Corrective Action: "shall be appropriate to the effects of issues encountered"
mlthompson
Good Day Everyone! Please help me understand this requirement. I know the ISO standard says action shall be taken to eliminate recurrence. But then this statement is made. I always thought that this meant my company has the choice on what action to take (i.e., don't spend $150,000 to fix a $100 problem) or maybe just tolerate certain nuisance issues using existing controls.
I am now being told that "appropriate actions to the effects" only refers to effect on customer or end user. I am also being told that corrective actions (those that eliminate recurrence) must be taken on all nonconformities despite the magnitude of the issue. To implement poke yoke methods for every known problem can be very expensive and probably not feasible in most company's capitol budget.
How to you understand this requirement and what does your auditor check for to show compliance?
Thanks Much!
mlthompson
This is what my registrar is telling me. I know CAs must be implemented to correct our issues, I'm concerned about needing to fix those nuisance issues that doesn't justify fixing.
The registrar or the auditor? I find it hard to believe that a registrar would have such a nonsensical policy. CAs should always be appropriate to the effects, or potential effects, regardless of who the effect happens to. That means that sometimes the reaction will be "it's not worth pursuing." As long as you have a record of review and can explain it in terms that make sense, you should be in the clear.
mlthompson
I have recently received an advisory notice from my registrar regarding the "magnitude" comment. In regards to the "effects only on the customer/end user" comment, this was told to me by my Corp QA Director who says that this is the interpretation of the registrar.
I'd like to hear from some of our third-party folks on this one, as well as any other Covers who might have had similar experiences.
Sidney Vianna
Post Responsibly
We need the facts
I agree with you, Jim. Since it is a formal advisory issued by the Registrar, according to Mike, it should be OK to post a copy here. Sometimes, when you read the advisory carefully, it might make sense. I would advise Mike to post a copy so we can evaluate it. Otherwise, we are limited to Mike's understanding of the advisory. I can not believe that a Registrar would make an all encompassing policy such as this, irrespective of the impact magnitude.
It would not be the first time, however, that a poor written advisory would have to be retracted.
Aaron Lupo
I was wondering if his Corporate QA Director could be reading too much into the advisory notice or just not understanding what is being said. I have never heard such a thing either. Sometimes as they say "stuff happens" and as was already mentioned just make sure you document that you feel it is not worth pursing and the reasons why.
Helmut Jilling
Auditor / Consultant
Advisory was mis-stated
I am aware of this Advisory, and with all due respect to the parties, it was misread or misunderstood.
The topic of the Adisory was about root causes. There is no statement that corrective action has to be done regardless of cost, regardless of magnitude.
The actual quote is:
"It is our view, ... that corrective actions are actions that are taken to specifically address the root cause of a problem regardless of the magnitude of that problem. First, proper corrective action cannot be taken until the actual root cause of the problem has been identified."
It went on to explain that the point is, unless you have analyzed and identified the systemic root causes, you are not in a position to understand whether the proposed actions will be effective.
It was not about doing corrective action regardless of cost or magnitude. It was about knowing the root cause, whether a big problem or small, will allow you to determine effective solutions.
Even the standard makes it clear that actions have to be approrpiate to the magnitude of the issue. A registrar cannot overturn the standard. There is no blank check required. It would not be feasible, in any case.
Hope that satisfies the concerns, folks...
Root cause.............
is their opinion???
Surely, this will frighten organizations into thinking that they need some structured process to find a simply obvious reason for an issue? It's not necessary to formulate an '8D' or similar to find the root cause, but I could see that's what auditors and (some) management are going to interpret. From my experience (and from some articles published in the British IQA Journal many years ago) the diagnosis of some problems doesn't need much analysis. I'm thinking these auditors/Regstrars are making mountains (sorry Icy:lol: ) from (potential) molehills:bonk: If organizations are going to have effective actions, we must be careful not to over analyze issues.........:caution:
Do what you will and show you worked on an effective action, rather than worrying about what 'advice' you get from folks like this..........:rolleyes:
Andy
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 6
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
qualprod Is a Corrective Action Expected if a Quality Objective is not in compliance? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 38
M Corrective Action Effectiveness Nonconformance and Corrective Action 5
P Documentation for correction, corrective action, mini CAPA Nonconformance and Corrective Action 9
P Interesting Discussion Addressing Human Factors in Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 23
S Formal written response to a corrective action? Nonconformance and Corrective Action 9
Q AS9100D Corrective Action Procedure needed Document Control Systems, Procedures, Forms and Templates 1
S Corrective Action from Internal Audits not performed ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 24
J We don't have enough Corrective action entries AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
T Timely Closure and "Ongoing" Corrective Action Nonconformance and Corrective Action 15
P Examples of Nonconformance, Corrective Action Requests, and Root Cause Analysis Nonconformance and Corrective Action 2
S How to Politely Close out a Nuisance Customer Corrective Action? Nonconformance and Corrective Action 11
R How many Corrective Action Request can be Issued by DCMA for a single issue? Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
J When to Initiate a CAR (Corrective Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
A Corrective Action Software Recommendations Nonconformance and Corrective Action 4
S SCAR (Supplier Corrective Action Request) Timeliness & Issuance Supplier Quality Assurance and other Supplier Issues 3
Fender1 Customer specified Item Defect Corrective Action Responsibility Customer Complaints 18
Q Corrective Action - Assigning KPIs to Non-Guilty Processes ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
5 Expediting Internal Corrective Action Requests (CAR) Closures Nonconformance and Corrective Action 3
J Corrective Action for External Audit NCMR (Procedure Not Followed) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
J ISO 9001:2015 Clause10.2 Nonconformity and Corrective Action - Deal with Consequences ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
T ISO 9001:2015 Clause 9.2.2 Internal Audit - Corrective Action Report Format ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
C Recurring Nonconformance - Missing Deadline for Closing a Corrective Action Problem Solving, Root Cause Fault and Failure Analysis 14
D Seeking Corrective Action Process Examples Nonconformance and Corrective Action 3
