Corrective Action against Customer Complaints
G
glenn0004
Past help has been gratefully received, so here we go again:
We currently record any customer complaint against a defined set of categorise “Key Nature of Complaint” – what I would like to instigate is a link between “Key Nature of Complaint” and a conflict in requirements of the ISO 9001 standard - hence helping with analysis.
We have one “Key Nature of Complaint” listed as “Engineers - Contractual call out time frames not adhered to” and another listed as “Parts delivery - Unable to supply parts”
Could anybody suggest appropriate conflicts in requirements of the ISO 9001 standard?
G
glenn0004
1st objective - identify key processes that have failed
2nd objective - does the complaint represent a conflict with an ISO 9001 requirement.
What I want to identify from the samples given is would “Key Nature of Complaint” listed as “Engineers - Contractual call out time frames not adhered to” represent a conflict with requirement for the control of Non-Conforming Product, given that our product is a service level agreement or would this be a conflict with the requirements for the measurement of product ....or a simple failure in the planning of product realisation....
Hope this helps
What I want to identify from the samples given is would ?Key Nature of Complaint? listed as ?Engineers - Contractual call out time frames not adhered to? represent a conflict with requirement for the control of Non-Conforming Product, given that our product is a service level agreement or would this be a conflict with the requirements for the measurement of product ....or a simple failure in the planning of product realisation....
Hope this helps
This seems like another instance of two people arguing about whether a carnivorous reptile is an alligator or crocodile while they're being eaten by it. It doesn't matter much what you call a failure mode; what you call it doesn't affect the actual nature of the thing. The customer didn't get what was expected. Now the questions are:
  • Are there documented requirements that were not fulfilled?
  • If so, are the requirements reasonable--is the process capable of fulfilling them consistently?
  • If there are no documented requirements that address the problem(s), should there be?
If your process objectives are clear, and they're based on customer requirements and the requirements of the standard, it should also be clear if there's a nonconformity. If the requirements say that in a given situation you must do x and you do y or fail to do x, you know where to hang the NC. What I'm getting at here is that when there is a question as to whether or not a thing is a nonconformity, it means that the requirements aren't clear or don't actually exist.
Randy
Here's what ISO 9001 says in 8.5.2:
A documented procedure shall be established to define requirements for
a) reviewing nonconformities (including customer complaints),
Customer complaint = Nonconformity so ya gotta at least review them regardless of what you label 'em
And all the other stuff from "b" to "f" is relevant too
A customer complaint is not a nonconformity unless it involves non- fulfillment of a requirement. The wording of "a" is bad, but it means that customer complaints must be reviewed. That is unless ISO 9001 is using something other than the normative definition of "nonconformity."
somashekar
:applause: The root cause analysis
:( ISO requirements help to align business process. For any and every complaint that needs appropriate resolution, I see no necessity to cross check with ISO requirements. Your business needs complaint resolution.
Big Jim
We currently record any customer complaint against a defined set of categorise ?Key Nature of Complaint? ? what I would like to instigate is a link between ?Key Nature of Complaint? and a conflict in requirements of the ISO 9001 standard - hence helping with analysis.
We have one ?Key Nature of Complaint? listed as ?Engineers - Contractual call out time frames not adhered to? and another listed as ?Parts delivery - Unable to supply parts?
The biggest shortfall of your proposed approach is that you are trying to determine before hand which element of the standard was violated based on your categorization.
In truth, it will not always fall under the same requirement (element of the standard). Every case needs to be evaluated individually.
I suspect that greater familiarity with the standard (ISO 9001) may help.
John Broomfield
glenn,
The nature of a nonconformity or complaint is the opposite of the requirement.
It does not matter if the requirement is undocumented (see clause 8.3 and the ISO 9000 definition of nonconformity).
Citing a product nonconformity against the clauses in a system standard is not done. First, you have to determine where in the system are the root causes.
Root causes in the system can then be linked to clauses in the standard. A product nonconformity or customer complaint cannot be linked to the standard until you complete the problem solving to stop recurrence.
For example:
Service delivered too early or too late - may be due to poor planning (7.1), poor training in the Sat Nav (6.2.1) and/or poor contract review and acceptance (7.2.2)
Parts not available - may be due to poor supplier selection (7.4.1), poor planning (7.1) and/or lack of customer focus (5.2)
Hope this helps,
John
G
GoKats78
We did analysis..after the corrective action investgation was complete to determine:
A) What process failed; and
B) Into what "Category" the failure fit
1. Failure Mode not identified on PFMEA
2. PCP (Process Control Plan) Not sufficient
3. PCP Not Executed - Competency (Not Trained)
4. PCP Not Executed - Failure to Execute (Just didn't do it....)
P Corrective action against the auditing agency? Written contract is in error AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 17
B Corrective Action Against Provision of Resources, 6.1 Nonconformance and Corrective Action 4
M Issuing a Corrective Action against Internal Customers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 6
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Is a Corrective Action Expected if a Quality Objective is not in compliance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Interesting Discussion Addressing Human Factors in Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
Q AS9100D Corrective Action Procedure needed Document Control Systems, Procedures, Forms and Templates 1
S Corrective Action from Internal Audits not performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J We don't have enough Corrective action entries AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Timely Closure and "Ongoing" Corrective Action Nonconformance and Corrective Action 15
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
S How to Politely Close out a Nuisance Customer Corrective Action? Nonconformance and Corrective Action 11
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Corrective Action Software Recommendations Nonconformance and Corrective Action 4
S SCAR (Supplier Corrective Action Request) Timeliness & Issuance Supplier Quality Assurance and other Supplier Issues 3
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
Q Corrective Action - Assigning KPIs to Non-Guilty Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
5 Expediting Internal Corrective Action Requests (CAR) Closures Nonconformance and Corrective Action 3
J Corrective Action for External Audit NCMR (Procedure Not Followed) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J ISO 9001:2015 Clause10.2 Nonconformity and Corrective Action - Deal with Consequences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
