Corrective Actions identifed as Preventive Actions
O
omartinez
Guys ,
I need a little of your help , I have an AS9100 audit last week and the auditor found an issue with during the process.
I explain him that we already have identify the issue and we create a Preventive Actions in our internal sistem .
He arguge that this was not a Preventive action it was a Corrective action so he wrote a fining :
The organization shall determine action to eliminate the causes of potential nonconformities in order to prevent their occurrence.
Nonconformance: The organization, in some situations, identified nonconforming processes as Preventive Actions.
12 Objective Evidence:
The site identified a Daily Machine Check List that was not being filled out daily as preventive action.
The site identified that a Traveler Sheet did not include the process procedure used in an Inspection operations
In both cases the processes were either not followed or not clearly/correctly identified, which would be considered a non-fulfillment of a requirement and should have been identified as nonconforming and addressed through the corrective action process.
He strongly say , that training as corrective action was not aceptable , due our company and staff is not knew and they should know what the differences between corrective and preventive.
Have you had any similar fining ? How do you answerer you findings ?
Thank you !
Mikishots
Guys ,
Thank you !
Because the non-conformances have occurred, they clearly fall within the realm of corrective action. The task is to identify the root cause of the non-conformance and then address it directly, thus preventing future occurrences.
Training is a containment activity (or more specifically, lack of training is not considered to be an acceptable root cause).
O
omartinez
Thank you Sr.....
lack of training was the real causes , dont know why the auditor wont acept that.
I respectfully disagree. Lack of understanding can be a legitimate root cause.
Mikishots
Sure. But that's not what I said.
But you can easily identify a level deeper - there must be a reason why the staff don't understand. Without addressing this root cause, there's no reason to expect that it won't happen again.
Thank you Sr.....
Why was there a lack of training ?
When you have an answer to this, we can see if we have to ask any more questions to get to the root cause.
We need root cause, not the real cause., so that when that gets addressed, such a NC situation no further occurs.
If lack of training is the root cause, training may be provided. However the competency assessment and gap analysis and actions to fill this gap prior to activity may never happen. A repeat NC can come up sooner than later.
O
omartinez
So lack of training is not root cause but is part of the root cause , so going deeper the lack of training is because there is not a program training in those items , but this will fall into a Program Training / Lack of training issues
TShepherd
I agree with Somashekar completly and in addition this may be helpful to you.
Preventative Action - sometimes known as Error Proofing - means "This non-conformance can never happen again - ever" - most times through design of the product or process which eliminates the potential for a non-conformance.
Detection - also known as Mistake Proofing - means "this non- conformance will be detected before moving to the next step in the process" - However, at least 1 non-conformance will be created and there is still potential for that getting through the system.
A check list does not even rise the level of Mistake Proofing.
Operator Error or Operator Training cannot be used as a root cause or listed as Preventative Action because the root cause has not been determined yet and the last cause (Root Cause)has not yet been listed yet
If you rethink the Problem Statement from this standpont you might come up with something like this...
The operator failed to Bla, Bla, Bla or The operator did this XXXX
And if the answer to either of these two questions is "Lack of Training"
it becomes a systemic issue that must be resolved.
Some companies resolve this by requiring that operators be licenced to a specific job and that this licence is posted at the job when they are operating the job - some even tie pay incentives to the number of jobs that an operator has a licence to run.
Keep in mind, that even this does not rise to the level of Mistake or Error Proofing and still well within the Detection Arena - your issue with the Audit may be nothing more than a definition misunderstanding or Perspective misunderstanding.
Using this type of engineering thought process and a well written 3L5Y (Three Legged Five Why) may be helpful to you in your responses.
Good Luck
Tom:2cents:
Let it fall ...
Then question it and address that process.
Check if it ends there or leads you to an other process where the root (real) cause is present
P
PaulJSmith
It may very well. However, the point everyone is trying to make is that there is a deeper reason that the training failed; it may be your training process, or your personnel assessment process, or ...
Ask "Why" the training failed.
