Convert Class B Medical Device to Class A
W
wally4u
Hi everybody,
We have a simple medical device where small electric currents are generated.
Due to the nature of the device, delivering electric currents to a user, it's possible to cause skin irritation when used incorrectly. The software embedded in the device actively prevents this.
The way I read the IEC 62304 software classifications ANY injury (irritation/brusing/burns/etc) will cause the system be class B. So when the software has a runaway process the safety features could not function properly. I prefer not to have to write all the class B documentation. So I would like to classify the device as Class A.
I was wondering if a hardware watchdog (either internal to the MCU or external hardware) would be sufficient to guarantee that the software is properly running with the software safety measure active (not a runaway process), and thus allowing for Class A.
Any ideas if this would be acceptable?
glork98
I gotta say "no."
How about the software is just wrong? Sounds to me like you've got a Class B product and need to show that it won't hurt people and that the safety is proven to a high level of confidence.
W
wally4u
Hi Glork98,
So basically what your saying that using a watchdog that trigger the device to go into a "safe state" when it isn't activated once in a while (only possible when the software has gone bad) isn't sufficient?
My main issue is that one of the safety features is implemented in software, and I need to make sure that is still active. Section 4.3 notes:
If the HAZARD could arise from a failure of the SOFTWARE SYSTEM to behave as specified, the probability of such failure shall be assumed to be 100 percent.
If the RISKof death or SERIOUS INJURYarising from a software failure is subsequently
reduced to an acceptable level (as defined by ISO 14971) by a hardware RISK CONTROL measure, either by reducing the consequences of the failure or by reducing the probability of death or SERIOUS INJURYarising from that failure, the software safety classification may be reduced from C to B; and if the RISKof non-SERIOUS INJURYarising from a software failure is similarly reduced to an acceptable level by a hardware RISK CONTROL measure, the software safety classification may be reduced from B to A.
So wouldn't a hardware watchdog count as a risk control measure? Since it will guarantee that either the safety feature is active or the device is set to save mode by hardware.
On a side note, do you agree with me on the assumption that ANY injury (irritation/brusing/burns/etc) will cause the system be class B?
Or should I just have to document the safety features as class B and the rest of the device as class B (or does that depend on how good I can partion the device in software items?)
glork98
You need to show that it is mitigating the only possible failure mode. My experience is that software can fail to operate correctly in many (many, many) ways. This includes a failure to detect and mitigate hardware faults.
That's what B is: ability to injure.
If you're getting a splitting the code into A and B then, yes, that's something that's done a lot. The critical control code can be B while file output or UI display stuff is A. If the operator can enter settings or configuration data is read then that becomes B, too, as a mistake will propagate into the control code. Also, bad pointers or stack overruns and other failures that have unintentional side effects push code on shared processors into B.
It's hard to quantify all the situations and cases. That's what 62304 calls for. Do an architecture and then do a hazard analysis and see what comes out of it. Since your product can produce an injury you need to follow that path.
W
wally4u
Thanks for the info. So basically section 4.3 doesn't apply since the device itself is a Class B system.
