Controlled Form Font Change - No information is being added or removed - Commments?
Bob_M
Controlled Form Revision - Help
OK I'm still new at this quality/control arena so bare with me :)
We have Controled Forms with form numbers and revisions numbers that are protected on the system. ISO9001:94 going to 9K2K
Some of these forms are used for inspections incoming, in process, etc. These forms have part number and detailed information. (The forms are "templates" for detailed forms).
When the forms are updated (new fields, different font, whatever) should ALL of the detailed versions be updated?
Example1: In coming raw material inspection form has part number and all relavant info for the inspector to check.
I want to update the form so it will be easier to fill out (bigger spaces etc). No information is being added or removed. Do I NEED to update all the part specific inspection forms (which serve as our records)?
Example2: Control Plans - Updated form so additional customer/print information MAY be added where appropriate. Should I update all control plans to use the new "template"?
I'm talking about 1500 part numbers and only me to do everything (I AM the QA dept).
Did this make any sense?
Do I need to update all detailed forms, when I have updated the blank "template" or can I update them as needed?
The old version will in no way hurt production or quality, but they won't visually match the current revision.
Bob_M
E
energy
I wouldn't
Use the same form. Contain the revision within. If you mention the revision in any other document, such as a Master List, you must change it. You said it yourself. It doesn't matter if the old one gets used. For example, they are printed already. use them up. Save a tree. If it's on a Company Intranet, only the latest will be used. No biggee. Welcome to the Cove!:agree: :ko: :smokin:
M Greenaway
Bob
You have answered your own question in that the change of form will not affect production or quality for those documents bearing the old form template, so only change on an 'as needed' basis - thats what we do.
Bob_M
Energy:
To clarify my own post...
The "template" is up to date on the system.
The detailed form is the (excel) form partially filled out with part specific details - Example Control Plan "template" vs. Part Specific Control Plan.
Saving the tree... Yes I'm hoping to minimize the paper copies soon. (We need acrobat 5.0)
M Greenaway
I may have answered my own question, but I wasn't sure that's why I asked :)
Do I NEED to state in our document control policy that we CAN use old revisions of forms IF the information contained within is still valid? 9k2k (soon I hope) :frust:
M Greenaway
I personally dont think you have to necessarily explicitly state that in a policy or procedure, but if it gives you peace of mind then do so. Your argument that there is no effect on quality is as sound an argument as you could wish for, and an auditor would have to prove this wrong in order to raise a non-compliance - which would be nigh on impossible.
Bill Ryan - 2007
Hi Bob
In example #1 - You have only changed the format (I do the same just about daily) without changing any of the "required" information. You haven't changed a thing!!!!! IMO - You don't need to get all part specific forms updated.
In example #2 - The Control Plan is a different story in my eyes. Your registrar may "decide" that you need to update all part specific (or generic) Control Plans to the new format (I'm assuming you're change was in the header??). Yes, in my eyes, you need to change your Master and work toward getting all existing documents upgraded ("my eyes" have been changed due to too many "discussions" (being nice) with our auditor. Our last audit (TS) had a "minor" because we didn't have the 3rd edition PFMEA format on ALL our PFMEAs. The time period to "comply" was "yesterday". When I asked how he thought that might happen, he said he didn't know but it had to happen (apparently my registrar interprets the TS standard as not allowing "grandfathering" - but that's in a different thread). I didn't jump him on it, but we still don't have our Masters (part specific) updated to 3rd edition. If we get another finding Monday or Tuesday (our next surveillance audit) I will have to give him the old "where does it say that?" (although it might be too late then)).
I realize I got off the subject with example 2 but I think the two documents are closely related, concerning format, in an auditor's eyes.
Happy surrogate Friday and Happy Thanksgiving.
Bill
P
Phil Schoner
I have successfully argued that forms need not be controlled. They are simply a conveniently formatted piece of paper to enter records. When they are filled out, they become a record and are controlled as such. Otherwise, how do you enter information on a controlled form without revising it by so doing?. This in itself is revising the document and requires all the rules of document control (approval, etc.).
Just be sure you don't include any instructions on the forms. Put this in the document that generates the form.
M Greenaway
Phil
I totally agree with this approach, and it is something I have argued for years.
Well done !
M Greenaway
Jim
A change to a form, such as you describe, is in effect a change to the process.
If we are changing a process shouldnt we do more than just update a document and fire it off into the unknown ?
Shouldnt there be some form of training following a process change ??
If we need to document our process wouldnt it be simpler and less beaurocratic to update our documented process description (whether it be procedure, flow chart or even PROCESS MAP).
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
R Does a Capital Expenditure Form need to be Controlled? Document Control Systems, Procedures, Forms and Templates 10
D Vendor (Supplier) Audit Form as a Controlled Form and as a Record Supplier Quality Assurance and other Supplier Issues 15
H Certification Form (C of C) - Must CofC forms be numbered and controlled? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
P Form Number for Master List of Controlled Documents - ISO 9001:2000 Document Control Systems, Procedures, Forms and Templates 8
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
T Controlled Forms or documented requirements for records? ISO 13485:2016 - Medical Device Quality Management Systems 2
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CS2 (Controlled Shipping Level) by GM - CB notified. What about other customers? IATF 16949 - Automotive Quality Systems Standard 1
R Digital Storage of ITAR Controlled Documentation Other ISO and International Standards and European Regulations 7
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
C Need examples for Controlled Shipping I and II (CSL) IATF 16949 - Automotive Quality Systems Standard 3
D Should Customer Drawings be controlled per AS9100 QMS ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Types of Controlled Documentation - Call Lists of Emergency Contacts Quality Manager and Management Related Issues 5
C Use of white-out or obliterating a portion of a controlled drawing or document Document Control Systems, Procedures, Forms and Templates 7
M Should spreadsheets be controlled? If so, how? Records and Data - Quality, Legal and Other Evidence 8
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
Q Modification in Controlled Documents AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
A Clean Room as a Controlled Environment - Requirements ISO 13485:2016 - Medical Device Quality Management Systems 12
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
