Control Plan
I found different interpretation of rules and contain of Control Plan.
In the last time to different auditors say that Work instruction must be added in Control Plan and for this point the give nonconformity in audit.
I read and reread the APQP (base of Control Plan) and others example from different sources and I have not found this topic as “Work instruction must / have to added in Control Plan” (in text or in example).
In my opinion Work instruction is a document result behind Control Plan (request of product or process characteristic).
There are various opinions that WI should be added at “Specification / Tolerance’ or at “Control Method”...what is true, how it should be?
Thank you!
John Predmore
In my opinion, a Control Plan is a Risk Management tool. It provides value if it helps you identify and plan for risk and react appropriately when bad things happen. The people who benefit from Risk Management are your organization and your customer(s). There are different approaches what to include in a Control Plan and how much detail needs to be included. If the Control Plan provides value to your organization and your customer(s) (value being risk mitigation in all it many forms), then I conclude you are doing the Control Plan correctly. If someone has a suggestion, and that suggestion adds value to your Control Plan, then certainly consider that. If an idea adds no value, then I think the idea is only an opinion.
If an auditor has an opinion which is different from yours, they are bound by an auditor's code of conduct to listen to your explanation and consider whether your opinion has validity. If a difference of opinion cannot be resolved between you and an auditor, you are allowed to speak to the audit authority.
malasuerte
Thank you!
Hi Cristi
That is a bad NC written.
A Control Plan is for "CONTROL" :)
The Control Plan should be a document for your org that describes the actions (measurements, inspections, quality checks or monitoring of process parameters) required at each phase of a process with a final piece of how to react/respond if the control goes bad.
Zero_yield
No cost too great...for Quality
From my limited interaction with Control Plans, usually there's a basic sense of "If A happens, do B. If C happens, do D." Does your Control Plan contain or reference instructions on what to do in case of a few event-based items?
malasuerte
Hi Cristi
@Cristi Cobrac
In re-reading, I do want to clarify, since verbiage can be a concern here: The OCAP/Reaction Plan must be captured in the Control Plan.
A "Reaction Plan" is a "Work Instruction". A "Work Instruction" could also be a for maintenance, processing, metrology, etc.
So to make sure: You have the Reaction Plan in your Control Plan? If it is missing, then the NC could be correct.
But there is not a requirement to put the WI that tells someone how to process or do the work at the step.
S Control plan for "highly automated processes" FMEA and Control Plans 3
B 8.5.1.1 Control Plan - question audit NC IATF 16949 - Automotive Quality Systems Standard 5
B QM Plan vs Control Plan IATF 16949 - Automotive Quality Systems Standard 3
N AS 13004 Control Plan and AQL FMEA and Control Plans 1
J PFMEA/control plan question- PLEASE HELP ! IATF 16949 - Automotive Quality Systems Standard 8
Y FMEA link to Control Plan frequency and sample size FMEA and Control Plans 19
S Linking control chart with control plan Statistical Analysis Tools, Techniques and SPC 5
S Operation of possible rework in control plan FMEA and Control Plans 8
M Process & Product Characteristic in Control Plan FMEA and Control Plans 17
Sonja D AIAG VDA PFMEA and Control Plan training FMEA and Control Plans 9
A Control plan for IATF - example? FMEA and Control Plans 1
S Maintenence related action in Control plan FMEA and Control Plans 3
R Control Methods in Control Plan FMEA and Control Plans 5
L Looking for Control Plan and FMEA Stamping process FMEA and Control Plans 2
Jimmy123 IATF16949 Control Plan FMEA and Control Plans 1
A Prototype control plan FMEA and Control Plans 2
G Control Plan & PFMEA Review Procedure? FMEA and Control Plans 10
P IATF 16949 requirement - error-proofing in control plan IATF 16949 - Automotive Quality Systems Standard 3
J Control Plan use on the manufacturing floor FMEA and Control Plans 4
D All Dimensions listed on control plan FMEA and Control Plans 10
DuncanGibbons Manufacturing Plan vs Material Specification vs Control Plan Manufacturing and Related Processes 5
S Should safety checks be included in the Control Plan? IATF 16949 - Automotive Quality Systems Standard 5
D Supplied Product on Control Plan - Lot ranging in 40,000 pcs per product FMEA and Control Plans 3
M Is there any pre-defined Control plan format/template acc. VDA? VDA Standards - Germany's Automotive Standards 1
G Control Plan - Include the processes for each sub component? APQP and PPAP 2
A Redesigning our process flow chart, PFMEA and Control Plan Process Maps, Process Mapping and Turtle Diagrams 4
D Link between FMEA, flow chart and control plan FMEA and Control Plans 10
M Dynamic Control Plan Draft - need review FMEA and Control Plans 2
Ashland78 IATF 16949 Control Plan Authorizations IATF 16949 - Automotive Quality Systems Standard 2
N Control plan evaluation methods - Which methods should be carried over from the PFMEA? FMEA and Control Plans 3
Rameshwar25 What is a Control Plan at "Material Level"? IATF 16949 - Automotive Quality Systems Standard 4
leftoverture Control Plan - Multiple Process Steps FMEA and Control Plans 8
W Purchased Part Control Plan (IATF 16949) FMEA and Control Plans 7
J VDA audit, control plan - My hair is almost gone now VDA Standards - Germany's Automotive Standards 5
Howard Atkins MSAs are now required on every feature of the control plan - IATF 16949 IATF 16949 - Automotive Quality Systems Standard 13
Jeff Putman EQI Prelaunch Control Plan - Definition Customer and Company Specific Requirements 0
V How to Add Annual Revalidation requirements to Control Plan? FMEA and Control Plans 5
N Control plan references FMEA and Control Plans 6
L Simple Example for PFMEA / Control Plan Training Training - Internal, External, Online and Distance Learning 1
J Functional group / area responsible on a Control Plan IATF 16949 - Automotive Quality Systems Standard 1
T Should Testing be a separate operation in the Control Plan? FMEA and Control Plans 5
M Annual Layout requirements for PPAP/Control Plan FMEA and Control Plans 6
T IATF 16949 Control Plan and Process Monitoring Requirement(s) IATF 16949 - Automotive Quality Systems Standard 1
J Why Control Plan Review needs to be Approved by the Customer IATF 16949 - Automotive Quality Systems Standard 1
B PFMEA and Control Plan Links APQP and PPAP 2
