Corrective Action for lost project quality records
Avtaar
We are an ISO9001 certified organization. One of my colleague misplaced all his project documents including records of review and authorization. He has softcopies of all project documents, but the records of review and authorization which were in hardcopy forms are lost forever. The project was implemented sometime back and is a potential candidate for audit. Any idea what concerns would the auditors have and what would be the immediate corrective action.
Q
qualitymanager
Re: Corrective Action for lost quality records
As an (Internal) auditor I would be concerned that this could happen to other records (i.e., system breakdown). You would have to convince me that the root cause has been eliminated, and that it will not happen again.
Without knowing the root cause or causes, I don't want to venture a guess as to corrective action.
One measure you can take to reduce the severity of the NC would be to have all persons involved in the project sign off (e.g. a memo) to say that all requirements related to the project were met, and an endorsement by the highest-ranking full-time person in the organization (e.g. CEO) AND a commitment to prevent it happening AGAIN.
If it happened again and I found it during a subsequent audit, it would suggest to me that both your Record control (ref. ISO 9001 4.2.4) and Corrective Action (ref. ISO 9001 8.5.2) are not effective.
JCVP1969
Your screwed!! Only kidding :D
How long has it been since you lost the documentation and what have you done in the meanwhile?
I would suggest starting again, explaining the situation in advance of the Surveillance Visit to your Certification Body as they will usually be quite understanding (these things happen!). As you already have the documentation you will just be missing some change control history. Ideally if you could have the new system in place some months in advance you might also be able to show them some document change control which should keep them happy! Also you may need to demonstrate how you will prevent the same thing from happening again.
You may just have to take the loss of these documents on the chin but you should still get through the audit.
Stijloor
If this is a one-time event, it's not a too much of a deal. Just be able to explain this to the Auditor as my Fellow Covers have stated.
Now, if this has happened a number of times, that's more serious because that indicates a systems issue.
Devote an internal audit to verify that this is not a systems issue.
Good Luck!
Stijloor.
Terrisandrew
I had the same thing happen to me. The hardcopies that had the approval signatures were thrown away and all I was left with were the electronic copies. This was caught during a survenliance audit and a nonconformance was sited. The root cause was due to oversight by the QS manager at the time who decided to clean up. We had subsequently implemented an electronic approval system so that was our corrective action.
I would just document what you found in a CAR. This way if it comes up during the audit you can reference your CAR and all should be good.
yodon
I think it might be good to mention that corrections and corrective actions could be two different things. As several have pointed out, if this is a systemic issue, a corrective action should be undertaken to identify the root cause such that a change can be made to the process to ensure it doesn't recur.
The correction, as some have pointed out, is how to recover and/or explain to the auditor what happened.
Howard Atkins
Forum Administrator
Please remember that there is no requirement in the standard that there be hard copies.
If there is a requirement then it is in your procedures.
Why do you want hard copies?
Think and then
Take this as an opportunity to change and then you have totally prevented re occurrence
:biglaugh:
Avtaar
Thanks for your inputs.
I am looking at electronic approval system as a possible corrective action and to prevent this from happening again.
Terrisandrew : May I know what electronic approval system did you implement?
Regds.
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 6
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Is a Corrective Action Expected if a Quality Objective is not in compliance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Interesting Discussion Addressing Human Factors in Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
Q AS9100D Corrective Action Procedure needed Document Control Systems, Procedures, Forms and Templates 1
S Corrective Action from Internal Audits not performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J We don't have enough Corrective action entries AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Timely Closure and "Ongoing" Corrective Action Nonconformance and Corrective Action 15
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
S How to Politely Close out a Nuisance Customer Corrective Action? Nonconformance and Corrective Action 11
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Corrective Action Software Recommendations Nonconformance and Corrective Action 4
S SCAR (Supplier Corrective Action Request) Timeliness & Issuance Supplier Quality Assurance and other Supplier Issues 3
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
Q Corrective Action - Assigning KPIs to Non-Guilty Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
5 Expediting Internal Corrective Action Requests (CAR) Closures Nonconformance and Corrective Action 3
J Corrective Action for External Audit NCMR (Procedure Not Followed) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J ISO 9001:2015 Clause10.2 Nonconformity and Corrective Action - Deal with Consequences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
D Seeking Corrective Action Process Examples Nonconformance and Corrective Action 3
