Correct Sample Size for Attribute Gage R&R (Good / Bad parts)
L
liamtek
Hi to all,
Could someone help me to confirm the correct/estimated sample size used to do an Attribute GR&R?, this means, how many good / bad parts are needed?.
We need to develop an Attribute GR&R for an AOI (Automatic Optical Inspection).
Hope you can help.
Jim G
A common standard for a Continuous GR&R study is to use 10 parts, measured by 3 different people, 3 times each, giving you a total of 90 results.
For Attribute data GR&R studies more data is required (Due to Attribute data having less resolution) therefore at least 20 parts should be assessed at least 3 times by each appraiser giving 180 results.
You should also ensure your selection of parts includes some borderline products to challenge the abilitiy of the measurement system.
Hope this helps
Jim G
We learn more by looking for the answer to a question and not finding it than we do from learning the answer itself.--Lloyd Alexander
there are a couple of approaches for sample size that work for attribute (aka categorical) data guage R&R studies. The best approach is dependent on what you are trying to accomplish with the study.
Check out this attachement which details these approaches and the appropriate statistical analyses... Categorical Data MSA
...for what it's worth - I dont' recommend 'reading' each unti three times. twice is sufficient and ti allows you to increase your sampel size appropriately without increasing the amount of work the subjects have to do. This is particularly true for categorical data as most of the appropriate statistical tests are based on two readings for each unit and tehy get very complicated very fast when you increase the number of readings - without a corresponding increase in the usefulness of the data results.
Remember that a R&R study is trying to determine the measurement error, which is expressed in terms of the standard deviation. This standard deviation is from teh repeated measurements of a single unit. the improvement in the SD estimate of a sample of 2 to a sample size of 3 is negligable. However, increasing your unit sample size from 10 to 30 has a significant improvemetn in the estimate of the measurement error by virtue of using 30 sample SDs instead of 10 sample SDs...
L
liamtek
All the info you provided is good, but nobody answer my question, I will try to explain in a another way.
What I want to know is how many parts (good & Bad) I need in order to do an attribute GR&R?
Example:
I need to do a GR&R in the Automatic optical Inspection (AOI), this equipment is detecting the lack of electrical components, in order to do the GR&R, what is the standard quantity of good pcs & the standard quantity of bad pcs in order to do the GR&R, for example if we use 30 parts, how many parts needs to be good & how many neds to be bad parts?
Currently I'm selecting between 20 to 30 test samples that represent the full range of variation encountered in actual production runs. For maximum confidence, I'm using a 50-50 mix of good/bad parts but also a 30:70 ratio is acceptable. But I'm doing this according to my experience, but I need to know if there is something in a procedure, MSA, Customer requirements in order to ensure I'm following a standard sample.
Please advise, any comments are very welcome....
How many parts needs to be good & how many neds to be bad parts?
Sorry to respond so late -I got distracted.
There is no published 'valid' standard other than if you go to the formulas that calculate the statistical significance of 'disagreement' given a sample size. but this is probably far too complicated for what you are trying to do.
I have two basic approaches:
first I use a roughly 50:50 split with an over sampling of 'marginal' parts to test the instruments ability to discriminate in the marginal zone. (this is only diagnostic in helping me improve the discrimination IF I need it.) from this you could calcualte your false accept/reject rates IF you know the distribution of marginal devices to fully bad and fully good.
then I use a good:bad ratio that matches my current process, this way I can verify how many false rejections and false acceptances I will actually get. (this is the real purpose of the equipment...) This drives my sample size.
Englishman Abroad
All,
In the recently published Ford PPAP specifics there are some requirements for this;
Parts for Attribute Gauge R&R Study
25% of the parts should be near the lower specification limit (on both sides of the specification).
25% of the parts should be near the upper specification limit (on both sides of the specification).
30% of the parts should represent the expected process variation.
10% of the parts should be outside the upper gauge specification limit and beyond the 25% of the parts near the specification as described above.
10% of the parts should be outside the lower gauge specification limit and beyond the 25% of the parts near the specification as described above.
There is also a graph showing the distribution of these parts;
(See the IATF website Ford Customer Specific Requirements for PPAP, June 2013; Page 6 - sorry the web link was deleted)
Although only required by Ford, this provides good guidance for other customers in this complicated area.
While this provides some guidance it is not based on any statistical theory, or performance requirement ()false rejection or false acceptance). It is a generic test but the results may be meaningless depending on teh actual defect rate and the required accept/reject rate.
michellemmm
Quest For Quality
Hi to all,
Hope you can help.
I have numerous questions:
1- Why would you need to perform GR&R on an AOI equipment?
2- Do you have other alternatives than manual inspection or ICT?
ICT does not help in terms of component orientation or polarity. And if you don't have 100% coverage, you will have other problems....
3- Do you have several AOIs or just one?
4- What are you trying to determine/accomplish?
5- How old is your AOI?
6- How do you calibrate your AOI?
7- What are you going to do with the data?
Personally, the last thing I would do is GR&R on AOI.
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
U The Importance of Correct Sample Size Calculation - Greek Alphabet Soup Book, Video, Blog and Web Site Reviews and Recommendations 7
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
R How to determine the correct Sample Frequency for SPC Features Statistical Analysis Tools, Techniques and SPC 66
lanley liao How to correct this NC? Oil and Gas Industry Standards and Regulations 11
lanley liao How to correct these NCs? Oil and Gas Industry Standards and Regulations 4
lanley liao Would you helpe me that how to correct these NCRs? Oil and Gas Industry Standards and Regulations 6
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NANDO codes of products - These are not the GMDN codes, correct? EU Medical Device Regulations 4
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
S Definition MTBF and MCBF Correct Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
T What is the correct UMDNS Code for Tracheostomy Tube? Other Medical Device Regulations World-Wide 2
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
E Database search is correct to capture medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J TS 16949 - Which definition of Automotive is correct? IATF 16949 - Automotive Quality Systems Standard 3
R Correct Cable Ports After Work and Weekend Discussion Topics 2
S Is it gramatically correct to say Singapore people or Singaporeans ? Coffee Break and Water Cooler Discussions 12
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J MSA Emergency - PV%=100(PV/TOL)in American? And that is correct? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Are my Cpk and Cp Calculations Correct? Capability, Accuracy and Stability - Processes, Machines, etc. 4
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
T Correct use of NPT (National Pipe Thread) Thread Gages General Measurement Device and Calibration Topics 15
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
C Correct Tool for Gage R&R - Assay Dilutions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
