Definition Controlled Document Definition - What constitutes a controlled document?
shereenk
Hi, I am new to the forum but have read through some very helpful threads.
Right now, I am trying to come up with a good document control process and would like to know the following:
1. How do I determine what documents need controlling? My company has the following types:
a) Process documents - which WILL be controlled
b) Documents sent to customers by Marketing - brochures, flyers, presentation slides, newsletter
c) Invoices, receipts, credit notes - which are generated by software
d) Product documentation - notes on the products generated by Technical Writer
2. One proposed document ID format (by consultant) uses document types like RP - Report, FR - Form, CK- Checklist, PR - Procedure... he even said should have one called TM - Template.. but I'm thinking... isn't everything a template? So it's funny that I have:
FR-001 for Training Form
TM-001 for the same Training Form
Is it right to do away with TM document type?
3. Some of the process documents have been in used for years but there is no release date or version number. How should this be tackled? I just use version 1 and current date?
Hope you guys can help out.
Thanks,
Shereen
harry
Re: What constitutes a controlled document?
Welcome to the Cove, Shereen.
This had been extensively discussed here before and I will direct you to some previous discussions instead. See: What is the difference between a controlled document and an uncontrolled document? Also, scroll down the page to read other threads in the 'Similar Discussion Threads' box.
Unless you are a very big organization with hundreds of documents, you can control documents by 'name of the document' and revision number. Issued date is useful but not necessary. It is your choice if you do not want the cumbersome 'dinosaur' practice that you had described.
Existing documents can be put under control by starting with Revision 'Zero' or even 'One' if you choose so. After all, these will be described in your document control procedure.
Some related and informative threads found using the search function.
Jeff Frost
Shereenk ,
This can get a little complicated for those starting the control of documentation for the first time. There are typically three types of documents that must be controlled.
Management Documents
· Quality Policy
· Quality Manual
· Procedures
· Work Instructions
Technical Documents
· External Specifications (MIL, ASTM, customer specs, etc.)
· CAD Drawings
· Blueprints
· Schematics
· Job travelers/work orders
· Order-specific instructions
· Reference charts
Forms
· Forms
Each type of document can have their own format or template so you really do not have to reinvent the wheel here just standardize of one format for management documents and technical documents. Forms are, well… forms so they should be in a format needed to collect or record data.
Because you are implementing a new system for control of documents the revision for historical documents can start at Revision 1, or NC or A, date of approval and a revision history note such as “original issue”.
Hope this helps.
Jeff
Matt Swartwood
Long story short, ask the question "Does or could the application of the document adversely affect the quality of the product" If the answer is yes, then you must control the document. If the answer is no, it is your choice on whether or not to control the document.
well, the standard tells you what is required in 4.2.1. The kicker is 4.2.1 d). Matt's suggestion is correct, but I would take it one step farther. Does the document affect the effectiveness or efficiency of the process as well? Bottom line is.... if I need the document to do my job, it must be controlled.
SteelMaiden
I tried to post yesterday, but had some computer problems. I agree that stopping at "does it affect product quality" is probably not far enough. ISO-9001 is about your quality systems, not about your product quality. If all we had to worry about was product quality we could stop with an ASTM standard and a bunch of inspections. That was not effective, effecient nor economically healthy, that is why we are all following some sort of qualty management system now instead of only quality control.:agree:
shereenk
Thank you very much for your advice... Makes it much clearer now and I'm on my way to listing out the documents.. :)
F
ffemt1
The way I determine if a document needs revision control is to ask 3 questions.
FIRST - "Can the relevant information it provides ever change?"
If the answer is NO, you do not need to control the document. - Example - Wal-Mart has several calendars, some with cats, some with dogs, and some even have spaceships on them, but Jan. 1, 2009 is always on Thursday and will never change so we do not need to control calendars even though they may look different.
If the answer to the first question is YES then ask, "Can the change DIRECTLY affect the quality of the product we produce?"
If the answer is NO, you do not need to control the document. Example - The internal phone list changes all the time, but does not knowing my new phone number DIRECTLY affect the quality of the product we produce?" Probably not. You can call the operator and get the new number so we do not need to control phone lists.
