Controlled Documents & Note Making
Deli88
Hi Everyone,
I have a quick question on controlled documents in the form of job specifications.
Every job we do have their own spec card with details on how to set up the machines and cut product to size, occasionally or on the first issue of a spec the operator will write notes on the spec, usually this has to do with the fine-tuning product to meet tolerances or increasing yield.
is this acceptable if the notes are incorporated into the spec when it is returned to the office on completion of the job or is this a major no-no?
Any suggestions on how I could do this while conforming to ISO standards would be appreciated
Thanks in advance
Marcelo
Hum, you know that a specification is a document that contains requirements, right? So a specification would not define how to do stuff, it would contain the expectations.
The document that contains the way to fulfill the requirements is a procedure, or work instruction, or the like.
Deli88
I didn't come up with the terminology, I just inherited it from my predecessor.
It is essentially a work instruction for individual jobs and does define the finished product dimensions (which are never changed unless through an agreement with the customer) but the means of achieving these specifications may need altering. This is usually required after the first run when the operator notes adjustments are needed to achieve the correct tolerances on the finished product.
Marcelo
No problem, I was just trying to make things clear so we people can better help.
So, whatever the document is (let's use your comment on work instruction) it would be ok to write it and then include it in a revised work instruction if:
- This possibility is included in the document control (procedure)
- The person can do this (responsibility and authority)
- The way it's done is according the document control (the usual way to accept written changes is to have the corrected text have a strikethrough without loosing the original text, and the new text is written near it, and the person signs and dates it - but there can be more ways to do that)
Deli88
Thanks Marcelo,
I was thinking something along these lines but its always nice to have a second opinion on something like this.
T Changes to Controlled Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
D MDR technical file: does it need to contain duplicates of controlled documents EU Medical Device Regulations 2
D Are there Controlled Documents in a DMR (Device Master Record)? ISO 13485:2016 - Medical Device Quality Management Systems 3
A Distribution of controlled documents through e-mail, is it ok? Document Control Systems, Procedures, Forms and Templates 3
M Do employee training records need to be controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
Q Modification in Controlled Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
R Part Prints - Controlled and Uncontrolled Documents (e.g.: The Production Floor) Document Control Systems, Procedures, Forms and Templates 13
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
A Do controlled documents require a signature on every page as per 21 CFR 820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
x-files Documents required by the quality management system shall be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
A How are Electronic Editable Documents Controlled Document Control Systems, Procedures, Forms and Templates 7
K Printed documents can't be controlled Document Control Systems, Procedures, Forms and Templates 16
C Documents not controlled by the ECO (Engineering Change Order) process ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
J Are SPC Charts Controlled Documents according to TS 16949? Quality Manager and Management Related Issues 4
G Document Control-AS9100 - Marking of Documents as Master Copy of Controlled Copy AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
S Document Control - Different documents which must be controlled not identified Document Control Systems, Procedures, Forms and Templates 11
R Controlled Documents vs. Signage Papers (ie, reminders, general information) Document Control Systems, Procedures, Forms and Templates 1
J Add Safety Policies/LOTO/etc. to Controlled Documents? ISO 13485:2016 - Medical Device Quality Management Systems 9
Q Documents uncontrolled when printed, if is not printed is controlled? Document Control Systems, Procedures, Forms and Templates 4
T Which controlled documents should be labeled "Confidential and Proprietary" Document Control Systems, Procedures, Forms and Templates 7
N Controlled Documents Distribution Query - Home Care Company ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
N Is this footer okay for our Controlled Documents? Document Control Systems, Procedures, Forms and Templates 14
B What to include on Controlled Documents that are managed Electronically? Document Control Systems, Procedures, Forms and Templates 2
H Document Control Defined? Determining what documents must be controlled ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
T Inheriting Another Company's Controlled Documents? Document Control Systems, Procedures, Forms and Templates 4
M AS9100 Clause 4.2.3 requirements - Documents required by the QMS shall be Controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
A Are Job Descriptions and Organizational Charts Controlled Documents? ISO 13485:2016 - Medical Device Quality Management Systems 13
A Document Control File - Identifying all documents which need to be controlled Document Control Systems, Procedures, Forms and Templates 11
T Controlled Documents - Can a word document and excel spreadsheet be controlled? Document Control Systems, Procedures, Forms and Templates 5
J Lock-out / Tag-Out Procedures as Quality Controlled Documents? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 25
W Electronic Distribution of Controlled Documents: Validation required? Qualification and Validation (including 21 CFR Part 11) 5
E Wiki vs. Controlled Documents - Eliminating Conflicts Quality Manager and Management Related Issues 5
B Stamping Documents as "Controlled Copy" - Clause 4.2.3 Document Control Stamp Document Control Systems, Procedures, Forms and Templates 17
A Equipment List - Control or not to Control (Controlled Documents) Document Control Systems, Procedures, Forms and Templates 8
M Should Internal Audit Checklists be Controlled Documents? Document Control Systems, Procedures, Forms and Templates 9
A List of controlled documents for ISO9001:2008 Call / Contact Center ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
B Electronic Copies of previous versions of Controlled Documents in editable format Document Control Systems, Procedures, Forms and Templates 3
M All Internally Generated Documents ? Required to be Controlled or Not All? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
M Reissue of controlled documents - No changes identified Document Control Systems, Procedures, Forms and Templates 3
B Printed Copies of Controlled Documents Document Control Systems, Procedures, Forms and Templates 9
B "Controlled" stamp for Controlled Documents - Any alternatives? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
