Controlling Temperature and Time - Do I need to calibrate the thermostat?
mjoakin
This is for a car, we glue together plastic and foam using an adhesive that activates at 70ºC during 2.5 mins. We bought a pizza oven like. It got a thermostat and a dial to control the running band goes to 2.5 mins.
Do I need to calibrate the thermostat by a third lab? we used a turkey thermometer, we put the oven at 70ºC, the liquid screen of the oven says 70ºC but the turkey thermometer marked 50-55 ºC, so we increased the dial to (don't remember) let's say 85ºc and then we put the turkey thermometer by 2.5 and we got the 70ºC we needed. So I guess I can have a thermometer to "calibrate" or "verify" the oven and I'll meet requirements? I think calibrating the oven's therm is more expensive. But anyway, do I NEED to have a thermometer calibrated by and approved lab? is a MUST according TS?
BradM
Hi there!
I'm not sure about the TS requirement aspect. However, if I understand what you are doing...
You are using a thermometer to verify the product is reaching the desired temperature. Is the thermometer calibrated?
If you are using the thermometer to monitor the process, then I would think the oven temperature indicator is not used for monitoring/etc.
However, you mentioned 2 1/2 minutes for the process. Is that a critical exposure time? If so, you might want to perform some verification of the timing device used.
qusys
Is this control done to measure a special characteristic parameter reported in
the control plan? If so, I think , it shall calibrate it.
ISO TS does not tell you what to calibrate of not. It is just question of 7.6 of ISO 9001 where there are reported the rquirements to be meet for Monitoring and measurement devices:bigwave:
mjoakin
Well, it does not appear in customer requirements as a special characteristic, but the adhesive specs (specially manufactured for this customer and this very process) states it needs to be activated at 70ºC per 2.5 mins, now TS says "control that process", ok I will take measurements of the oven 3 times @ day ... with ... a calibrated equipment to certify oven temperature is ok ... now it became an issue, some parts at our customer's started delaminating ... cause? adhesive not activated correctly (not proper cure time was the customer's veredict) ... so I guess the answer to my question was pretty obvious
All I want is to cover my back, in my next TS audit if auditor asks "how do you verify the oven is correct" then I'll show him my turkey thermometer, he will ask "how do you know this measures the temperature correctly?" ... then I can show the calibration made by a certified lab ...
mjoakin
Hi there!
don't wanna use the oven's temp indicator for one reason: I can put the thermometer inside a UPS envelope and send it to a lab for a calibration, that's cheaper than hiring a Lab to come to my facilities to calibrate my oven's temp control / indicator / thermostat ... etc and stick a "calibrated" tag to the equipment ...
J Controlling Temperature and Humidity in the CMM Room and does anyone use Artifacts? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
R Controlling Quick Reaction Checklists Document Control Systems, Procedures, Forms and Templates 1
C Identifying and Controlling External Documents Document Control Systems, Procedures, Forms and Templates 3
qualprod Controlling documents in two different Applications ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M AS9100d Controlling External Provided Processes (purchasing 8.4) - The customer want us to use supplier X AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
qualprod Minor non-conformance for not controlling local regulation laws? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 20
Q Controlling Multi-Tab Microsoft Excel Forms Excel .xls Spreadsheet Templates and Tools 5
C Controlling Software Versions that are part of a medical device IEC 62304 - Medical Device Software Life Cycle Processes 2
A ISO 13485 - Controlling Production and Service Provision - Product Catalogues ISO 13485:2016 - Medical Device Quality Management Systems 3
M Difficulties Controlling Foreign Suppliers Supplier Quality Assurance and other Supplier Issues 8
R OHSAS 18001:2007 Section 3 - Controlling Work Place Risks Occupational Health & Safety Management Standards 3
T Controlling an Excel Spreadsheet (Database) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
C ISO 9001:2008 4.2.3(f) - Controlling Documents of External Origin Quality Manager and Management Related Issues 9
M Controlling Flow Charts that are hung in workplace. Quality Manager and Management Related Issues 6
N Controlling Records query that may cause some serious trouble for me ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
T Controlling Manual - Control of 10 Printed Manuals throughout our 9 Branches Document Control Systems, Procedures, Forms and Templates 8
Fender1 Controlling Documents and Records in a Custom Weld/Fabrication Company Document Control Systems, Procedures, Forms and Templates 10
C Tool Monitoring - Controlling a Process with Better Tool Monitoring Manufacturing and Related Processes 4
C Controlling QMS - We are expanding globally and want to keep our QMS Confidential Quality Manager and Management Related Issues 20
C Controlling Documents: Beyond the standard, how do we truly define what to control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
R Referencing and Controlling Labels & Stickers used internally throughout Production Document Control Systems, Procedures, Forms and Templates 1
Q Controlling Prints in Shop - Audit Finding Question ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
L Controlling "Stamps" used throughout our processing Records and Data - Quality, Legal and Other Evidence 16
T Requirements - Controlling and Maintaining Sheet Metal Templates for Production Use ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
P Controlling Solidworks model, CAD & Gerber files Document Control Systems, Procedures, Forms and Templates 3
M Defining and Controlling External Documents (Documents of External Origin) Quality Tools, Improvement and Analysis 5
S Controlling Documentation - Which procedures to control Document Control Systems, Procedures, Forms and Templates 12
C HACCP in Egg Production - Controlling hazards at the farm level Food Safety - ISO 22000, HACCP (21 CFR 120) 6
M Controlling Data Labels on Graphs - Number of Decimal Places Reported - Minitab Using Minitab Software 7
I Controlling Minitab by vba (visual basic) or vb Using Minitab Software 6
T Procedure for "Controlling Nonconformity" for a software company Document Control Systems, Procedures, Forms and Templates 2
R Controlling and monitoring of measuring devices - AS9100 General Measurement Device and Calibration Topics 3
D Establishing and controlling process capability - Meaning of Phrases Capability, Accuracy and Stability - Processes, Machines, etc. 2
E Controlling CNC Machine Programs - Your recommendations appreciated Manufacturing and Related Processes 12
T Controlling filled out "forms" (eg Operator job specific work instructions) Document Control Systems, Procedures, Forms and Templates 3
B Controlling Reference Material Document Control Systems, Procedures, Forms and Templates 1
R Procedure for Controlling Transmitted Technical Data - ITAR compliance Document Control Systems, Procedures, Forms and Templates 18
S Identifying and Controlling External Documents Document Control Systems, Procedures, Forms and Templates 8
Raffy Controlling Handler, Tester, Computer and other Equipment Manuals. Document Control Systems, Procedures, Forms and Templates 2
H Controlling Continuously Changing Forms IATF 16949 - Automotive Quality Systems Standard 12
W Controlling Revisions of External Documents - Documents of External Origin Document Control Systems, Procedures, Forms and Templates 10
A Controlling Humidity in a Textile Testing Laboratory General Measurement Device and Calibration Topics 10
M Polyurethane Foam Testing and Controlling the Foaming Process Manufacturing and Related Processes 6
G Controlling a male 6% Luer with permanent collar according to EN1707? General Measurement Device and Calibration Topics 5
C Controlling External Customer Documents (Documents of External Origin) Document Control Systems, Procedures, Forms and Templates 5
L "Document Controlling" Queries run to obtain information reported to customer Document Control Systems, Procedures, Forms and Templates 7
A Still Confused About "Controlling Suppliers Records" AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Controlling the records of suppliers - AS9100 Rev B Clause 4.2.4 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
S Controlling external processes - Alternatives ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
