Corrective Action Reply to a Customer - Operator Error
I
inspector 2s
Newbie.
Hi guys/gals.
I am a recent member and was wondering if someone could come up with an answer for me.
We recently had a NC off our customer. The part was machined and one of the four M4 tapped holes was not tapped to depth. We do 100s of these and all are tapped by hand, the fitter just missed one, our customer will not accept human/operator error. This wasn't picked up at inspection as toleranced dimensions are the only sizes that are checked, the rest is visual. Anyone got any ideas for corrective action?
many thanks.
Insp 2s
somashekar
Re: Corrective action reply
Welcome to the Cove inspector 2s ~~~
What you say above is certainly contradicting and not in line with your customer's expectation.
When you do more, your fitter would again miss few, and this is not intentional. Your visual inspector will miss too, and again not intentional.
Can you make investment to have a drilling fixture to drill all 4 at one go ?
Like this one in the picture attached .....
Jason PCSwitches
You also need to look at your inspection process and how this was allowed to slip-thru.
Your probably doing a sample of the batch, so you may need to increase the sample size as corrective action. If you are not inspecting for the noted defect, you may want to start doing so as a part of your corrective action.
These things will happen but the point of a QMS is to improve your processes. This is an opportunity to do so. Human error is probably not the root cause; it's the inspection process.
Perhaps this is a semantically quibble, but in this case human error is the cause. (while I am normally suspect of human error ,there are legitimate occurrences. Retraining or 'discipline' are almost never effective). The inspectIon process did not cause the defect, it failed to catch it. In "Apollo" language, it is the escape cause while human error is the physical or 'root' cause.
I think what your customer is probably looking for is a positive corrective action that will most likely involve some level of error proofing such as Someshaker has proposed...
Newbie.
Hi guys/gals.
many thanks.
used?
Can you clarify?
Insp 2s
You say that one of the holes "was not tapped to depth." I take this to mean that the hole was tapped, but not deep enough. You also say that the tapping is done by hand, but I'm not sure what that means either. Do you mean it's done by a machine, such as a drill press, and not in machine that actually makes the part, or do you mean that an actual hand tap is used?
Mr.Happy
When you make 100s of those parts, why don't you switch to an automatic (CNC) process.
Then you only have to check the first and the last part (and any in between if you like).
L
lego55
Newbie.
Hi guys/gals.
many thanks.
Insp 2s
Your customer might simply want one more "why" past "operator error." They might just be looking for the reason he/she didn't do what was needed. For example...
Is there a procedure the fitter did not follow? Or do you need a procedure?
Did the fitter get distracted? If so, by what and can it be prevented?
We once found out that our person who suddenly began making some errors kept forgetting their glasses. We just didn't ask the right questions. Another time, we found out our inspector was color blind and didn't notice the shade difference. We were able to put controls into place that helped each one.
Asking the right questions and finding the next reason might make it easier to prevent it next time.
Just my :2cents:'s worth.
I
inspector 2s
Thank you all for your response.
Jim, the four holes are drilled and part tapped on a CNC machine. They are not tapped to depth to avoid tap breakage, the holes are then tapped by hand with a tap wrench.
there are two tapped holes on each face of the component about 500mm apart.
We have been doing this part for over 7 years and this is the first time this has happened, I know it's technically a non conformance, but where does common sense kick in?
somashekar
Finishing with a manual operation after a CNC operation is downgrading the technology. Talking of M4 tap, you get very good quality machine taps and good lubricants that can be used to finish tap in one operation. Have you considered a process change, since 7 years is too long. Have the quantity increased over this time.
One of the reason you may get a problem that you described is from increased volume.
I
inspector 2s
Somashekar.
We have tried to drill and tap to depth in the same operation on the CNC, but found we were spending more time and money sending the component for spark eroding to have the broken tap removed. As good as CNC are, they do not have the feel that a person has when tapping by hand, ie if swarf starts to clog the tap the CNC will carry on regardless, hence the tap will break because of the size. there is also some M16 tapped holes on this component these are done complete on the CNC because it's a larger tap therefore more durable.
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
F Can we reply to a CAR (Corrective Action Request) without Root Cause? Problem Solving, Root Cause Fault and Failure Analysis 24
F Multi-Level CA (corrective action) Process? Levels of investigation, reply deadline Nonconformance and Corrective Action 4
H Streamlining audit response and corrective action processes ISO 13485:2016 - Medical Device Quality Management Systems 8
Q Corrective Action Notification - Registration Audit ISO 13485:2016 - Medical Device Quality Management Systems 12
S I need help in corrective action plan Nonconformance and Corrective Action 15
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
T Continual Improvement as Result of Corrective Action? Preventive Action and Continuous Improvement 32
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Is a Corrective Action Expected if a Quality Objective is not in compliance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Interesting Discussion Addressing Human Factors in Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
Q AS9100D Corrective Action Procedure needed Document Control Systems, Procedures, Forms and Templates 1
S Corrective Action from Internal Audits not performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J We don't have enough Corrective action entries AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Timely Closure and "Ongoing" Corrective Action Nonconformance and Corrective Action 20
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
S How to Politely Close out a Nuisance Customer Corrective Action? Nonconformance and Corrective Action 11
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Corrective Action Software Recommendations Nonconformance and Corrective Action 4
