Corrective Actions Root Causes from Surveillance Audit Findings
E
ehoqa
Hi Cove members!
I hope someone has some insight on how to determine the root cause and corrective action for some minor findings from our ISO 13485 surveillance audit. We are a small medical device company and ISO 13485 is pretty new to us, as we just started a couple of years ago. I don't expect anyone to answer these for me but I hope to be guided though this by objective readers :)
1. One of the nonconformities was written up against Sec. 4.1. which states that outsourced processes must be controlled and identified within the QMS. While it was found that our outsourced processes are controlled, they are not identified.
It was mentioned that the fix can be as simple as marking the outsourced processes on our approved vendor list. Great!
Now I'm stuck on figuring out the root cause and corrective action. We have an approved vendor list, but we didn't know we had to explicitly identify which ones are outsourced. Why not? Because no one here (me) is an expert at this, though we were trained to this standard to understand the basics. I don't want to say it's a training deficiency because even with further training on ISO 13485, I don't see how the issue of not being aware all the details will be resolved.
2. The second nonconformity is against 8.2.2 where it states that internal audit follow-up activities shall include verification and reporting verification results. The reason for this nonconformity is that this requirement isn't addressed in our procedure. I tried to fight this one because the auditor didn't have evidence that this requirement was not being performed (we use CAR forms with a verification section), but the auditor said it needs to be addressed in the procedure.
I'm better at determining the root cause for repeating/systemic process issues. However, I'm at a lost when it comes to things like needing to explicitly identify outsourced services or something is missing from the procedure.
Thanks for any help in advance! :)
insect warfare
QA=Question Authority
Outsourced processes can also be identified through the use of a process map. If an overall process map already exists within your organization, then you could simply identify them there - the added benefit is you can show how they interact with your internal processes and have a good reference document as a plus. But keep in mind that the word "identified" in this context does not necessarily mean "documented", so if you were able to adequately explain to your auditor what those outsourced processes were without having them documented per se, this still counts as "identified" and IMO maybe should have only been raised as an OFI (opportunity for improvement) and not a NC.
As for your 8.2.2 dilemma, what does your corrective/preventive action procedure state in regards to how internal audit findings are followed up on and verification recorded? The reason I ask is that even though your internal audit procedure may not state the requirements explicitly, your CAPA procedure may already contain this information, which still satisfies the requirement. If not, your auditor may have a case here, but still should be an easy remedy.
Brian :rolleyes:
E
ehoqa
Thanks, Brian. I think both have easy remedies/corrections, but that's just it. I'm wondering how to dig deeper to the root cause in these cases. :confused:
T Drop Down ("Standard") Categories for Corrective Actions & Root Cause Nonconformance and Corrective Action 4
S On Time Delivery - Non conformance? Root Causes, Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
U Non Conformance - Root Cause & Corrective Actions - Civil Construction Projects ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
W Corrective Actions - Getting to the True Root Cause Problem Solving, Root Cause Fault and Failure Analysis 12
L Article 87 Field Safety Corrective Actions in a third country EU Medical Device Regulations 2
L Corrective and Preventive Actions aligned to design related defects. After Work and Weekend Discussion Topics 5
A Final quality control corrective actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Northern Ireland Field Safety Corrective Actions (FSCA) UK Medical Device Regulations 5
A Corrective Actions and the 5 why's Training - Internal, External, Online and Distance Learning 2
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
qualprod Do we have to document all corrections and corrective actions in ISO 9001 10.2.2 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 22
F Vigilance Reporting - Requirements for manufacturer Field Corrective Actions (FCAs) Other Medical Device Regulations World-Wide 5
A Agenda for 8D audit on Supplier's side - Auditing Corrective Actions General Auditing Discussions 5
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E ISO 9001:2105 - Are OFI or Corrective actions required? Preventive Action and Continuous Improvement 55
M Informal Corrective Actions - AS9100DCl. 10.2.1 A-H Nonconformance and Corrective Action 12
O Updating "opportunities" resulting from Corrective Actions Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
Q Timeframe to resolve Corrective Actions (Undue Delay) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
MarilynJ6354 Internal Audit Corrective Actions Internal Auditing 5
J Where to get meddev FSCA (Field Safety Corrective Actions) trainings EU Medical Device Regulations 7
B Verification of Corrective Actions based on Quantities Nonconformance and Corrective Action 6
M Benchmarking - Timely Closure of Corrective Actions Nonconformance and Corrective Action 3
M Singapore - New Field Safety Corrective Actions (FSCA) Process Other Medical Device Regulations World-Wide 1
W Corrective /Preventative/Rectification actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S TS 16949 - 8.5.2.4 - When are Corrective Actions required IATF 16949 - Automotive Quality Systems Standard 5
E Can corrective actions be written by and resolved by the same person? Nonconformance and Corrective Action 5
H Corrective and Preventive Actions Process Examples IATF 16949 - Automotive Quality Systems Standard 2
L An Auditor gave a finding for Ineffective Corrective Actions IATF 16949 - Automotive Quality Systems Standard 13
J How to assign a Leader to respond to Corrective Actions Nonconformance and Corrective Action 7
D Supplier Nonconformance & Corrective Actions Procedures Nonconformance and Corrective Action 1
O Corrective Actions identifed as Preventive Actions Nonconformance and Corrective Action 10
R Tracking Corrective Actions using an Excel sheet Excel .xls Spreadsheet Templates and Tools 7
J Auditing Supplier Corrective Actions Supplier Quality Assurance and other Supplier Issues 3
F Software or form/templates program to track Internal Audits and Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
M Does "Responsibility" need to be mentioned in the Corrective Actions ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
P Can the Auditor close down the Corrective Actions? Internal Auditing 12
J Methods to control Efficiency of Corrective and Preventive Actions Quality Manager and Management Related Issues 9
J Corrective and Preventive Actions Database in Excel Document Control Systems, Procedures, Forms and Templates 14
M Management Team "Actions" vs. CAPA (Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Free webinar on Corrective and Preventive Actions on Thu, Mar 7, 2013 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Measuring Monthly Progress in Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E SPC Corrective Actions - Best Practice with Process Statistical Analysis Tools, Techniques and SPC 2
I RPN without Recommendation neither corrective actions FMEA and Control Plans 2
W Severity Rating CORRECTIVE ACTIONS - Opinions Wanted Please Nonconformance and Corrective Action 15
T System Corrective Actions when Conforming Product depends heavily on Inspection Nonconformance and Corrective Action 3
S Scoring the "Quality" of Planned & Executed Corrective & Preventive Actions? Benchmarking 3
