Correction and Corrective Action - ALWAYS DOCUMENT BOTH
E
emanbocol
I've read a thread here in Elsmar explaining why at times you only need to indicate corrections on minor nonconformances/findings with no corrective actions needed.
We were about to adopt that in our QMS when, during our transition audit to ISO 9001:2008, the external auditor insisted that it cannot be just either (correction/corrective action) but should always be both. He pointed out that 8.2.2 states that "The management responsible for the area being audited SHALL ensure that any necessary corrections AND corrective actions are taken without undue delay...."
We had a long exchange of ideas in the interpretation of this statement, but I hope to know how the experts would interpret this?
Would surely appreciate.
Randy
Those with expertise don't interpret...we use the standards themselves and in this case ISO 9000:2005
3.6.5
corrective action
action to eliminate the cause of a detected nonconformity (3.6.2) or other undesirable situation
NOTE 1 There can be more than one cause for a nonconformity.
NOTE 2 Corrective action is taken to prevent recurrence whereas preventive action (3.6.4) is taken to prevent occurrence.
NOTE 3 There is a distinction between correction (3.6.6) and corrective action.
3.6.6
correction
action to eliminate a detected nonconformity (3.6.2)
NOTE 1 A correction can be made in conjunction with a corrective action (3.6.5).
NOTE 2 A correction can be, for example, rework (3.6.7) or regrade (3.6.8).
You have to both fix it and find the reason it happened in the 1st place.
U
Umang Vidyarthi
:bigwave: Hello emanbocol, welcome to the cove. :bigwave:
Randy has provided the definitions straight from the horse's mouth. While correction is an act of correcting a nonconformity (viz: by rework), the corrective action is an act to prevent its recurrence, in other words, attacking at the cause(s) of of the nonconformity.
8.2.2 says "The management...shall ensure....any necessary corrections and corrective actions are taken without undue delay....."
Here 'Necessary' is the catch word. It is the prerogative of the management to decide as to which is necessary and which is not. (Of course, the responsibility to show why 'unnecessary' is unnecessary, lies squarely with the management).
The other point raised by the auditor that in stead of either/or it has to be both, is a valid arguement. Equally (or even More) important than correction is corrective action to avoid recurrence.
Hope this helps
Umang :D
howste
Thaumaturge
I agree with Umang's response. While I believe in most cases doing both correction and corrective action is the best route to take, forcing both in ALL cases could be counter-productive.
If necessary what?
If necessary, sir.:tg:
You said (with regard to detected NCs):"You have to both fix it and find the reason it happened in the 1st place." I was pointing out (based on your quotation of ISO 9000, which those with expertise don't interpret) that you have to fix it and find the reason it happened if necessary.
E
emanbocol
Yup. The "necessary" word in 8.2.2 was actually my point of contention against the ALWAYS TOGETHER. It appears to me that there are times wherein you can omit correction and just go straight to corrective action (i have yet to see cases where you can have corrections with no need for corrective actions).
I hope i'm not risking a longer discussion here with this example:
If for example you are given an NC for not completing your forms well, would you need correction for that, that is, fill out completely those old forms that are no longer relevant?
howste
Thaumaturge
Let's say you have a document control procedure that does not address legibility. Would you spend a lot of time identifying why it was not addressed when the system was first implemented? Or would you just add controls to the procedure to address the missing information?
G
Geoff Withnell
In the past, with minor problems, I have put a statement into the corrective action area such as "As this problem does not appear to be a systematic or repetitive issue, further action is not warrented at this time. If this problem becomes repetitive or systematic, further action will be taken."
Geoff Withnell
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
Q Corrective Action Effectiveness also for correction? Nonconformance and Corrective Action 11
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
A Software Medical Device Bug Fixes: Correction or Corrective Action? Other US Medical Device Regulations 5
A Observations - Is Correction / Corrective Action a Must ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q Corrective Action - Disposition always Correction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M Definition Corrective Action vs. Correction: Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 18
S Correction vs. Corrective Action - Differences Nonconformance and Corrective Action 30
H Definition Correction vs. Corrective Action vs. Preventive Action Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
K Correction, Corrective Action, and Preventive Action differences - Internal Audits Internal Auditing 10
C Correction - Corrective Action - Preventive Action Nonconformance and Corrective Action 9
J 'Forms' vs 'Question' based Corrective Actions - Correction Action System at Toyota Nonconformance and Corrective Action 8
Q Process Correction vs. Corrective Action - Failure to React when Out of Control Nonconformance and Corrective Action 8
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Rework, Reprocess, or Correction - A simple blurred letter on the legible etching ISO 13485:2016 - Medical Device Quality Management Systems 4
G Correction fluid found on documents that are reviewed Qualification and Validation (including 21 CFR Part 11) 11
Q Correction of records - FAR or DFAR? Various Other Specifications, Standards, and related Requirements 3
A Who pays for correction and removal actions? Other Medical Device Regulations World-Wide 2
Uriel Alejandro Evaluation of the effectiveness of correction actions General Auditing Discussions 15
D Non ASTM Partial Immersion LGT emergent stem correction General Measurement Device and Calibration Topics 3
I EO sterilization out of specification and correction Other Medical Device Regulations World-Wide 1
Jane's When audit NC requires only correction ISO 13485:2016 - Medical Device Quality Management Systems 16
J Who can make a Correction of Entry on GMP Records Other Medical Device and Orthopedic Related Topics 1
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Medical Device Malfunction - Customer Complaint - Response vs. Correction Other US Medical Device Regulations 3
M Does there always have to be a "correction?" Problem Solving, Root Cause Fault and Failure Analysis 16
L Medical Device Reporting vs Recall/Correction: What action to take? US Food and Drug Administration (FDA) 5
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
A AS9100 and Record Correction Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Applying Correction Factors to Furnaces Manufacturing and Related Processes 5
M Calculation for Correction Deformation (Pitch Diameter) General Measurement Device and Calibration Topics 3
D Correction and Degree of Error - Metrology Definitions and Differences General Measurement Device and Calibration Topics 1
B How do I calculate Correction to Caliper Calibration Data General Measurement Device and Calibration Topics 4
Q Correction Action as Preventive Action at another Plant? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Correction and Removal - Include Device used in Non-Production Environment? US Food and Drug Administration (FDA) 5
B Recall vs. Field Correction - Field Corrections instead of a Recall US Food and Drug Administration (FDA) 25
S 3 Wire Pitch Dia. Method - Measuring Force Correction & Lechowski?s method General Measurement Device and Calibration Topics 1
D NLEC (Non-Linear Error Correction) vs. SLEC (Segmented Linear) Calibration Technique Calibration and Metrology Software and Hardware 3
F Zahn Cup Correction Chart - Boeing specification BSS 7234 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Medical Device Reporting procedure - Correction and Removal (21 CFR 806) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Can a non-conformance be closed with "correction"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
M What is the indication of "adjusted scale correction" to calibration of liq thermom.? General Measurement Device and Calibration Topics 5
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
Z Apogee V2.5 - No correction mapping unless I pay $8,000+ Software Quality Assurance 6
D FDA Requirements about using Correction Fluid on Documents and Records US Food and Drug Administration (FDA) 8
M CARs (correction action request) vs. NCMRs (nonconforming material report) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D On-site Calibration Environmental Control - Is there a correction factor? General Measurement Device and Calibration Topics 5
G MSA Manual Bias Calculation - Why is the d2* correction factor needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
