Correction of records - FAR or DFAR?
Is anyone aware of a FAR or DFAR which specifies requirements for making record corrections? i.e., don't use correcting fluid, use a single line, sign & date - that sort of thing.
I tried doing a search both on the interwebs and here within the Cove but had zero success at finding anything on this topic. In the past, companies I have worked for had command media specifying the process of record corrections but I'm looking to learn if there was a FAR/DFAR driving that internal requirement.
Thanks!!!
Al Rosen
There is no single rule that states directly "whiteout may not be used", but the requirement can be found throughout the regulations indirectly. Look at 21cfr122.5 for example. Correction of records - FAR or DFAR?
This information must be stored in such a manner that none of it may be altered once it is initially recorded without recording all changes, who made them, and when they were made.
Whiteout does not allow you to see the original record.
Thanks Al, 21cfr122.5 is for medical devices so not applicable to the business I am in. I believe the requirements for legibility, identifiable, and retrievable in AS9100D would also cover it though not explicitly stated as a thou shalt not use correction fluid, but I was asked specifically about DFAR/FAR requirements.
J Who can make a Correction of Entry on GMP Records Other Medical Device and Orthopedic Related Topics 1
D FDA Requirements about using Correction Fluid on Documents and Records US Food and Drug Administration (FDA) 8
G What to do with correction factors overlooked by an accredited standard (6.4.11)? ISO 17025 related Discussions 5
G Rework, Reprocess, or Correction - A simple blurred letter on the legible etching ISO 13485:2016 - Medical Device Quality Management Systems 4
G Correction fluid found on documents that are reviewed Qualification and Validation (including 21 CFR Part 11) 11
A Who pays for correction and removal actions? Other Medical Device Regulations World-Wide 2
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
Uriel Alejandro Evaluation of the effectiveness of correction actions General Auditing Discussions 15
D Non ASTM Partial Immersion LGT emergent stem correction General Measurement Device and Calibration Topics 3
I EO sterilization out of specification and correction Other Medical Device Regulations World-Wide 2
Jane's When audit NC requires only correction ISO 13485:2016 - Medical Device Quality Management Systems 16
J ISO 9001:2015 - Clause for Correction of a QMS Nonconformity ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
C Medical Device Malfunction - Customer Complaint - Response vs. Correction Other US Medical Device Regulations 3
Q Corrective Action Effectiveness also for correction? Nonconformance and Corrective Action 11
M Does there always have to be a "correction?" Problem Solving, Root Cause Fault and Failure Analysis 16
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
A Software Medical Device Bug Fixes: Correction or Corrective Action? Other US Medical Device Regulations 5
L Medical Device Reporting vs Recall/Correction: What action to take? US Food and Drug Administration (FDA) 5
R How do I extend Correction factor of Calibration cert to compute instrument accuracy Measurement Uncertainty (MU) 1
A AS9100 and Record Correction Procedure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
N Applying Correction Factors to Furnaces Manufacturing and Related Processes 5
M Calculation for Correction Deformation (Pitch Diameter) General Measurement Device and Calibration Topics 3
A Observations - Is Correction / Corrective Action a Must ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
D Correction and Degree of Error - Metrology Definitions and Differences General Measurement Device and Calibration Topics 1
B How do I calculate Correction to Caliper Calibration Data General Measurement Device and Calibration Topics 4
Q Correction Action as Preventive Action at another Plant? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Correction and Removal - Include Device used in Non-Production Environment? US Food and Drug Administration (FDA) 5
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
B Recall vs. Field Correction - Field Corrections instead of a Recall US Food and Drug Administration (FDA) 25
Q Corrective Action - Disposition always Correction? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
S 3 Wire Pitch Dia. Method - Measuring Force Correction & Lechowski?s method General Measurement Device and Calibration Topics 1
M Definition Corrective Action vs. Correction: Definitions Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 18
D NLEC (Non-Linear Error Correction) vs. SLEC (Segmented Linear) Calibration Technique Calibration and Metrology Software and Hardware 3
S Correction vs. Corrective Action - Differences Nonconformance and Corrective Action 30
F Zahn Cup Correction Chart - Boeing specification BSS 7234 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Medical Device Reporting procedure - Correction and Removal (21 CFR 806) 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
V Can a non-conformance be closed with "correction"? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 15
E Correction and Corrective Action - ALWAYS DOCUMENT BOTH Nonconformance and Corrective Action 13
M What is the indication of "adjusted scale correction" to calibration of liq thermom.? General Measurement Device and Calibration Topics 5
H Definition Correction vs. Corrective Action vs. Preventive Action Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 2
G Whats the difference in applying error factor and correction factor? General Measurement Device and Calibration Topics 1
M Correction for Part/Master material difference in gage block comparison testing General Measurement Device and Calibration Topics 2
K Correction, Corrective Action, and Preventive Action differences - Internal Audits Internal Auditing 10
Z Apogee V2.5 - No correction mapping unless I pay $8,000+ Software Quality Assurance 6
M CARs (correction action request) vs. NCMRs (nonconforming material report) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 19
D On-site Calibration Environmental Control - Is there a correction factor? General Measurement Device and Calibration Topics 5
C Correction - Corrective Action - Preventive Action Nonconformance and Corrective Action 9
J 'Forms' vs 'Question' based Corrective Actions - Correction Action System at Toyota Nonconformance and Corrective Action 8
G MSA Manual Bias Calculation - Why is the d2* correction factor needed Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 2
T Element 4.5 - Hand written correction to a controlled component drawing? QS-9000 - American Automotive Manufacturers Standard 1
