Corrective Action - Increased Manufacturing Involvement - Injection moulding company
N
Nette
Hi
I work for an injection moulding company that manufactures plastic parts for the automotive industry.
We are currently looking at how we deal with corrective actions and at present the quality department deals with them with very minimal support from manufacturing.
Our senior management have decided that they want to change this and place more emphasis on manufacturing doing the investigations and implementation of corrective actions with the quality department providing a supporting role to them.
We have tried this before and failed.
Has anyone got any suggestions on how we can successfully get manufacturing to take ownership of corrective actions? Any advice or ideas would be welcolme.
Thank you.
Nette
Howard Atkins
Forum Administrator
If top management want it then they should help implement it to ensure it's success.
How are you operating at the moment, relating to each problem or making a monthy paretto of problems?
Have a monthly meeting with quality and production and a representative of senior management. Present the data and then perform root cause analysis on 2 or 3 issues. Help them to find the solution, then help them to implement this, monitor their efforts and each month present their accomplishments.
This is standard stuff but if you show that the root cause is theirs then they will have to fix it.
Good luck
N
Nette
Thanks for your reply.
At the moment customer concerns come through to the quality department. We then organise containment action, carryout the root cause analysis, decide what actions to take, implement the actions, verify they work and respond to the customer. We basically have to hound manufacturing to help us.
The desire for change has come from the Senior Management and they want to change it so the quality department gets notification of the concern and organises containment action. Manufacturing then carryout the root cause analysis, decide what actions to take and implement the actions. They then feed it back to quality who will verify the actions and respond to the customer.
Our timings for response is 24 hours containment, 7 days root cause and 14 days actions and verification.
We have tried to do this before but manufacturing don't investigate or implement any actions and we end up doing it at the last minute.
How do we get manufacturing to do the investigation and actions?
Nette
Howard Atkins
Forum Administrator
You seem to be banging your head against the wall.
You are also only refering to complaints,. what is your internal reject rate? Are you dealing with this?
As usual Quality is in the middle. IMO You will have to use the big stick of management
It seems to me like a motivation issue, you are doing it cause you care, manyfacturing are to busy making non compliant parts.
Sorry that I cannot be more positive or helpfull.
Cari Spears
I don't believe the quality department can...
Only senior management (their bosses) can.
That doesn't mean that you can't contribute/help/educate - but the bottom line is they aren't going to do anything if the quality department enables them by "doing it at the last minute" for them and as long as their bosses don't make them.
F
fuzzy
Piggyback on what works...
We have been going through similar changes and I think we may have gotten onto something this time. My top manager wants to make Operations report on internal NC material in place of the previous Qual / Eng. reporting. So we are basically adapting our existing methods from our Safety program in terms of response times, problem solving, and report formatting. Safety is our #1 priority and Quality is # 2 so why wouldn't we commit as much to Quality as we do to Safety in the Operations segment? Can you hook a ride on a program that you do well with? As has been mentioned, having support from Top Management goes a long way towards changing a culture. Does your management have the will to overcome resistance to change; the discipline to sustain this initiative beyond one month? I hope to say yes in my own case, but I believe a better measure will be after six months. Good luck to you!:)
jrubio
It is dificoult but
Hi friends.
To compete in the Automobile sector is High priority to produce parts with High Quallity (-> 0 ppm), the Automotive industry is cruel with that point, and at the end due to charge back process it cost a lot of money to the Supplier..
And what is more important american companies such as Ford and GM are having a lot of problems with that point Quality, and now they are having the great challage to minimize the inbound source of no-quality and compete with Toyota.
The use the arms of Charge back process and the rating for each concern and Purshasing supervision to get out of bussiness the bad supplier.
I have seen projects which BMW had, in a one Big3 american company wich went out of business due to a tier 2 supplier, they can not afford to have these suppliers.
One manager told me, it is time that we call for 0 pppm products due to the huge inbound of components we receive, this is a nightmare, we have to stop it.
