Corrective Action Effectiveness also for correction?
Q
QAMTY
Hi guys
Im applying CA's in my ISO 9001 system. I do the CA, and when is finished, I evaluate it, for effectiveness, but I wonder if I have to do it also in corrections? (containment action).
JoShmo
Hi guys
How will you know if the correction has happened if you don't?
RoxaneB
Change Agent and Data Storyteller
In my experience, corrections are typically documented after the fact (i.e., paperwork is completed after corrections have been made) along with a quick statement indicating that the situation has been fixed.
If I experience a paper cut, I clean the wound, apply a bandage, make sure there is no bleeding and go back to doing my job.
If I slice my finger down to the bone with a knife, well, the investigation and actions taken will be a bit more detailed and in-depth.
That said...if I start to experience paper cuts on a regular basis, there is obviously a problem with my paper-handling process and corrections are insufficient. A more in-depth investigation will now be required.
An organization does not wish to become bogged down in corrective actions for minor issues. That being said, regular analysis of all nonconformances (corrections and corrective actions) is needed to determine if triggers need to be refined (i.e., what situations and results will result in correction versus a corrective action).
Q
QAMTY
Tanks Roxane ,very helpful your comment.
Joshmo, I only ensure correction was done, having the evidences,nothing more.
TWA - not the airline
Hi guys
From the wording "containment actions" I gather that you are mainly thinking of non-conforming product. Here, effectiveness control on corrections typically is simple and straightforward, so in most cases you would not have to do anything special: Reworked product is tested again per SOP, scrap is documented in the batch records and/or the ERP system, product that will be "used as is" will be released following the respective regulations of your QMS, any recall will be tracked regarding the number of returned product etc.
Mike_H
Are you asking if you need to verify effectiveness of containment actions? I guess you could paint a picture where faulty products might continue to leak after corrective action , if containment isn't performed effectively ie) faulty products exist until the C/A is fully implemented and you might not be able to capture every item in time. You would need to weigh up the risk of this happening and the effect it would have to your business. The more risk, the more resource you would want to throw at it (in theory). Hope this helps.
T Measuring Corrective Action Effectiveness AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
J Reviewing Corrective Action Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Q Measuring Effectiveness in Containment Action or in Corrective Action? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
J Verifying the Effectiveness of Corrective Action - Challenge with an external auditor Nonconformance and Corrective Action 16
M Measuring Corrective and Preventive Action System Effectiveness Nonconformance and Corrective Action 32
T Documenting Effectiveness of Corrective/Preventive Action Nonconformance and Corrective Action 8
J Corrective Action Effectiveness and Results Verification Question Nonconformance and Corrective Action 5
J CAPA (corrective action preventive action) Effectiveness - Medical Device Industry Nonconformance and Corrective Action 3
E Audit Program and CAPA (Corrective Action - Preventive Action) Effectiveness ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
A Root Cause Verification - Corrective Action Effectiveness, or Root Cause Verification Problem Solving, Root Cause Fault and Failure Analysis 24
Raffy How can I demonstrate evidence and effectiveness of Corrective Action Training Nonconformance and Corrective Action 7
T Corrective Action Risk Matrix AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 9
T Corrective Action vs. Countermeasure AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L Globalization of corrective action and follow up IATF 16949 - Automotive Quality Systems Standard 17
H Can Non-conforming outputs & Non-conformity & Corrective Action procedures be merged Nonconformance and Corrective Action 8
M Root Cause and Corrective Action for CAPA's lacking validation/verification ISO 13485:2016 - Medical Device Quality Management Systems 19
H Ever given an Operations Manager an internal Corrective Action Request? Nonconformance and Corrective Action 5
B Human error corrective action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
G Use of Supplier's Corrective Action Form vs. Corporate Form Supplier Quality Assurance and other Supplier Issues 4
M Corrective action for a defect from customer's mistaken Nonconformance and Corrective Action 1
Q Corrective action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
H Streamlining audit response and corrective action processes ISO 13485:2016 - Medical Device Quality Management Systems 9
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
S I need help in corrective action plan Nonconformance and Corrective Action 15
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
T Continual Improvement as Result of Corrective Action? Preventive Action and Continuous Improvement 32
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
