Controlled Document Requirements for Marketing Materials
Java23
Hi - Looking for some advice / input regarding what is considered "controlled" and should go through the change control process.
Scenario:
Marketing creates a couple of ads to be included in a journal publication. There is no product information in the ads but, a program (which is trademarked) that will be offered at an upcoming event along with the company name, what the program will include (including description of the procedure to be performed with use of the device). Marketing assigns a "control" number to each piece along with a Rev. # (new so Rev. 1).
I review and approve the change notice with the ads. The change notice then goes to the next person on the approver list - that person cancels the change notice. Reason given is that the ads state nothing relevant to quality or regulatory, nor was it considered literature, therefore should not go through the change control process.
Any advice / comments / or explanation of what is considered "literature" - change order clearly states literature to be reviewed.
Thank you :)
G
Geoff Withnell
Scenario:
Thank you :)
The main question is, if there is a change in the product or process, do you want to be sure that this material, "literature" or whatever, gets updated? If so, put it under control. If you don't care, then don't.
B Controlled document training requirements and structure ISO 13485:2016 - Medical Device Quality Management Systems 2
W Controlled Document vs. Uncontrolled Copy - Stamp requirements Document Control Systems, Procedures, Forms and Templates 11
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
C Use of white-out or obliterating a portion of a controlled drawing or document Document Control Systems, Procedures, Forms and Templates 7
N Controlled Document Binders on the Production Floor Document Control Systems, Procedures, Forms and Templates 3
I Is facility floor plan a required controlled document? ISO 13485:2016 - Medical Device Quality Management Systems 8
D Are signatures required on every page of a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 33
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Does this document (housekeeping checklist) need to be controlled? Document Control Systems, Procedures, Forms and Templates 8
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
R Should Internal Audit criteria be a Controlled Document? Internal Auditing 5
N Does a Document Distribution List need to be a Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
N Must Templates be controlled? Controlled Document Query ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S Preventing Photocopies of a Controlled Document Document Control Systems, Procedures, Forms and Templates 18
D DMR (Device Master Record) Index as a Controlled Document 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 7
Chennaiite Controlled vs. Uncontrolled Document - Clarification requested IATF 16949 - Automotive Quality Systems Standard 11
T Controlled Document vs. Controlled Manual Document Control Systems, Procedures, Forms and Templates 3
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
K A document is controlled when......... Document Control Systems, Procedures, Forms and Templates 7
GStough Internal Audit Checklist as a Controlled Document - Pros and Cons Internal Auditing 19
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
H Distribution of Controlled Copies - Document Control Document Control Systems, Procedures, Forms and Templates 10
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
W Design and Development Planning - Controlled Document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
S Have you seen and What is an Unusual Controlled Document Records and Data - Quality, Legal and Other Evidence 6
A Does the PSW (Part Submission Warrant) need to be a controlled document? APQP and PPAP 7
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
B Document and Record Matrix - A controlled document? Document Control Systems, Procedures, Forms and Templates 10
S Interesting Discussion Controlled Copy Stamp - Document Control Document Control Systems, Procedures, Forms and Templates 70
V Should the EMS manual be a controlled document? Miscellaneous Environmental Standards and EMS Related Discussions 7
S Definition Controlled Document Definition - What constitutes a controlled document? Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 9
M Examples of DCR (Document Change Record) Log and Document Controlled Log Document Control Systems, Procedures, Forms and Templates 3
F CE Mark Technical Files as controlled document in ISO9001 QMS Document Control Systems, Procedures, Forms and Templates 7
W Controlled Documents - Trying to differentiate document control levels Document Control Systems, Procedures, Forms and Templates 5
K Document Control Terms: Obsolete, Master Copy, Controlled and Uncontrolled Copy Document Control Systems, Procedures, Forms and Templates 2
J What is the difference between a controlled document and an uncontrolled document? Document Control Systems, Procedures, Forms and Templates 10
D Customer Quality Manuals - Document of external origin and must be controlled? Document Control Systems, Procedures, Forms and Templates 14
P TS16949 - Should specific process notes be considered a controlled document. IATF 16949 - Automotive Quality Systems Standard 4
J How to determine which is the 'master' "controlled" version of document Document Control Systems, Procedures, Forms and Templates 9
J Document control - ISO 13485:2003 - Obsolete controlled documents shall be retained? Document Control Systems, Procedures, Forms and Templates 7
G Posted document/Visual Aid as reference - Must they be controlled? Document Control Systems, Procedures, Forms and Templates 3
