Corrective Action Implementation
https://iaqg.org/wp-content/uploads/2022/12/9101-Form-4-14-Feb-2022.doc
In the case of IAQG AS91X0 audits, the established process requires the CB to review, not only the corrective action plan, but also containment and correction as required. The form I linked has fields and the back of the form you see the instructions for each field.
I don't see anything on that form to indicate that the organization has to wait for approval of a plan before implementing actions.
Steve Prevette
Deming Disciple
Never heard of a customer requiring CA approval before implementation. Does the customer own you? Approval of your report, yes. How can you let a customer stop you from fixing a leak in your boat until they approve the method? :oops:
I don't know the OP's situation, but in my case, the Department of Energy client definitely wanted to be involved in the corrective action process for certain serious concerns. Yes, we could plug the hole in the boat, but as far as rebuiliding / repairing the boat to use it again would require the customer's agreement to the path forward beyond the initial mitigating (plug the hole) action.
Jen Kirley
Quality and Auditing Expert
This type of information might instead be made available to the auditee by procedure. The closing meeting would have, in my experience at least, covered the expectations explicitly as a review of Next Steps to close the audit.
Sidney Vianna
Post Responsibly
If an organization implements a later-disapproved corrective action, such as the usual re-training bs, they will have double work.
That's a mighty big "if" and it doesn't address an actual requirement. The best way to avoid double work is to do it right the first time.