Therefore you have to tell your Management that if they do not involved production in this improment circles, your enterprice, sure enough will be not enough time in the Automobile Arena....
Jen Kirley
Quality and Auditing Expert
I sense some separation of responsibility, authority and powers at play here.
My impression is that Manufacturing has little active influence in the correctove action process, but plays a support and advisory role. If that is not how it is supposed to be, then perhaps this group has taken a hands-off position because history has shown your group will pick the thing up in the end and run with it.
So, top management has said "We will do better" but have they clearly described how they will support this endeavor? Have they talked about what improvement would look like and how the management would ensure that the improvement felt like everyone's victory?
I sense a separation of the three entities, much like our system of government (executive, judicial and legislative branches) but should a manufacturing entity be able to enjoy the same boundaries? To put it more plainly I ask:
What does the director of manufacturing say to support this effort? Does the action match the speech?
What does top management say it will do to take final ownership of the concerns--is there a process where unanswered or unresolved corrective actions will be systematically advanced to the next higher level until an acceptable resolution is achieved--or do they remain outside of the accountability loop?
Lastly I will ask a psychological question: How do you feel? How do the manufacturing folks feel about the quality effort--do they feel policed or are they normally and recognizably empowered to influence the positive? If they do not feel they can normally and recognizably influence the positive, arguably Quality will remain a police function.
If culture is an issue, changing it can be difficult and can take a long time. Progress is measured incrementally and gradually.
There are scores of books on the subject but I'll start you with Sirota et.al.: http://knowledge.wharton.upenn.edu/article/1188.cfm
...employees want a sense of achievement from work. The key element is to be proud of what you do and proud of the organization for which you are doing it. People don't want to work for an organization that's run by a bunch of crooks. The third element is camaraderie. This is also not mentioned much in our field, but it's key -- not only in the sense of having a friend, but working well together as a team. That is a tremendous source of satisfaction for people.
N
Nette
Thank you for all your replies.
The problem we have is that there is a battle between quality and sales. Sales is winning with manufacturing focusing on getting parts out of the door rather than quality.
I have had several discussions with our senior management and one of the problems we have identified is that when faced with the 8D document manufacturing think this is too complicated so I am not going to fill it in.
With this in mind we are going to design a more user friendly document for them to use that will still give us all the information we need to transfer onto the customer 8D. In addtion we are going to implement an escalation process so senior management can get involved if the concerns are being ignored. We are also going to give them a "idiots" guide to problem solving so they have clear steps to take when investigating concerns.
Basically we have to re-educate people :whip: and get them to accept that there is no point getting the parts out of the door if they are going to come back because they do not meet the customer requirements.
Should be fun!
Nette
H Ever given an Operations Manager an internal Corrective Action Request? Nonconformance and Corrective Action 5
B Human error corrective action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 15
G Use of Supplier's Corrective Action Form vs. Corporate Form Supplier Quality Assurance and other Supplier Issues 4
M Corrective action for a defect from customer's mistaken Nonconformance and Corrective Action 1
Q Corrective action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
H Streamlining audit response and corrective action processes ISO 13485:2016 - Medical Device Quality Management Systems 9
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
S I need help in corrective action plan Nonconformance and Corrective Action 15
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
T Continual Improvement as Result of Corrective Action? Preventive Action and Continuous Improvement 32
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Is a Corrective Action Expected if a Quality Objective is not in compliance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Interesting Discussion Addressing Human Factors in Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
Q AS9100D Corrective Action Procedure needed Document Control Systems, Procedures, Forms and Templates 1
S Corrective Action from Internal Audits not performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J We don't have enough Corrective action entries AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Timely Closure and "Ongoing" Corrective Action Nonconformance and Corrective Action 20
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
S How to Politely Close out a Nuisance Customer Corrective Action? Nonconformance and Corrective Action 11
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
