Corrective actions
Andrews
I have found that corrective actions for the non-conformities raised during the audit are usually
a) Adding a particular instruction / clause in the procedure / other documnet
b) training of employee concerned
c) Provisioning of a particular resource
Does anyone have something to add to this.
Mike S.
Happy to be Alive
How about getting Managers/Supervisors to buy-in to following the procedures as they are? Many times the NC's I have seen are due to people knowingly not following the procedures.
I find that "training the employee" may only be part of the problem when pursueing corrective action. The real question goes back to "What is the root cause?" You need to ask yourself these basic questions?
a) Was the employee just put into the job without any training?
b) If trained, did the employee just not follow the work instructions? If so, why not?
c) If the work document was wrong, why was it wrong? Wasn't it properly reviewed before approval?
d) What is going to be done to prevent this nonconformance from happening again?
Remember, root causes must be taken far enough to completely answer HOW or WHY it happen.
These are just my opinions and may not reflect the opinions of management or others.
:vfunny:
training and retraining
Good reply Bob! I often say that if there is a lack of performance, you must find out if the employee didn't know (lack of knowledge), then train. If the employee knew, but didn't perform (lack of execution), then you must find out what cause the performance lack. It could be a problem with the employee and it could be management, or equipment. Just as you said Bob:
Jimmy Olson
I agree that you need to find out the root cause of any problem, but you also need to be careful when looking at the process. Sometimes you can be so focused on the process and finding the problem in the process that you overlook the employee. Sometimes you just have to realize that the root cause is a problem employee.
Now that I have climbed off my soapbox I will throw in my two cents on the original subject. It seems that the vast majority of non-conformances do revolve around documentation in some way. Either you don't have the proper document/procedure, or the procedure isn't being followed, or something else related. I haven't seen any non-conformances for lack of management support (I'm sure there are some), but I would say that lack of management support is a problem and is a contributing factor to many NCs.
Andrews said:
---X---
Absolutley:
ISO9001:2000, clause 5.5, Responsibility, authority and communication.... The title says it all, really. The root causes we're all looking for can often be found under that clause, and it is also clearly connected with what Richard quite correctly said: Management support.
However: .... Ok, where is that soap box? Ah, there.. Ok... Ahem..
How often do we see audit reports nailing nc's under those clauses? At least in internal audits, it may in many cases be.... How shall I put it? unwise? You know: :ca: And: That may in its own right be an indication that all is not well concerning 5.1, 5.5 and last but not least 6.4: Work environment.
.... Stepping down from the box.
/Claes
L Corrective and Preventive Actions aligned to design related defects. After Work and Weekend Discussion Topics 5
A Final quality control corrective actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
D Northern Ireland Field Safety Corrective Actions (FSCA) UK Medical Device Regulations 5
A Corrective Actions and the 5 why's Training - Internal, External, Online and Distance Learning 2
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
qualprod Do we have to document all corrections and corrective actions in ISO 9001 10.2.2 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 18
F Vigilance Reporting - Requirements for manufacturer Field Corrective Actions (FCAs) Other Medical Device Regulations World-Wide 5
A Agenda for 8D audit on Supplier's side - Auditing Corrective Actions General Auditing Discussions 5
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
E ISO 9001:2105 - Are OFI or Corrective actions required? Preventive Action and Continuous Improvement 55
M Informal Corrective Actions - AS9100DCl. 10.2.1 A-H Nonconformance and Corrective Action 12
O Updating "opportunities" resulting from Corrective Actions Nonconformance and Corrective Action 2
MarilynJ6354 Missing Corrective Actions - Workforce does not trigger corrective action requests General Auditing Discussions 6
Q Timeframe to resolve Corrective Actions (Undue Delay) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
G Non Value Added Corrective Actions IATF 16949 - Automotive Quality Systems Standard 15
MarilynJ6354 Internal Audit Corrective Actions Internal Auditing 5
J Where to get meddev FSCA (Field Safety Corrective Actions) trainings EU Medical Device Regulations 7
B Verification of Corrective Actions based on Quantities Nonconformance and Corrective Action 6
M Benchmarking - Timely Closure of Corrective Actions Nonconformance and Corrective Action 3
M Singapore - New Field Safety Corrective Actions (FSCA) Process Other Medical Device Regulations World-Wide 1
W Corrective /Preventative/Rectification actions AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
S TS 16949 - 8.5.2.4 - When are Corrective Actions required IATF 16949 - Automotive Quality Systems Standard 5
E Can corrective actions be written by and resolved by the same person? Nonconformance and Corrective Action 5
H Corrective and Preventive Actions Process Examples IATF 16949 - Automotive Quality Systems Standard 2
L An Auditor gave a finding for Ineffective Corrective Actions IATF 16949 - Automotive Quality Systems Standard 13
J How to assign a Leader to respond to Corrective Actions Nonconformance and Corrective Action 7
D Supplier Nonconformance & Corrective Actions Procedures Nonconformance and Corrective Action 1
O Corrective Actions identifed as Preventive Actions Nonconformance and Corrective Action 10
R Tracking Corrective Actions using an Excel sheet Excel .xls Spreadsheet Templates and Tools 7
J Auditing Supplier Corrective Actions Supplier Quality Assurance and other Supplier Issues 3
F Software or form/templates program to track Internal Audits and Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
E Corrective Actions Root Causes from Surveillance Audit Findings Nonconformance and Corrective Action 3
M Does "Responsibility" need to be mentioned in the Corrective Actions ? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 22
P Can the Auditor close down the Corrective Actions? Internal Auditing 12
J Methods to control Efficiency of Corrective and Preventive Actions Quality Manager and Management Related Issues 9
J Corrective and Preventive Actions Database in Excel Document Control Systems, Procedures, Forms and Templates 14
M Management Team "Actions" vs. CAPA (Corrective Actions) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 14
M Free webinar on Corrective and Preventive Actions on Thu, Mar 7, 2013 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
Q Measuring Monthly Progress in Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
E SPC Corrective Actions - Best Practice with Process Statistical Analysis Tools, Techniques and SPC 2
I RPN without Recommendation neither corrective actions FMEA and Control Plans 2
W Severity Rating CORRECTIVE ACTIONS - Opinions Wanted Please Nonconformance and Corrective Action 15
T System Corrective Actions when Conforming Product depends heavily on Inspection Nonconformance and Corrective Action 3
S Scoring the "Quality" of Planned & Executed Corrective & Preventive Actions? Benchmarking 3
Q Corrective and Preventive Actions and Management Reviews ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
0 Corrective Actions - Communication Management & Tools Preventive Action and Continuous Improvement 1
J Reviewing Effectiveness of Corrective Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
R Problems with Supplier - Always with 100% Sorting - No Corrective Actions Supplier Quality Assurance and other Supplier Issues 22
