Converting to Electronic Document Control - Procedure Content
sagai
#11
when you store on the intranet you simple can set up access rights, that's all, anyway.
The reason i think this subject deserve attention is more universal in my mind.
I think there is a very broadly accepted perception about the QMS is the QMS is ALL the processes and procedure, including EVERY bit of instruction has ever put into a document format.
I would caveat the kind readers and anticipators the fact what is written as regard to QMS in the standard:
4 Quality management system
4.1 General requirements
The organization shall establish, document, implement and maintain a quality management system and
maintain its effectiveness in accordance with the requirements of this International Standard.
I would like to point to the fact that the ONLY regulatory need is for QMS is to prove how the company work effectively in accordance with the Standard itself.
For example when we are talking about document control, all we have to do from the QMS prospective to address the requirements set in the Standard, nothing else.
Which folder you put in the intranet, how do you granulate the reviewer and approver roles, whether or not you find useful to have a named author, how do you manage the approval, reviewer workflows are NOT RELEVANT from this prospective.
So I am crazy to say it is not relevant to document how to handle the documents in an organization?
Actually I haven't said that :cool:
It does matter, but not from the QMS prospective. There can be practices, guidelines, specialized trainings in order to widespread this knowledge, but those are not mandated to be part of the QMS.
One more angle I would add to this subject.
Having more detail in the QMS than it is mandated in the Standard radically increasing the probability of running to non conformity in the course of an audit. And nevertheless anything is more than required by regulatory is an unnecessary burden on the organization, not to mention the fact that you have to maintain that QMS. Unnecessary burden is from the regulatory prospective, yes, there could be engineering or other reasons influencing the extent of the original scope of a process or procedure.
Cheers :bigwave:
mortby
#12
You've got the part where the organisation has to meet the requirements of the standard, but what about the part where the organisation has to meet the requirements of it's own business?
4.2.1d) The quality management system documentation shall include documents, including records, determined by the organisation to be necessary to ensure the effective planning, operation and control of its processes.
So, yes, potentially you increase the possibility of non-conformity by adding detail to your QMS, but you also decrease it by actually describing for your people what you want them to do and giving them a reference to work from.
It's a constant balancing act which is purely dependant on the needs of the business, with all the factors taken into account - culture, business maturity, system maturity, business changes etc.
Document control is however, one of the regulatory mandated procedures, so it should be detailed enough to answer the 'how do you...' question put in front of each of the lettered bullets in 4.2.3
sagai
#13
Where is the end of answering the question of "how do you"?
It can end up with a crazy QMS document telling which fingers are allowed to hit a particular key on the keyboard ...
I agree, it is a constant balancing, but I would warn anyone to consider all procedure in an organization as part of the QMS.
Actually, the paragraph you have mentioned for document control continues ... :cool:
NOTE 1 The extent of the quality management system documentation can differ from one organization to another
due to
a) the size of the organization and type of activities,
b) the complexity of processes and their interactions, and
c) the competence of personnel.
With other words, if you ensure that you have a trained and competent people, you do not have to include every bit of information into your QMS and it can be excluded from the scope of the QMS.
But sum it up, yes it is balancing, Cheers!
tori2432
#14
I just converted our document control system to paperless. I email out the document and the approver replys 'approved' then I save the approval in a folder. ALways have an electronic trail with rev, document number, date, changes and who approved it and when. Easy!
Stijloor
#15
Yep! Simple and user-friendly! :applause:
Too many "quality" management systems are bureaucratic...
Stijloor.
dsanabria
#17
I am putting our ISO 9001 & 14001 combined system into electronic format and doing away with printed manuals at our 30 Branch locations.
I am not clear on how my Document Control procedure should address this. Can anyone offer up a copy of a Document Control procedure for their electronic manual I can use as a starting point.
My main concerns are a document approval process since nothing will bear signatures.
Many Thanks,
Don't forget this one:
"g) to prevent the unintended use of obsolete documents, and to apply suitable identification to them if they are retained for any purpose."
Chance
#19
Many Thanks,
Just like many posters have mentioned, make it simple. Specify who has the authority to approve, and indicate how you control by saying that versions will change everythime there is a revision. Specify that you will summarize changes -wherever you want to and don't forget the approval date.
We utilize SharePoint for our approval process, and we activiate "Track Changes" during the review process. Then we create workflows for approval.
tori2432
#20
For us, when a document is updated, the change is in blue and italicized. Simple and straightforward. OBS documents are in an OBS folder. I have a database with all the documents listed, rev date/level and if they are active or not.
