Corrective and Preventive Action in 8D Problem Solving
neash83
Hello all,
I have a query regarding 8D and more specifically corrective and preventive action within 8D.
My understanding is that a lot of organisations use 8D as the basis of management and control of nonconforming product.
The one aspect of it I?ve never really got my head around is how 8D includes preventive action as one of the steps. I understand you have for example some nonconforming product; you contain it, complete some correction, and investigate the root cause. Then next you have the corrective action and the preventive action.
My interpretation of corrective action being action to prevent an something that has occurred from occurring again and preventive action being action to pre-empt a potential fault and stop it happening at all.
So my question is how can you complete corrective and preventive action with regards to 8D and some nonconforming product you have if the fault has already occurred? Doesn?t any action you put in place after the nonconforming product occurrence always have to be corrective?
How can it be preventive action if its already occurred?
Jen Kirley
Quality and Auditing Expert
Good day neash83,
As shown on Wikipedia's explanation, D7 is "Take Preventive Measures: Modify the management systems, operation systems, practices, and procedures to prevent recurrence of this and all similar problems."
So the prevention aspect is in preventing both this exact issue from happening again, and other similar issues from happening in the first place.
I hope this helps!
neash83
I understand that, but surely if the problem has already occurred any action you do subsequent to that is corrective action? I appreciate it may be simply semantics .
Regards
rob73
looking for answers
As jennifer says, it is the application of the action to areas where the issue has not yet happened that makes it a preventative rather than corrective action.
For example: I have a car its tyre (or tire if you a yank;)) is bald so I replace it - corrective action, my motor bike tyre is not bald but I plan to replace it in one month to stop it going bald - preventative.
shamhaider
Preventive actions must be taken to prevent similar failures down the road..
It is considered as permanent solution to the existing problem..and also help in identify similar problems in other processes..
qusys
Regards
In 8D you can assume that D7 is dedicated to the assessment of the things to be modified based upon the corrective action in whatever system, procedure, method , equipment, material of the organization. it represent a continuum of the corrective action. It is a question of words.
Preventive action is when you act on a "potential" non conformity
Beyond the rather limited use of 8D for preventive action to prevent occurrence of the specific Problem under investigation in other similar products or processes, 8D is simply not a good tool for preventive action before a problem occurs.
FMEA is a rather decent tool for assessing whether preventive action is appropriate.
We must remember that there is no single tool that does it all.
Helmut Jilling
Auditor / Consultant
I find the 8D format is a perfectly useful tool for Preventive Action, if you follow the classic approach described in cl 8.5.3.
To use it, look for POTENTIAL issues in your system, or in production. If it is significant, begin to fill out the form as you would if you were doing a corrective action. The only difference is the verb tense will say things like "could happen" instead of "did happen."
Same root causes, same actions, etc.
Jennifer has the correct interpretation.
Do not confuse the 8D concept of Preventive Action with the ISO 9001 definition of Prevention. They are NOT the same. Ford developed the Team Oriented Problem Solving (TOPS)/8D/Global 8D methodology many years before ISO 9001 became common place. They had a different perspective on prevention.
To Ford, Corrective Action is action taken on the root cause of the problem itself as well as the root cause for the escape. These are the first two branches of the 5 Why. Ford defines Prevention (from the 8D perspective) as actions taken on the systemic root cause of the Quality Management System that allowed either or both of the problem/escape root causes to occur (3rd branch of 5 Why) as well as "Extending the Fix" to similar products/processes that contain the potential for the same root cause to occur.
The ISO 9001 definition of Prevention is an entirely different animal from the 8D definition.
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
B Corrective and Preventive Action Procedure for Customer Service Nonconformance and Corrective Action 5
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
B Questions regarding Non-Conformance, Corrective Action and Preventive Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
kedarg6500 Horizontal Deployment of Corrective Action - is it Preventive Action? Nonconformance and Corrective Action 21
W Are CAPAs (Corrective Action Preventive Action) Input or Outputs ISO 13485:2016 - Medical Device Quality Management Systems 6
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
paul van oppen Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
A When to take Corrective / Preventive Action and Continuous Improvements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W Corrective Action, not Preventive Action? Nonconformance and Corrective Action 10
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Rameshwar25 Difference between corrective action impact and preventive actions. IATF 16949 - Automotive Quality Systems Standard 2
