present the diameter of the hole. If the part is round, then the Diameter of the part. If anything should happen during the production run that compromises any of these diamensions, you can clearly see it when you do your Frequency check. Let's say the hole is not round anymore, well clearly right there you can see that you are not making parts anymore that are within the tolerances given by the Customer. The Part is oversudden longer or wider then your approved first piece you are out of spec.
Our parts that we make are not that complicated they are pretty straight forward, unlike some of you who work for Companies that produce parts that are very complex. :)
try2makeit
#17
Thank you Howard. That is what our CB Auditors do. They get the Control plan for that part that they are getting ready to audit.
Example: Setup for Part # ABC , Correct Tool --> Shop order packet. Now you look at the Shop order and there you will see the Tool number 123, so the Tool in your Press better has the numbers 123 on it. Correct Material ---> Shop order Packet and Material Identification tag. Auditor should be able to take the Shop order look at the Material requirements and match them to the Material Identification tag.
Each process that the part has to go thru is in the Control plan and a reference is made to where you find the Information.
B PFMEA and Control Plan Links APQP and PPAP 2
B Links between Process Flow, Process FMEA and Control Plan IATF 16949 - Automotive Quality Systems Standard 22
J Software which links Process FMEA (PFMEA), Control Plan and Flow Chart Quality Assurance and Compliance Software Tools and Solutions 9
Q Outsourcing & the Control Plan (Ours and the Subcontractor's) - Links, etc. APQP and PPAP 10
S Control Plan and Design FMEA (DFMEA) Links FMEA and Control Plans 4
A Prototype control plan FMEA and Control Plans 2
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 1
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
D Supplied Product on Control Plan - Lot ranging in 40,000 pcs per product FMEA and Control Plans 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 0
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
M Dynamic Control Plan Draft - need review FMEA and Control Plans 2
Ashland78 IATF 16949 Control Plan Authorizations IATF 16949 - Automotive Quality Systems Standard 2
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
Rameshwar25 What is a Control Plan at "Material Level"? IATF 16949 - Automotive Quality Systems Standard 4
L Control Plan - Multiple Process Steps FMEA and Control Plans 8
W Purchased Part Control Plan (IATF 16949) FMEA and Control Plans 7
J VDA audit, control plan - My hair is almost gone now VDA Standards - Germany's Automotive Standards 5
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
Jeff Putman EQI Prelaunch Control Plan - Definition Customer and Company Specific Requirements 0
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
N Control plan references FMEA and Control Plans 6
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
J Functional group / area responsible on a Control Plan IATF 16949 - Automotive Quality Systems Standard 1
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
T IATF 16949 Control Plan and Process Monitoring Requirement(s) IATF 16949 - Automotive Quality Systems Standard 1
J Why Control Plan Review needs to be Approved by the Customer IATF 16949 - Automotive Quality Systems Standard 1
A Corrective Action Column in Control Plan and aligning PFD, PFMEA and Control Plan FMEA and Control Plans 6
M Control Plan MSA's - Pressure Gages IATF 16949 - Automotive Quality Systems Standard 2
S Family / Generic type of FMEA & Control Plan and Symbols FMEA and Control Plans 3
V Do I need to add everything on print to control plan? FMEA and Control Plans 1
H Control plan example format for CNC machining activities FMEA and Control Plans 3
M Mention "according to Work Instruction" in Control Plan FMEA and Control Plans 3
W Does TS16949 require MSA on all measurement systems in the Control Plan? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 5
T Software for linking Process Flow Diagram, Process FMEA and Control Plan APQP and PPAP 9
S Attribute G&R for all Visual Controls in Control Plan Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1
I Any recommendations on software for managing the APQP, PPAP, PFMEA, Control Plan etc? Quality Assurance and Compliance Software Tools and Solutions 2
F What goes into a Control Plan? FMEA and Control Plans 1
