Corrective Action (CA) vs. Preventive (Predictive) Action (CAPA)
kedarg6500
dear folks
I know there are million questions regarding CAPA.
I haven't been able to find a definitive answer on this.
Let us take example in one of RCA exercise, a Corrective Action was found out. If we implement Corrective Action in similer component group, can we call it as Preventive Action.
If yes what treatment/ we should call for if Preventive Action from earlier RCA exercise being implemented for similer component group.
Kedar
Stijloor
Re: Corrective Action vs. Preventive (Predictive) Action (CAPA)
dear folks
Yes.
If yes, what treatment/ we should call for if Preventive Action from earlier RCA exercise being implemented for similer component group.
Same, Preventive Action
Stijloor.
David DeLong
I agree with Stijloor 100%
Howard Atkins
Forum Administrator
If the system is that of ISO/TS then it is still a corrective action
8.5.2.3 Corrective action impact
The organization shall apply to other similar processes and products the corrective action, and controls implemented, to eliminate the cause of a nonconformity.
Stijloor
Howard,
I have to respectfully disagree with you. Any action taken to prevent a nonconformity is a preventive action. The unwanted situation or condition has not occurred yet.
Stijloor.
Jen Kirley
Quality and Auditing Expert
Howard,
Stijloor.
I agree with this as I understand it. A corrective action is taken to remedy something that is known to be deficient.
If that action is repeated in an appropriate area that has not been found to be deficient, this extended effort is a preventive action for that area. It becomes a matter of learning from mistakes, an excellent endeavor. :2cents:
Please, let us not go here again. TS16949 is an exception. The passage Howard quoted clearly shows that under that standard, actions taken on other processes as a result of corrective action in another should not be considered preventive for purposes of distinguishing between corrective and preventive actions. I know it makes no sense, and no one dislikes the mindless corrective/preventive dichotomy more than me, but there it is.
Stijloor
Good points. Yes, I see ISO/TS 16949:2002, I see Howard's point, I see all contributors' points in this thread. Let's agree that whatever we do to prevent/correct problems is effort well worth it. Fair enough?
Thanks, you are all great. :applause:
Stijloor.
kedarg6500
I am of the same opinion as of Howard, but special thanks to hime for pointing to TS 16949: 8.5.2.3. as well as we can refer to CA implemented on similer process & product as "consequent corrective action".
More contribution are expected on this issue
madannc
Just to add MHO...
Corrective Action as described is correct, the implementation of something to prevent recurrence.
And I am sure that Preventive Action has been described as the implementation of something to prevent occurrence.
That said, the grey lines have a vast opinion following... if product x non conforms the implemtentation of CA (straight forward) however if product y has the potential to to non conform but has not yet, and the implementation of the fix for poroduct x will reduce (or eliminate) the chance of the issue is this a PA?
As an example... I remember this from some training I had a long time ago... if a train fails to stop at a station due to brake failure, the CA is to replace the brakes more often on train "x", now train "y" has not failed to stop at station so is the change in frequency to brake changes for this considered a PA or extension of CA.
IMHO, it is a CA the non conformance of failing to stop at a station has occurred, this was the non conformance, and the train co. is merely exending the application of the CA to all of its fleet (if this is correct term for group of trains).
If the train company was monitoring the efficiency of its brakes and saw a trend showing that there was the potential for brakes to fail at 5 months and the schedule for change was 6 months, then implementing a change to replace brakes at 4 months would be a PA, the non conformance of failing to stop has not occurred.
All to often in real life I have seen these types of fixes addressed in projects, improvement tasks, supplier improvements, etc, and companies forget to include these in their PA process as the perception (still) is that pa's are linked to non conformance which is a bad thing.
not sure if this clarified but thought it would be good to add.
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
B Questions regarding Non-Conformance, Corrective Action and Preventive Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
kedarg6500 Horizontal Deployment of Corrective Action - is it Preventive Action? Nonconformance and Corrective Action 21
W Are CAPAs (Corrective Action Preventive Action) Input or Outputs ISO 13485:2016 - Medical Device Quality Management Systems 6
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
A When to take Corrective / Preventive Action and Continuous Improvements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W Corrective Action, not Preventive Action? Nonconformance and Corrective Action 10
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
