Correct use of NPT (National Pipe Thread) Thread Gages
Wayne
Gage Crib Worldwide
#11
I'm not familiar with the term convolution. But what does it mean in the thread gage community?
Another term for convolution is Higby Cut.
And a bigger question: Where can I find a stated requirement on convolution with tolerance? That word doesn't appear in B1.20.1.
It may be found in ANSI B1.20.5; which is the gages for NPTF. If it is the case that it is not in ANSI B1.20.1 then a case may be made to allow convolution or chamfer. I am still searching for this data. What I have learned is that gage convolution was added to the pipe gages in 1968 (but I am still trying to learn where in the standards it was added) I have heard that some gage makers use chamfer on NPT and others convolute. I have also discovered some disagreement between how the standard tolerances are applied to the gages (I do not want to get into detail here) which will affect the size of the gage and broaden the gage tolerance.
I do have access to ANSI B1.2:1983 (R2001) and in paragraph it states: B1.2%20ppg%204.1.10%20convolution.jpg
Wayne
Gage Crib Worldwide
#12
I am told that on page 16, in the last paragraph of paragraph 7.1.1 the convolution of NPT gages is addressed. I do not have a copy of this page, so I cannot confirm, but the person who told me should know.
Y
YankeePapa
#13
Wayne,
Thank you for all the excellent information.
The last paragraph of 7.1.1. reads "Partial end threads shall be removed on both ends of the ring gage and on the small end of the plug gage to full-form profile in order to avoid possible seating error from bent or malformed feathered edge."
As you can see, it's not as detailed as NPTF. PM me for a copy.
Have you ever seen a survey of measured L1 numbers for female threads across different manufacturers? I would think that the more expensive fittings mfrs would use this to show how their products meet spec and those of competitors often don't.
A general question, agree, disagree, or comment:
Threads on pipe nipples tend to be correct dimension because those are governed by taper angle and number of threads. The OD of the pipe is fairly tightly controlled, the taper angle doesn't change that much with tool wear, and the number of threads is plainly visible, so if it's wrong the product tends to get rejected with no measurement needed.
In contrast, female threads tend to be undersized (i.e. they have short L1's) because they have no reference dimension equivalent to pipe OD, and as long as they have all their threads, plus short hand-tight lengths in the field can be easily chalked up to dings and burrs. It pays for manufacturers to cut corners here because it's cheaper to leave the hole smaller and no one notices.
Thanks again, Wayne!
Wayne
Gage Crib Worldwide
#15
A general question, agree, disagree, or comment: <snip>
No comment. This is outside of my knowledge zone. :notme: I get involved in gages, but never use them on parts.
I am sure that others on the forum will have better input than me on this question. :D I will let them answer this from their expierence.
Marc
#16
<snip> A general question, agree, disagree, or comment:
Anyone here who can shed some light on this one?
G How to ensure dimension of tapping hole before plating is correct? Manufacturing and Related Processes 2
K AS9100 - 7.3 - Are these black and white questions with specific correct answers AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 1
E Correct way to certify hydrostatic testing when it is not 100% (and Sample Size) Various Other Specifications, Standards, and related Requirements 6
R What is the correct way to refer to NIST? Calibration Frequency (Interval) 4
M NANDO codes of products - These are not the GMDN codes, correct? EU Medical Device Regulations 4
K The correct way of doing a 2 Sample T test Reliability Analysis - Predictions, Testing and Standards 7
B PED 2014/68/EU - Is this Traceability audit finding correct? Other ISO and International Standards and European Regulations 4
K Assigning the Correct Procedures Applicable to Job Titles General Auditing Discussions 15
JoshuaFroud How important is using the "correct" GMDN? Other Medical Device Regulations World-Wide 14
M Specifications Aerospace - Who is responsible for providing the correct specification(s) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 14
supadrai OEM Changing the name of the manufacturer - length of process? Is 1-3 months correct? Other Medical Device Regulations World-Wide 0
J How long should I have to correct an audit finding? VDA Standards - Germany's Automotive Standards 7
E SPC for Dummies - The correct meaning of all the graphs Statistical Analysis Tools, Techniques and SPC 3
C UDI Label Verification - How do we ensure the barcode is correct and prove it? 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
N Correct reading for analog pressure gauge ISO 17025 related Discussions 2
J How to measure process quality? Is DPPM the correct metric? Capability, Accuracy and Stability - Processes, Machines, etc. 5
P The correct way to do a Linearity and Stability Study on a Critical Dimension Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 8
L Choosing the correct Distribution for Acceptance Sampling Inspection, Prints (Drawings), Testing, Sampling and Related Topics 19
A Safety Shoes & Temporary Workers - Is it correct to reuse again or not? Occupational Health & Safety Management Standards 11
S Definition MTBF and MCBF Correct Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 5
T What is the correct UMDNS Code for Tracheostomy Tube? Other Medical Device Regulations World-Wide 2
E Correct Statistical Test comparing 2 Groups Statistical Analysis Tools, Techniques and SPC 14
N What is the easiest way to verify we have the correct customer supplied materials? Misc. Quality Assurance and Business Systems Related Topics 5
D The correct way to analyze Skewed Data using Minitab Using Minitab Software 3
C Rolling the correct M8 1.25 Pin Thread Manufacturing and Related Processes 2
E Database search is correct to capture medical device ISO 13485:2016 - Medical Device Quality Management Systems 2
S Choosing the correct Elisa Test Food Safety - ISO 22000, HACCP (21 CFR 120) 1
J TS 16949 - Which definition of Automotive is correct? IATF 16949 - Automotive Quality Systems Standard 3
L Correct Sample Size for Attribute Gage R&R (Good / Bad parts) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
R Correct Cable Ports After Work and Weekend Discussion Topics 2
S Is it gramatically correct to say Singapore people or Singaporeans ? Coffee Break and Water Cooler Discussions 12
H Determining the Correct Sample Size when AQL points to two Sample Sizes AQL - Acceptable Quality Level 7
J How IAQG plans to ensure that correct PEAR level determination is done by Auditors? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
K AS9102 Form 3 for Assemblies - Verification that the Assembly is Correct AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
J MSA Emergency - PV%=100(PV/TOL)in American? And that is correct? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 13
F Can you tell me if this table is correct? Gage R&R Problems Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 12
T Is the following flow for Training Needs Analysis correct? Training - Internal, External, Online and Distance Learning 6
M Calculating Cp and Cpk - Is my calculation correct? Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Are my Cpk and Cp Calculations Correct? Capability, Accuracy and Stability - Processes, Machines, etc. 4
D What is the correct Working Standard for Digital Micrometer? General Measurement Device and Calibration Topics 21
R First Pass Yield - Am I doing correct the First Pass Yield Metric Quality Tools, Improvement and Analysis 2
C Correct Tool for Gage R&R - Assay Dilutions Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
B How to Correct Bad Employee Performance-Attendance and/or Tardiness Quality Manager and Management Related Issues 84
R How to determine the correct Sample Frequency for SPC Features Statistical Analysis Tools, Techniques and SPC 66
Q Latest ISO 9001:2008 Rev. E - Correct? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
bobdoering The CORRECT steps to implement an SPC chart Imported Legacy Blogs 16
E Orthographic Projection - Which view is correct? Coffee Break and Water Cooler Discussions 4