If the answer to question 2 is Yes, the document needs to be controlled. Example - Job tickets can change and if you do not have the current revision, it might affect the quality the customer will get. Is that ticket we printed last week still current?
You then need to ask "Who needs to know about the change?" Some changes just a few people need to know about. Example - Customer Files can change and we may be receiving a new file from a customer. Maybe only Customer Service and Prepress needs to know this. Some changes a lot of people need to know about. Maybe a customer increases counts and changes binding style. Many people need to know about this. When a change is made, we need to know who is affected.
The main reason we need to control documents is to make sure the right information is in the right place at the right time.
"CONTROL" means when there is a change we should be able to find ALL of the old documents and replace them with new ones, and if training is needed, know who needs it. That way there is no chance of of using old information, and everyone understands the change.
Y
Yarik
Hi Shereen,
It's difficult to answer this question without understanding what exactly do you (or your consultant) mean by "template".
If the issue with ID convention is still open, could you please clarify how many templates are you planning to have and documents of what types are going to use each template?
For example, you might have a separate template for each document type (one template for reports, another - for checklist, yet another - for forms, etc.).
Best regards,
Yarik.
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
C Use of white-out or obliterating a portion of a controlled drawing or document Document Control Systems, Procedures, Forms and Templates 7
N Controlled Document Binders on the Production Floor Document Control Systems, Procedures, Forms and Templates 3
I Is facility floor plan a required controlled document? ISO 13485:2016 - Medical Device Quality Management Systems 8
D Are signatures required on every page of a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Controlled document training requirements and structure ISO 13485:2016 - Medical Device Quality Management Systems 2
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Does this document (housekeeping checklist) need to be controlled? Document Control Systems, Procedures, Forms and Templates 8
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
R Should Internal Audit criteria be a Controlled Document? Internal Auditing 5
J Controlled Document Requirements for Marketing Materials Document Control Systems, Procedures, Forms and Templates 1
N Does a Document Distribution List need to be a Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
N Must Templates be controlled? Controlled Document Query ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Preventing Photocopies of a Controlled Document Document Control Systems, Procedures, Forms and Templates 18
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
T Controlled Document vs. Controlled Manual Document Control Systems, Procedures, Forms and Templates 3
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K A document is controlled when......... Document Control Systems, Procedures, Forms and Templates 7
GStough Internal Audit Checklist as a Controlled Document - Pros and Cons Internal Auditing 19
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
H Distribution of Controlled Copies - Document Control Document Control Systems, Procedures, Forms and Templates 10
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
W Design and Development Planning - Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Have you seen and What is an Unusual Controlled Document Records and Data - Quality, Legal and Other Evidence 6
A Does the PSW (Part Submission Warrant) need to be a controlled document? APQP and PPAP 7
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
B Document and Record Matrix - A controlled document? Document Control Systems, Procedures, Forms and Templates 10
S Interesting Discussion Controlled Copy Stamp - Document Control Document Control Systems, Procedures, Forms and Templates 70
V Should the EMS manual be a controlled document? Miscellaneous Environmental Standards and EMS Related Discussions 7
M Examples of DCR (Document Change Record) Log and Document Controlled Log Document Control Systems, Procedures, Forms and Templates 3
F CE Mark Technical Files as controlled document in ISO9001 QMS Document Control Systems, Procedures, Forms and Templates 7
W Controlled Documents - Trying to differentiate document control levels Document Control Systems, Procedures, Forms and Templates 5
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
D Customer Quality Manuals - Document of external origin and must be controlled? Document Control Systems, Procedures, Forms and Templates 14
P TS16949 - Should specific process notes be considered a controlled document. IATF 16949 - Automotive Quality Systems Standard 4
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
J How to determine which is the 'master' "controlled" version of document Document Control Systems, Procedures, Forms and Templates 9
J Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained? Document Control Systems, Procedures, Forms and Templates 7
G Posted document/Visual Aid as reference - Must they be controlled? Document Control Systems, Procedures, Forms and Templates 3
