Controlled Forms or documented requirements for records?
ThatSinc
Hi All,
Looking for some guidance on forms, specifically with regards to review of customer requirements 7.2.2 and control of documents 4.2.4
The devices being sold are configured and have multiple options available.
Currently the sales order process uses "quote master templates" that include each product option with its associated price.
These are required for each customer enquiry and the resulting quote is sent back to the customer for review and approval, and then this becomes the record of the review of customer requirements.
These forms are not controlled in accordance with 4.2.4, they are updated as prices change and as new options become available with no identification of the date of revision, and previous copies are overwritten.
The company is small and only one person performs the sales process
Whilst I appreciate that nowhere in 7.2 states that a procedure is required, the sales order procedure doesn't include reference to use of these quote masters, only that a final acknowledgement of the order must be provided once customer requirements are confirmed and accepted.
My questions are;
1. would you consider these templates "documents required by the quality system" - and thus subject to control as per 4.2.4?
2. would it be acceptable to document (in a procedure or otherwise) what the minimum requirements are for the record of the review and then the quote master itself becomes irrelevant as long as the record meets the documented requirements?
3. where 13485 doesn't require a procedure for any of the customer related processes in 7.2, I've never seen anywhere that doesn't document a sales order process - is there a better way?
I'm moving from a company that had 1,001 controlled forms for everything, so trying to avoid creating new forms where they're not strictly necessary.
Thanks all,
TS.
John C. Abnet
Teacher, sensei, kennari
Good day @ThatSinc ;
The short answer is a question....
What does your organization need to ensure the intended results?
Consider a principle I coined years ago, which I call the "WRONG or GONE" principle.
If the document/information is WRONG or GONE, can it lead to a nonconformity? If yes, then what controls are necessary to prevent the nonconformity?
Regardless, be selfish. It is YOUR organization's QMS.
Hope this helps.
Be well.
ThatSinc
Hi John,
I like that approach, and at this time the process kind of sits in the middle of both potentially leading to an NC.
The appearance of the quote isn't important to quality, it could be written on the back of a napkin as long as it has the right information; quote number, parts lists as per approved parts drawings, prices, any other customer requirements, approvals. Therefore the form isn't important and the sales process could simply require these things to be documented.
However the approved parts lists are not referred back to each time to verify, these parts lists are pre-filled onto the forms for ease of use. If the parts are wrong on the form, and it gets approved and goes to production as a build order, which is simply the approved quote with prices removed, then there's a problem.
Thanks for the help.
TS.
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Controlled Forms Conundrum Document Control Systems, Procedures, Forms and Templates 2
E What forms should be controlled? Vacation, sick leave, employee evaluations, etc? Document Control Systems, Procedures, Forms and Templates 10
R Do generic forms bought over the counter need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
I Controlled Dynamic Forms vs. Fixed Forms US Food and Drug Administration (FDA) 3
T Control of Forms - Do forms need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 64
P Should Forms printed for daily use in the shop floor be controlled documents? Document Control Systems, Procedures, Forms and Templates 16
H Certification Form (C of C) - Must CofC forms be numbered and controlled? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 13
S ISO 9001 and Controlled Forms Document Control Systems, Procedures, Forms and Templates 4
W Controlled vs. For Reference Only - Forms which don't need control? Document Control Systems, Procedures, Forms and Templates 6
J Having to say about controlled documents on forms,WI,and procedures ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
F Controlled Forms - To what extent do forms need to be controlled? Document Control Systems, Procedures, Forms and Templates 41
D Controlled Documents and Records - Overdue NCR/CAR Forms QS-9000 - American Automotive Manufacturers Standard 8
J Supplier Controlled Shipping (GM CS1) Condition Manufacturing and Related Processes 3
was named killer AS 9100D - Calibration Instructions - Controlled documents? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
B Do IFU designs have to be document controlled under ISO 13485? Document Control Systems, Procedures, Forms and Templates 2
C Certificate of Conformance Form - COC for each customer a controlled document? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
qualprod Controlled sticker for product identification? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Defect codes and process codes need to be controlled AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
P Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
L Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CS2 (Controlled Shipping Level) by GM - CB notified. What about other customers? IATF 16949 - Automotive Quality Systems Standard 1
R Digital Storage of ITAR Controlled Documentation Other ISO and International Standards and European Regulations 7
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
C Need examples for Controlled Shipping I and II (CSL) IATF 16949 - Automotive Quality Systems Standard 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
D Should Customer Drawings be controlled per AS9100 QMS ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