A fair percentage of the quality community (including auditors) will not accept "training" as a resolution to most Non-Cons. Once you dig deeper, you'll see why that is.
L Article 87 Field Safety Corrective Actions in a third country EU Medical Device Regulations 2
L Corrective and Preventive Actions aligned to design related defects. After Work and Weekend Discussion Topics 5
A Final quality control corrective actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Northern Ireland Field Safety Corrective Actions (FSCA) UK Medical Device Regulations 5
A Corrective Actions and the 5 why's Training - Internal, External, Online and Distance Learning 2
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
qualprod Do we have to document all corrections and corrective actions in ISO 9001 10.2.2 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 22
F Vigilance Reporting - Requirements for manufacturer Field Corrective Actions (FCAs) Other Medical Device Regulations World-Wide 5
A Agenda for 8D audit on Supplier's side - Auditing Corrective Actions General Auditing Discussions 5
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E ISO 9001:2105 - Are OFI or Corrective actions required? Preventive Action and Continuous Improvement 55
M Informal Corrective Actions - AS9100DCl. 10.2.1 A-H Nonconformance and Corrective Action 12
O Updating "opportunities" resulting from Corrective Actions Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
Q Timeframe to resolve Corrective Actions (Undue Delay) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
MarilynJ6354 Internal Audit Corrective Actions Internal Auditing 5
J Where to get meddev FSCA (Field Safety Corrective Actions) trainings EU Medical Device Regulations 7
B Verification of Corrective Actions based on Quantities Nonconformance and Corrective Action 6
M Benchmarking - Timely Closure of Corrective Actions Nonconformance and Corrective Action 3
M Singapore - New Field Safety Corrective Actions (FSCA) Process Other Medical Device Regulations World-Wide 1
W Corrective /Preventative/Rectification actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S TS 16949 - 8.5.2.4 - When are Corrective Actions required IATF 16949 - Automotive Quality Systems Standard 5
E Can corrective actions be written by and resolved by the same person? Nonconformance and Corrective Action 5
H Corrective and Preventive Actions Process Examples IATF 16949 - Automotive Quality Systems Standard 2
L An Auditor gave a finding for Ineffective Corrective Actions IATF 16949 - Automotive Quality Systems Standard 13
J How to assign a Leader to respond to Corrective Actions Nonconformance and Corrective Action 7
D Supplier Nonconformance & Corrective Actions Procedures Nonconformance and Corrective Action 1
R Tracking Corrective Actions using an Excel sheet Excel .xls Spreadsheet Templates and Tools 7
J Auditing Supplier Corrective Actions Supplier Quality Assurance and other Supplier Issues 3
F Software or form/templates program to track Internal Audits and Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E Corrective Actions Root Causes from Surveillance Audit Findings Nonconformance and Corrective Action 3
M Does "Responsibility" need to be mentioned in the Corrective Actions ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
P Can the Auditor close down the Corrective Actions? Internal Auditing 12
J Methods to control Efficiency of Corrective and Preventive Actions Quality Manager and Management Related Issues 9
J Corrective and Preventive Actions Database in Excel Document Control Systems, Procedures, Forms and Templates 14
M Management Team "Actions" vs. CAPA (Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Free webinar on Corrective and Preventive Actions on Thu, Mar 7, 2013 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Measuring Monthly Progress in Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E SPC Corrective Actions - Best Practice with Process Statistical Analysis Tools, Techniques and SPC 2
I RPN without Recommendation neither corrective actions FMEA and Control Plans 2
W Severity Rating CORRECTIVE ACTIONS - Opinions Wanted Please Nonconformance and Corrective Action 15
T System Corrective Actions when Conforming Product depends heavily on Inspection Nonconformance and Corrective Action 3
S Scoring the "Quality" of Planned & Executed Corrective & Preventive Actions? Benchmarking 3
Q Corrective and Preventive Actions and Management Reviews ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
0 Corrective Actions - Communication Management & Tools Preventive Action and Continuous Improvement 1
J Reviewing Effectiveness of Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
