Here's my concern, better described, I hope.
If we go back to the first post and extract one example:
Can somebody help me out in writing corrective action (in the technical language) for the following received NCs:
1. To define the controls for the outsourcing of warehousing facilities within the quality management system.
1. To define the controls for the outsourcing of warehousing facilities within the quality management system. - for this we have defined the procedure and prepared the work instruction that means we have shown teh steps which will be worked out for receiving, storing, disposal - the formalities in warehouse. The root cause is known, the correction is done and now only in the non-conformity report, i have to write corrective action. only MAJOR PROBLEM IS THE LANGUAGE TO BE USED
QUOTE
The organization had outsourced the warehousing (storage) facilities for the industrial chemicals. COntrols over this outsourced activity were not defined within the quality management system.
I rather doubt that this is the real cause:
For NC (1) - warehousing:
Root Cause: Lack of adequate review of documented controls of processes.
Correction : Controls for receiving, storing, disposal of activities of industrial chemicals at the warehouse have been adequately defined and documented in the procedure. Steps to implement the controls have been documented in work instruction..
Corrective Action : All other processes related to the Warehousing facilities and other processes where controls form an important aspect, shall be reviewed for any other lack of necessary documentation, including lack of controls, adequacy of interaction between processes, and shall be documented in order to avoid any future recurrence of such NC.
Since this was found at a 'stage 1' audit, it shows there's an issue with the 'design' of the quality management system - the documented process and controls.
The 'root cause' must deal with why the system didn't define the controls over outsourcing the warehousing. Why wasn't it included? Is it new?
The requirement in the standard is clear, so why wasn't it included? When you have the answer, then you have 'root cause'. I don't see how the suggestion - a lack of review - is the real reason
