Interesting Discussion Controlled Copy Stamp - Document Control
Stijloor
#11
Re: Control Of Documents: Controlled Copy - Controlled copy stamp
Hi friends, do we need to put a controlled copy stamp on our documents to differentiate between iso documents and non iso documents?
:thanks:
There is no such thing as "ISO Documents." You have documents that support the processes in your quality management system. You control those. Then, get rid of the rest. If they do not serve a purpose, your should not have them. :agree1:
Stijloor.
Helmut Jilling
Auditor / Consultant
#12
You need to classify documents as controlled and uncontrolled.
A controlled document can be updated, amended, reviewed and approved prior to issuance and distribution to intended users or copyholders. Uncontrolled document is a copy of document distributed to whomever upon request for specific purpose (training., audit, etc). There are a lot of ways to distinguish controlled and uncontrolled e.g. stamping. If stamping works for you, so be it.
If you use it, post it, distribute it, it is beneficial to know the info is up to date and correct. You do that by controlling it. Controlling all the docs you use is much easier than controlling some and not others.
However, some docs are correct when you give them to someone, but you do not intend to continue to control them. It is helpful to have dates on them, but some people stamp that type uncontrolled to make the distinction clear.
DrM2u
#13
At the organization where I am now, I have a drawer full of stamps from my predecesor. I got REJECT, REFERENCE ONLY, OBSOLETE, ISSUED DOC CTRL, FOR REFERENCE ONLY, CONTROLLED, UNCONTROLLED, DOCUMENT CONTROL #, RECEIVED, etc. I also got about a dozen inking pads and ink refills of various collors, with red and blue the predominant ones. There is even a kit so I can make my own customized stamp if needed. I could not find any instructions as to what stamp and color combinations are supposed to be used for what occasion. All these were at one point in time related to document control. I wonder if the stamps were controlled too?!? :sarcasm: :lmao:
Proud Liberal
#14
:topic:
In addition to a red stamp, I also use a custom paper hole punch in the shape of a maple leaf. Even color copies of controlled documents don't have the punched out leaf.
savetheearth
#15
Hi friends, we have been using all these kinds of color-stamps but we find it did not help us at all but caused us to lose a lot of time and making mistakes.
We think 9001 only asked for prevention of "unintended" use ... Can we say that color stamp and "embossed" are for the prevention of "intended" fraud?
By recording the distribution and update recipients with changes and revisions, we think has meet the 9001. Will we get NC?
We think if people intentionally making unauthorized copies, it is hard to prevent. But we think "embossed" or more sophisticated means are required to prevent intended fraud.
DrM2u
#16
As you have already found out, stamps don't always work and certainly do not prevent the copying of controlled documents. A stamp, just like an emboss, is just a method of identifying the documents. By simple analogy, one could draw the conclusion that embossing will work just as good (or bad) ar stamps.
Have you consider other methods of controlling and distributing documents? (hint: there is no specific requirement that documents must be in hard-copy format). It is hard to tell if you will get a NC or not unless someone actually audits/assesses your document control system. The auditor will let you know his/her oppinion and you can agree or dispute it at that time. It would be incorrect for us to say YES or NO in behalf of the auditor.
'Fraud' is a very strong word to use in relation to documentation. Are you sure it is 'fraud' or is it just people bypassing a cumbersome (ineffective and inefficient) system in order to get things done? According to Webster's Dictionary fraud is:
- "a: intentional perversion of truth in order to induce another to part with something of value or to surrender a legal right:
- "b : an act of deceiving or misrepresenting"
bobdoering
Stop X-bar/R Madness!!
#17
By simple analogy, one could draw the conclusion that embossing will work just as good (or bad) as stamps.
May not be a simple analogy, as a copy of an emboss is easier to detect than color copies of stamps. I would not recommend it, unless you have the situation the poster has, and needs to get the situation under control until such time the culture can be changed to utilize the system correctly.
It is hard to tell if you will get a NC or not unless someone actually audits/assesses your document control system. The auditor will let you know his/her opinion and you can agree or dispute it at that time. It would be incorrect for us to say YES or NO in behalf of the auditor.
I think it is fair to say that if an auditor finds in their sampling a document in use that is the incorrect revision, it is an NC. If they have the objective evidence, there is little to dispute, unfortunately.
It may not infer precisely the correct meaning, but I am not adverse to the strength of the word. We can not assume that the system is cumbersome - there are people so adverse to change that they will expend more effort to circumvent an adequate system that utilize it. We would have to see the system to make that judgment.
DrM2u
#18
There was a strong undertone of sarcasm in my reply. Trying to control an ineffective and inefficient system is a waste of time and resources. My suggestion for the OP is to re-evaluate if the system is indeed the best system that meets organization's needs. Of course, there is always the option of maintaining the status-quo if that is the organization's culture.
Agreed, the auditor could (not saying for sure though) very well issue a finding if there is evidence to support it. What remains to be decided by the auditor is the significance of the finding. Some registrars use Nonconformance for significant system failures and Areas of Concern for less significant ones. The category and criteria depends on the applicable standard. I stand that my previous statement that I cannot predict what the auditor will do for sure!
A robust system should be efficient and effective, and should also prevent the unintended errors from occuring. If a system is bypassed then it is either not robust or the bypass is intentional. If the system is intentionally bypassed then either the system is cumbersome to the users or there is no system for accountability (rewards & punishment) within the organization for the ones 'resisting change'. My previous statement was only insinuating that the OP should re-visit the system to identify the root cause of failure.
savetheearth
#19
We may resort to the use of stamp or embosser to prevent intentional violation of our company rules on document control but we think the more appropriate one would be disciplinary action to deal with the persons committing such "crime".
To prevent unintentional use of obsolete documents as required by 9001, we make use of obsolete stamp in red color. As 9001 does not require the control of prevention of unauthorized copying, NC should not be issued unless such act actually led to the use of an obsolete copy, are we correct?
Unauthorized copying could lead to the use of obsolete document but such act without an objectibve evidence of the presence of an obsolete document being use should be an observation for us to take further action, are we correct?
bobdoering
#20
The objective evidence of the use of an obsolete copy is the most likely to generate a finding. If it is possible to tell if a document in use is an uncontrolled copy, then there could be a finding for that, too.
S Controlled Copy Stamp on "Paper Originals" Document Control Systems, Procedures, Forms and Templates 10
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
eternal_atlas Is not having a controlled copy of ISO 9001 standard a NonConformance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 114
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
A Distribution of Controlled Copy vs. Uncontrolled Copies Document Control Systems, Procedures, Forms and Templates 4
A What is an uncontrolled copy of a controlled document? Document Control Systems, Procedures, Forms and Templates 11
M External prints - Should copies should be marked ?Controlled Copy?? Document Control Systems, Procedures, Forms and Templates 2
N Definition Controlled Copy vs. Uncontrolled Copy - What are the definitions and differences? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 10
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CS2 (Controlled Shipping Level) by GM - CB notified. What about other customers? IATF 16949 - Automotive Quality Systems Standard 1
R Digital Storage of ITAR Controlled Documentation Other ISO and International Standards and European Regulations 7
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
C Need examples for Controlled Shipping I and II (CSL) IATF 16949 - Automotive Quality Systems Standard 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
D Should Customer Drawings be controlled per AS9100 QMS ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Types of Controlled Documentation - Call Lists of Emergency Contacts Quality Manager and Management Related Issues 5