N Convert Class A Software to B by on-chip Watchdog IEC 62304 - Medical Device Software Life Cycle Processes 5
A Tubing Clog Tester - Convert from Air Bubble to Flow Rate Reliability Analysis - Predictions, Testing and Standards 1
B Need to convert Reference Only M&TE to a calibration schedule General Measurement Device and Calibration Topics 3
N How to Convert Micro Volts into Temperature Uncertainty Measurement Uncertainty (MU) 1
W In what format do you convert documents to digital form? Document Control Systems, Procedures, Forms and Templates 10
J How to convert Rougness Rmax=6,3S to micrometers General Measurement Device and Calibration Topics 4
F How to convert inches to degrees - Inspecting the perpendicularity of 2 lines Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
K How do you convert Subjective Data into Numerical Data? Preventive Action and Continuous Improvement 11
B Process Approach - Convert System of Documentation into System of Managed Processes Misc. Quality Assurance and Business Systems Related Topics 2
AnaMariaVR2 How do I convert an .ASHX file to a pdf or MS PPT file? After Work and Weekend Discussion Topics 11
S Is it possible to convert a gas turbine to a diesel turbine? Manufacturing and Related Processes 10
B Timeframe to Convert to AS9100 from ISO9001 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 7
L AS9100 in Japan convert from JISQ 9100 to AS9100 consultant needed AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
M Minitab Macro-Command 'NUMERIC' to convert a text column to an numeric column Using Minitab Software 8
R Please help me to convert from ISO9001 to ISO13485 ISO 13485:2016 - Medical Device Quality Management Systems 10
eternal_atlas Quality Objectives - Convert these objectives into "SMART" format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q How do I convert inches of mercury to pounds per foot Inspection, Prints (Drawings), Testing, Sampling and Related Topics 13
P How to convert angle measurement given in degree to degree/Minutes/Seconds? Inspection, Prints (Drawings), Testing, Sampling and Related Topics 2
J Six Sigma chart - How do I convert a database into a chart with binomial distribution Quality Tools, Improvement and Analysis 1
M Efficient approach to convert Quality System from ISO 13485:2000 to ISO 13485:2003 ISO 13485:2016 - Medical Device Quality Management Systems 3
C API Q1 Quality Manual Example - Trying to convert an existing ISO 9001 QMS Oil and Gas Industry Standards and Regulations 30
Q 6 Weeks to convert from QS-9000 TE Supplement to ISO 9001:2000 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
C Convert Dewpoint Temperature specification to RH (Relative Humidity) General Measurement Device and Calibration Topics 2
Casana Distributors cannot convert to TS? IATF 16949 - Automotive Quality Systems Standard 2
J How to convert an unbeliever - Dinged for insufficient documentation by our registrar Document Control Systems, Procedures, Forms and Templates 16
shimonv Clinical evaluation report for class I device EU Medical Device Regulations 3
D Control Number for Class III and IV devices Canada Medical Device Regulations 0
M Class II type machine , and its compliance with 60601-1 IEC 60601 - Medical Electrical Equipment Safety Standards Series 14
A Clinical assessment sample size - Medical device Class IIb implantable (93/42 directive) EU Medical Device Regulations 2
P ISO 14644 Class 8 Cleanroom Air Filter Requirements Other Medical Device Related Standards 4
J Instructions for use for Class I devices under MDR EU Medical Device Regulations 1
D Electrical Medical Devices class I EU Medical Device Regulations 0
K MDR Class 1 Self Certification - Competent Authority or Notified Body? EU Medical Device Regulations 6
K "World Class Product" based QM. I need advice. Quality Management System (QMS) Manuals 14
L Class IIb devices marked EC according to the 93/42/CE - Portugal CE Marking (Conformité Européene) / CB Scheme 3
J Biocompatbility testing on Class 1 device requirements Other US Medical Device Regulations 12
J Reusable surgical Instrument is under class IIa? EU Medical Device Regulations 4
H EU CE marking for Medical Device Class I EU Medical Device Regulations 2
E Any sample of a full software life cycle IEC 62304 report ( any class )? IEC 62304 - Medical Device Software Life Cycle Processes 1
JoCam Certified QMS for MDR - Class I medical device manufacturers EU Medical Device Regulations 4
K CE Marking Class 1 (Non sterile) medical device CE Marking (Conformité Européene) / CB Scheme 3
G Voluntary Class I Device Filing Other US Medical Device Regulations 4
J IEC 60601-1-11 Home Class II With Ballasts IEC 60601 - Medical Electrical Equipment Safety Standards Series 3
A ISO 13485 for Class 1 Medical Device ISO 13485:2016 - Medical Device Quality Management Systems 7
N Validating Software before getting approved as Class 2 device US Food and Drug Administration (FDA) 5
D Can a diagnostic device be class I? EU Medical Device Regulations 1
A AMSQQP416E Class 2 type 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 0
S IVD risk class II devices for Brazil and MDSAP Other Medical Device Regulations World-Wide 0
