Controlled sticker for product identification?
qualprod
Hi everybody.
Please give a comment in this case.
For the identification of a product (for traceability) we use a little sticker 3x2 inches,onto the product, includes product code, work order number, date, process receiving, and next process.
The question is, should this sticker be controlled? I mean , a form with it's code and revision? And under control of documents?
What are the pros and cons of using it
Without control?
John Predmore
My answer depends on what is the purpose of the sticker.
If the purpose is Traceability, and traceability is required, then section 8.5.2 Identification and Traceability applies...
"The organization shall control the unique identification of the outputs when traceability is a requirement, and shall retain the documented information necessary to enable traceability. " [emphasis added here]
I interpret this to include serial numbers or lot/batch information (information Qualprod did not explicitly mention, but other readers look for guidance in these responses, too).
If the sticker indicates acceptance authority to proceed to the next step, some quality systems require more control. For example, in aerospace AS9100, 8.5.2 contains the additional clause "When acceptance authority media are used (e.g., stamps, electronic signatures, passwords), the organization shall establish controls for the media. " This added measure is intended to prevent an unauthorized person from marking suspect or untested parts as passed.
qualprod
It will depend on your procedure for controlling documents. The standard does not specifically require assigning of codes or indicating revisions on forms.
My procedure is only for documents, but don't you think a sticker (form) should have a control of document, to ensure this sticker be controlled if changes occur? If such form includes data like: tag number, client number, work order, name of process,etc.
The idea is that all people who need the sticker, always use the one which is under control (name of form and revision).
Sticker for this purpose, how Is managed by others ?
Please help.
Golfman25
I would resist "controlling" the sticker as it can get too complicated. We use tags - probably 500 a month. They simply hang on the part container and move along with the parts for identification. When the parts are complete, the tags are tossed as they serve no other purpose.
qualprod
thanks to all,
Hey John, I wonder why the standard states "when traceability is a requirement", what should we do about this, because even when is not a requirement of customers we usually apply practices of traceability, use of stickers with data. marks on some parts and so on.
why is like that?
On the other hand the stickers I refer to are used only to identify product into the processes, is not a release of acceptance.
What I conclude from other guys regarding to assign a control of a sticker (control of form, name and revision), such control is not needed.
As additional information, Into my procedures I mention that stickers have to be added to product to help the identification, but not I dont mention code name of the sticker.
Hope this help to clear up my case.
L Can a sticker be a controlled document? Document Control Systems, Procedures, Forms and Templates 24
J Controlled information versus defined documents / records ISO 13485:2016 - Medical Device Quality Management Systems 3
D Controlled Environment requirements Miscellaneous Environmental Standards and EMS Related Discussions 1
C Work Instructions; Controlled/Uncontrolled? Document Control Systems, Procedures, Forms and Templates 5
I Dating controlled documents after changes - Revision History Document Control Systems, Procedures, Forms and Templates 13
Q Do Management Review records have to be on a controlled form? ISO 13485:2016 - Medical Device Quality Management Systems 30
S Controlled Document Location Document Control Systems, Procedures, Forms and Templates 3
GreatNate Document Control info - What is required on a controlled form/document for ISO 9001: 2015? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
G Defect codes and process codes need to be controlled AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
M How to calculate benefits? Moving some developed non controlled software/automation systems Service Industry Specific Topics 2
I R&D prototype documents need to be controlled? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
K Work Order Form (Controlled Document)? Document Control Systems, Procedures, Forms and Templates 5
M Training template - controlled document? Document Control Systems, Procedures, Forms and Templates 21
D Controlled Documents & Note Making ISO 13485:2016 - Medical Device Quality Management Systems 4
pammesue Controlled Setup Sheets for a production line Document Control Systems, Procedures, Forms and Templates 2
P Qualification of a Temperature Controlled Unit have to be empty? Qualification and Validation (including 21 CFR Part 11) 5
M ISO 14644 - Cleanrooms and associated controlled environments -Recovery Test Other ISO and International Standards and European Regulations 0
E Do all Controlled Document copies require a Stamp? Document Control Systems, Procedures, Forms and Templates 3
Uriel Alejandro Including "Internal Rules" as Controlled Documents in a QMS Document Control Systems, Procedures, Forms and Templates 7
J Employer Warning Notice a Controlled Document? Document Control Systems, Procedures, Forms and Templates 7
R How to Cross-Reference Controlled Documents Document Control Systems, Procedures, Forms and Templates 3
C Leveraging previous results in IQOQs - Environmentally Controlled Room 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
R FAI (First Article Inspection) on source-controlled parts AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 5
M Definition of a controlled document --> is a form a controlled document Document Control Systems, Procedures, Forms and Templates 14
P Employment Application Form - Controlled or Not? Document Control Systems, Procedures, Forms and Templates 3
LeonelAguilar352 Specific Question about Printing Controlled Documents. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
T Controlled Forms - Centralized or Decentralized? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
S CS2 (Controlled Shipping Level) by GM - CB notified. What about other customers? IATF 16949 - Automotive Quality Systems Standard 1
R Digital Storage of ITAR Controlled Documentation Other ISO and International Standards and European Regulations 7
N Do Material MSDS's Need To Be Controlled? Document Control Systems, Procedures, Forms and Templates 3
C Need examples for Controlled Shipping I and II (CSL) IATF 16949 - Automotive Quality Systems Standard 3
S Is a Dynamic Controlled Form acceptable per 21CFR820 Document Control Systems, Procedures, Forms and Templates 3
T Should a supplier self assessment form be a controlled document? Document Control Systems, Procedures, Forms and Templates 9
D Should Customer Drawings be controlled per AS9100 QMS ? AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 3
M Types of Controlled Documentation - Call Lists of Emergency Contacts Quality Manager and Management Related Issues 5
C Use of white-out or obliterating a portion of a controlled drawing or document Document Control Systems, Procedures, Forms and Templates 7
M Should spreadsheets be controlled? If so, how? Records and Data - Quality, Legal and Other Evidence 8
C Control of Records - Differences between Controlled Documents and Controlled Records Records and Data - Quality, Legal and Other Evidence 18
Q Modification in Controlled Documents AS9100, IAQG 9100, Nadcap and related Aerospace Standards and Requirements 4
A Clean Room as a Controlled Environment - Requirements ISO 13485:2016 - Medical Device Quality Management Systems 12
J Employee Contracts : Controlled and Uncontrolled Documents Document Control Systems, Procedures, Forms and Templates 6
C Controlled Forms Conundrum Document Control Systems, Procedures, Forms and Templates 2
S Cleanliness Requirements for Raw Materials Used in a Controlled Environment Quality Manager and Management Related Issues 4
R Part Prints - Controlled and Uncontrolled Documents (e.g.: The Production Floor) Document Control Systems, Procedures, Forms and Templates 13
L Are ISO/TS Registrars also controlled or governed by ISO17021:2011? IATF 16949 - Automotive Quality Systems Standard 3
N Controlled Document Binders on the Production Floor Document Control Systems, Procedures, Forms and Templates 3
F ISO 9001:2008 Fundamentals: Basic Questions - Controlled Documents ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
I Controlled Environment Classification Qualification and Validation (including 21 CFR Part 11) 1
K Medical Application Classification in Controlled/Uncontrolled by Mobile App State. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 6
A Do controlled documents require a signature on every page as per 21 CFR 820.40? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 5
