Converting an ISO Class 8 Cleanroom to ISO 7
TheBigChill
Hi there,
I'm not quite sure that this is the best place to ask this but, as a recently appointed "Cleanroom Coordinator", I've been tasked with implementing an ISO 7 clean-space within our existing ISO 8 cleanroom.
Our customer is requesting that their product be built in an ISO 7 clean-space, and I'm currently weighing different options regarding how I can implement this. Below are my options, ordered from most to least preferred.
Options:
1) Re-work existing ISO 8 cleanroom to ISO 7 level. (What's involved?)
2) Install modular IS0 7 softwall cleanroom in existing ISO 8 area (encompassing project specific tooling and workspace).
3) Install vertical laminar flowhoods over the project specifictooling and workspaces.
In terms of particle counts, we actually monitor data daily, and with the exception of 5 micron particles we are well within ISO 7 limits. Should I be looking more at better gowning and operator contamination controls, or a better cleaning protocol? Basically, that 5 micron count is all that's keeping us from being ISO 7.
We currently don:
-Bouffant caps.
-Beard covers.
-Washable ESD frocks.
-Disposable ESD cleanroom gloves.
HEPA Coverage:
-5 HEPAS providing ~10% ceiling coverage.
Air changes will be calculated shorty, but I'm fairly certain even those already meet ISO 7, or can with some tweaking of fan speeds and air handler damper adjustments.
Perhaps making shoe covers and sleeve guards (we have a cuff exposure issue) mandatory, that will help.
Thoughts?
MIREGMGR
Re: Converting an ISO 8 Cleanroom to ISO 7
What does your count data tell you about sources of particles? I.e., if the room has less of a 5 micron issue with systems running but no persons working; or less of an issue with persons working but not circulating; or with some kinds of work-activity/products compared to others; or in parts of the room where particular activity occurs or a particular source may be concentrated. That should point toward what to change first if you choose to bring the whole room to 7.
Is the cheapest solution the one that will be chosen? If so, I assume that the cheaper of the modular and hoods ideas would determine the cost threshold for whole room modifications. Does it seem plausible that the cost of whole room upgrades could fit within that budget?
BradM
Miregmgr points are sound.:agree1: Basically you need to determine what the cleanroom (irrespective of people and activities) is capable of reproducing.
I've seen situations where clean suites are constructed to meet requirements two grades better than what they were currently classified at. I've also seen situations where the suites were barely passing their current desired specification.
I assume the HEPA filters are testing for downstream velocity and are acceptable. Also, I assume that differential pressures are acceptable.
So, if the room (at rest) can meet the specifications, then to your point, you will need to minimize the burden carried in/out of the room.
TheBigChill
Because particle counts for all sizes are within ISO 7 spec with the room "At Rest", that tells me that our biggest contamination burden is likely personnel. Shortly after a couple of people walk in the room ("In Use"), the 5 micron particle count goes outside ISO 7 spec, while all others stay in. Having said that, it's a bit perplexing as to why this happens, as we don all suggested and required apparel. Perhaps we need to look at upping our cleaning standards?
In terms of processes within the cleanroom that contribute to contamination, we use primarily hand tools and electronics test equipment, with three, slow rotating fixtures. I'd consider them pretty low contributors to contamination. Occasionally soldering takes place, and even with a elephant trunk sucking the smoke away, sometimes our particle counter goes nuts.
The cheapest option won't necessarily be the chosen option, but we do have an unused modular softwall cleanroom, and 4 HEPAs / FFUs that are currently unused and could be applied to the project. The issue with the modular softwall room is ceiling height; Our ISO 8 cleanroom has an 8' ceiling, and the top of the HEPAs for the softwall room are also around 8'. You must have 1' of clearance between HEPA ceiling outlets and HEPA inlets of hoods or modular cleanrooms.
Some Technical Data:
- 5% of our ceiling is HEPA filters (I misspoke earlier).
- We have 28 Air Changes / Hour.
- 60% Humidity and 69F temp.
- Room pressure differential is .08.
In order to convert to ISO 7, we'd have to add ~ 10 more HEPAs to achieve 16% ceiling coverage, and fine-tune the fan speeds on all units in order to achieve 40-60 Air Changes / Hour. (Based on Flanders Air cleanroom design guidelines.)
One thing I'm currently handling is our personnel and their bad habits of bringing paper, ESD cardboard, and other non-cleanroom approved material into the room. Additonally, we don't have a gowning room. People use the tacky mat outside the door, and gown-up in a corner near the entry door. This is also changing, as we're building a gowning room.
Thanks for the responses, guys, and any help is appreciated.
BradM
I wished all posters provided details like this. :agree1:
I couldn't imagine the 5 micron shooting up, and not the .5 micron. I agree with your statement about cleaning. Something (or somebody) is bringing in some nasty stuff.
Have you measured with increased gowning requirements in place?
Do you perform this work in flow hoods?
It's nice to have options. :D
Is that room differential to.. open (unclean air) that seems kind of low. I would like to see that up higher if possible. Now... if you were talking a cascade scenario and this was three tiers up, .08 may be all you can get. Are they going in and out of the door a lot? Is there a gown room leading in?