P Converting DMF III into eCTD (Electronic Common Technical Document) Medical Information Technology, Medical Software and Health Informatics 4
N Converting Paper Records to Electronic Format Records Document Control Systems, Procedures, Forms and Templates 6
S Converting SOP MDD to MDR Noob ISO 13485:2016 - Medical Device Quality Management Systems 4
Q Converting Manufacturing Drawings from a Contract Supplier ISO 13485:2016 - Medical Device Quality Management Systems 7
N Converting ETO Residual Limits from PPM to mg ISO 13485:2016 - Medical Device Quality Management Systems 6
T Converting an ISO Class 8 Cleanroom to ISO 7 Various Other Specifications, Standards, and related Requirements 4
V Converting Newtons to Newton Meters APQP and PPAP 4
optomist1 Converting Defect Rate To Capability index Capability, Accuracy and Stability - Processes, Machines, etc. 11
B Conversion and Rounding Standard for converting metric to english and vice versa Other ISO and International Standards and European Regulations 4
A Converting 1-Sided Design Tolerance to a Bilateral Tolerance Statistical Analysis Tools, Techniques and SPC 8
Stijloor Converting a Bear... Funny Stuff - Jokes and Humour 0
optomist1 ASME GD&T Certification Test - Converting Coordinate Tolerances to Profile Tolerances Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8
J Converting SOUP to "SOKP" ... IEC 62304 - Medical Device Software Life Cycle Processes 1
M Converting PowerPoint Presentations into MS Word Documents After Work and Weekend Discussion Topics 6
N Thermocouple Calibration - Digital Display vs. Converting the Millivolt into ?C General Measurement Device and Calibration Topics 8
R Converting Best Measurement (BMC) to Calibration & Measurement Capability (CMC) Nonconformance and Corrective Action 2
A Basic Math training - I.e. fractions converting from inches to mm, etc. ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 1
I Converting mG(milli g's of acceleration) to dB(deciBel) Misc. Quality Assurance and Business Systems Related Topics 20
J Converting solid model formats for a Calypso CMM Inspection, Prints (Drawings), Testing, Sampling and Related Topics 3
Q Curve Surface Roughness Measurement & Converting Ra to Rz General Measurement Device and Calibration Topics 8
Sidney Vianna Converting PowerPoint presentations into video - software recommendations? After Work and Weekend Discussion Topics 12
A CMM Software Conversion - Converting from Zeiss/Calypso to Brown & sharpe PCDMIS Inspection, Prints (Drawings), Testing, Sampling and Related Topics 7
ScottK Learning about converting an AutoCAD .dwg to a .STEP file Manufacturing and Related Processes 5
B Converting from QS9000 to TS 16949 ... HOW? WHO? HOW MUCH? IATF 16949 - Automotive Quality Systems Standard 2
J Converting torque to pressure - One for the Math Folks Inspection, Prints (Drawings), Testing, Sampling and Related Topics 4
M Converting ISO9001:1994 to new ISO9001:2000 - Transition ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
C Converting to Process Audits - Seeking: Process Audit Form layout Process Audits and Layered Process Audits 4
J Table for converting Cp values into corresponding Capability % Statistical Analysis Tools, Techniques and SPC 1
J Converting DPMO to SIGMA - Seeking Forumula Statistical Analysis Tools, Techniques and SPC 16
A Electronic forms QMS Document Control Systems, Procedures, Forms and Templates 7
S Reporting REACH - Electronic components distributor REACH and RoHS Conversations 5
K ISO 13485 and compliance of electronic signature ISO 13485:2016 - Medical Device Quality Management Systems 5
M MDR - eIFU - When you can supply an electronic IFU instead of a paper IFU EU Medical Device Regulations 5
D Advice on capturing electronic signatures ISO 13485:2016 - Medical Device Quality Management Systems 8
C Shelf life electronic components 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 2
C Cleaning of electronic transmitter Other Medical Device Related Standards 2
D Preservation of Electronic Data / Information Technology ISO 13485:2016 - Medical Device Quality Management Systems 5
Anonymous16-2 21 CFR Part 11 - Steps to take if we want to validate an electronic system Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 2
R Electronic and hand-written footnotes for GDP Document Control Systems, Procedures, Forms and Templates 1
A 21 CFR part 11 - section 11.100 - Electronic Signature Certification Other US Medical Device Regulations 6
qualprod From paper to Electronic (records) in the QMS ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
S FDA's E submitter - For clinical electronic thermometer Medical Device and FDA Regulations and Standards News 6
J Integrity of electronic digital records - Medical Devices ISO 13485:2016 - Medical Device Quality Management Systems 4
T Electronic ECO/ECR Process - Software recommendations Document Control Systems, Procedures, Forms and Templates 3
M Informational EU – DSVG 03 – Cardiac Implantable Electronic Devices (CIED) – Guidance on the vigilance system for CE-marked medical devices Medical Device and FDA Regulations and Standards News 0
D Benefits of electronic QMS software Software Quality Assurance 5
M Informational US FDA Draft Guidance – Providing Regulatory Submissions for Medical Devices in Electronic Format – Submissions Under Section 745A(b) of the Federal F Medical Device and FDA Regulations and Standards News 0
R Electronic handwritten signatures for approvals - Signed with a Stylus or a Finger Document Control Systems, Procedures, Forms and Templates 2
WEAVER Electronic Weighing Scale Calibration Tolerance Manufacturing and Related Processes 1
