Controlled Document Location
Hi All,
Looking for some advice on how to control documents correctly per ISO9001:2015. I'm currently updating the form of my companies work instructions. In the past, we have added a print date and expiration date to the document, and had all copies electronically. However, there was a lack of computer knowledge with the floor workers, so I'd like to have a printed copy available for daily use.
I'm leaning towards putting a file path at the bottom, and saying something like "This document is controlled at location. Verify that the document is current before use. If questions, contact the quality department."
In doing this, I'm concerned about a potential audit. I know having documents printed at all leads to potential NCs. I'm going to have a master list with locations of all documents to be obsoleted and recalled when a new revision is created. However, I don't want to add a statement like that in, and then in an audit have an operator not check for the correct version.
Am I making this too difficult? Do I need any of this? Or can I control it purely with a master list and have only quality responsible for the correct versions on the floor (and if that's the case, do I just put controlled in the footer)? Furthermore, do I need to mark documents as controlled at all, or can I just have my doc control procedure lay all of that out?
Thanks in advance!
ISO 13485 Medical Device environment here
I have almost all of my controlled documents available only electronically. All controlled documents live on one controlled drive on our network. All employees are trained to this network drive. I have a few work instruction manuals where the owner of the manual refuses to give up her hard copies. Auditors are always finding incorrect revisions and the owner refusing to give up hard copies is responsible for completing any CAPAs related to these nonconformances. All employees have computer access at or near their work stations.
I do have several "wall postings" controlled and hard copies are assigned to certain locations on the plant floor. These are noted within my Document Masterlist.
My way may not be the best way to handle documents but no audit issues have been raised as of yet.
JimS
ISO 9001:2015, not medical.
All of our controlled docs are available electronically from a controlled SharePoint library. There are a few workstations that don't have computer access, however, so our SOP defines a process whereby the manager can request a hard copy, noting where it is to be used. Doc Control prints it, stamps it as a controlled copy, then initials and dates it, noting the location where it "belongs". And since a good color copier can easily replicate all that, we also use a non-circular hole punch to punch a hole in it. Something odd available at hobby stores but someone would have to go through a lot of trouble to duplicate. If someone does that, you've got bigger problems!
If a new revision is released, the manager submits another request. I prepare it but don't hand it over until he hands me the old revision, which is destroyed. This process is working well for us.
Ours are in electronic form also, however to minimize disruptions when auditors show up, I have made up a notebook of our controlled documents and so keep one book current with all.
This is helpful when I need to quickly access a particular form for a possible revision or update, and we dont have to waste alot of time showing auditors how to access the system. Keeping one book is not really much of an added burden and has been more of a help than a hindrance. As part of our internal audits, this book is checked for being up to date and accurately reflecting the electronic information.
R Regulations on Controlled Document Size (Paper Size) Document Control Systems, Procedures, Forms and Templates 4
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
C Use of white-out or obliterating a portion of a controlled drawing or document Document Control Systems, Procedures, Forms and Templates 7
N Controlled Document Binders on the Production Floor Document Control Systems, Procedures, Forms and Templates 3
I Is facility floor plan a required controlled document? ISO 13485:2016 - Medical Device Quality Management Systems 8
D Are signatures required on every page of a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
B Controlled document training requirements and structure ISO 13485:2016 - Medical Device Quality Management Systems 2
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Does this document (housekeeping checklist) need to be controlled? Document Control Systems, Procedures, Forms and Templates 8
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
R Should Internal Audit criteria be a Controlled Document? Internal Auditing 5
J Controlled Document Requirements for Marketing Materials Document Control Systems, Procedures, Forms and Templates 1
N Does a Document Distribution List need to be a Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
N Must Templates be controlled? Controlled Document Query ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Preventing Photocopies of a Controlled Document Document Control Systems, Procedures, Forms and Templates 18
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
T Controlled Document vs. Controlled Manual Document Control Systems, Procedures, Forms and Templates 3
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K A document is controlled when......... Document Control Systems, Procedures, Forms and Templates 7
GStough Internal Audit Checklist as a Controlled Document - Pros and Cons Internal Auditing 19
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
H Distribution of Controlled Copies - Document Control Document Control Systems, Procedures, Forms and Templates 10
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
W Design and Development Planning - Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Have you seen and What is an Unusual Controlled Document Records and Data - Quality, Legal and Other Evidence 6
A Does the PSW (Part Submission Warrant) need to be a controlled document? APQP and PPAP 7
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
B Document and Record Matrix - A controlled document? Document Control Systems, Procedures, Forms and Templates 10
S Interesting Discussion Controlled Copy Stamp - Document Control Document Control Systems, Procedures, Forms and Templates 70
V Should the EMS manual be a controlled document? Miscellaneous Environmental Standards and EMS Related Discussions 7
S Definition Controlled Document Definition - What constitutes a controlled document? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
M Examples of DCR (Document Change Record) Log and Document Controlled Log Document Control Systems, Procedures, Forms and Templates 3
F CE Mark Technical Files as controlled document in ISO9001 QMS Document Control Systems, Procedures, Forms and Templates 7
W Controlled Documents - Trying to differentiate document control levels Document Control Systems, Procedures, Forms and Templates 5
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
D Customer Quality Manuals - Document of external origin and must be controlled? Document Control Systems, Procedures, Forms and Templates 14
P TS16949 - Should specific process notes be considered a controlled document. IATF 16949 - Automotive Quality Systems Standard 4
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
J How to determine which is the 'master' "controlled" version of document Document Control Systems, Procedures, Forms and Templates 9
J Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained? Document Control Systems, Procedures, Forms and Templates 7