Um... maybe if I actually read everything, I could see your answers to my questions! :D:tg:
Personally, I think having a gown room will make a big difference. Since you already have this under Change Control and such, can you up the air flow in the clean room, up the air flow in the gown room, and then have cascading positive differentials? I think that would help a lot.
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Converting Manufacturing Drawings from a Contract Supplier ISO 13485:2016 - Medical Device Quality Management Systems 7
N Converting ETO Residual Limits from PPM to mg ISO 13485:2016 - Medical Device Quality Management Systems 6
P Converting DMF III into eCTD (Electronic Common Technical Document) Medical Information Technology, Medical Software and Health Informatics 4
N Converting Paper Records to Electronic Format Records Document Control Systems, Procedures, Forms and Templates 6
V Converting Newtons to Newton Meters APQP and PPAP 4
optomist1 Converting Defect Rate To Capability index Capability, Accuracy and Stability - Processes, Machines, etc. 11
B Conversion and Rounding Standard for converting metric to english and vice versa Other ISO and International Standards and European Regulations 4
A Converting 1-Sided Design Tolerance to a Bilateral Tolerance Statistical Analysis Tools, Techniques and SPC 8
D Converting to Electronic Document Control - Procedure Content ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
Stijloor Converting a Bear... Funny Stuff - Jokes and Humour 0
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Converting SOUP to "SOKP" ... IEC 62304 - Medical Device Software Life Cycle Processes 1
M Converting PowerPoint Presentations into MS Word Documents After Work and Weekend Discussion Topics 6
N Thermocouple Calibration - Digital Display vs. Converting the Millivolt into ?C General Measurement Device and Calibration Topics 8
R Converting Best Measurement (BMC) to Calibration & Measurement Capability (CMC) Nonconformance and Corrective Action 2
A Basic Math training - I.e. fractions converting from inches to mm, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I Converting mG(milli g's of acceleration) to dB(deciBel) Misc. Quality Assurance and Business Systems Related Topics 20
J Converting solid model formats for a Calypso CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Curve Surface Roughness Measurement & Converting Ra to Rz General Measurement Device and Calibration Topics 8
Sidney Vianna Converting PowerPoint presentations into video - software recommendations? After Work and Weekend Discussion Topics 12
A CMM Software Conversion - Converting from Zeiss/Calypso to Brown & sharpe PCDMIS Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
ScottK Learning about converting an AutoCAD .dwg to a .STEP file Manufacturing and Related Processes 5
B Converting from QS9000 to TS 16949 ... HOW? WHO? HOW MUCH? IATF 16949 - Automotive Quality Systems Standard 2
J Converting torque to pressure - One for the Math Folks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Converting ISO9001:1994 to new ISO9001:2000 - Transition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Converting to Process Audits - Seeking: Process Audit Form layout Process Audits and Layered Process Audits 4
J Table for converting Cp values into corresponding Capability % Statistical Analysis Tools, Techniques and SPC 1
J Converting DPMO to SIGMA - Seeking Forumula Statistical Analysis Tools, Techniques and SPC 16
S Need ISO 15189:2012 Documentation toolkit. Document Control Systems, Procedures, Forms and Templates 0
chris1price Archiving of paper records - ISO 9001 7.5.3.1b Records and Data - Quality, Legal and Other Evidence 4
M Transferring ISO 17025 from one company to another ISO 17025 related Discussions 1
D Common practices in ISO 9001 deployment ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
B ISO 17025:2017 risk management Risk Management Principles and Generic Guidelines 0
P Audit check for IT company (ISO 9001) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
M Label Making & Printing Standards ISO / ASTM ISO 13485:2016 - Medical Device Quality Management Systems 5
Sidney Vianna Interesting Discussion Should ISO 9004 be changed from a guidance standard to a requirements standard? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
Ed Panek ISO 13485:2016 Section 5.5.3 ISO 13485:2016 - Medical Device Quality Management Systems 3
Q Do these certificates of calibration meet ISO 9001 requirements for traceability to NIST? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 11
ebrahim QMS as per ISO 13485, Clause 4.2 Requirements for regulatory purposes for Medical Devices Authorized Representatives. ISO 13485:2016 - Medical Device Quality Management Systems 3
S ISO 2768-mk print call out Other ISO and International Standards and European Regulations 11
T ISO 17024, clauses 4.3.8. and 5.1.1. Other ISO and International Standards and European Regulations 4
C ISO 14001:2015 6.1.3 Compliance Obligations - Legal requirements monitoring ISO 14001:2015 Specific Discussions 0
D ISO 13485 scope (implantable) - Polymers for dental application EU Medical Device Regulations 9
W First time being audited (ISO 9001), asking for advice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
John C. Abnet ISO 26262 ISO 26262 - Road vehicles – Functional safety 3
Marc ISO 26262- Road vehicles – Functional safety ISO 26262 - Road vehicles – Functional safety 0
John C. Abnet ISO 26262 IATF 16949 - Automotive Quality Systems Standard 0
