Corrective and Preventive Action Procedure for Customer Service
biboy2012
I have attached a draft of flowchart specific to Customer Service Corrective/Preventive Action Procedure and hoping to see some of your comments.
Our management system is not based on ISO 9001, but I hope that this procedure might work for us. Customer Service department will be the pilot. Eventually, I will expand said procedure to cover all aspects of company operations.
Please check the flow and level of details against ISO 9001 requirement. My objective is to review the causes of our services that have resulted in customer complaint or dissastisfaction, and provides plan to prevent those causes in he futire.
So, what are your thoughts, comments, criticism?
Thanks in advance.
qusys
Thanks in advance.
Some feedback at first glance:
-I do not understand why “valid compliant?” comes after the box to determine root cause
- I suggest that well established authorities and responsibilities are set ( one role , not two or three roles)
- you did not indicate any reference to “containment action”
- it is not indicated the method to verify the effectiveness of the corrective action
- how long is “appropriate time frame”? Who decides it?
- you say that this also includes “preventive actions”, but I do not see anything about that. Remember
That preventive action concerns with “potential” non conformity
-Also suggested to link the “root cause analysis procedure”
-I do not see anything about the records for this activity
-I do not see anything about feedback in input to mgmt review
Hope this helps
:bigwave:
biboy2012
Agree with your observation.
I will include the foillowing in the "Responsibility" section of the procedure:
All Employees areresponsible for understanding and following this procedure if customer compliant takes place.
All Supervisors areresponsible for assuring adherence to this procedure.
The Department Head isresponsible for ensuring this document is necessary, reflects actual practice, and supports corporate policy.
What do you mean by a "containment action"? Please give an example.
No method yet. Perhaps either through monitoring of the supervisor or manager.
Customer Service Department has a masterllist of complaints with corressponding Turn-Around Time based on SLA.
You are right. I will follow your advice by including/integrating preventive action in the flow.
Is root cause analysis a separate procedure? By the term "link", do you mean I should refer to Root Cause Analysis Procedure
once I reached th task/step relataed to determination of root cause?
I don't want to over burden the customer service representatives by requiring them to fill-up a Corrective/Preventive Action Report. I will try to discuss this with our IT if they can add recording root cause, corrective action, and follow-up results into the system/software.
Hope this helps
:bigwave:
They can put together all records of corrective action to management.
qusys
[/B]No method yet. Perhaps either through monitoring of the supervisor or manager.
You can find the definition of contaiment action and corrective action in ISO 9000. Briefly,the containment is an immediate action to stop immediately the issue preserving the customer to receive non conforming product. The containment does not fix the root cause of the problem, while the corrective action is aimed to address root cause to avoid the recurrence of the problem identified.
Hope this helps.:bigwave:
biboy2012
Looking for suggestions/comments about the following narrative procedure and attached flowchart revised from its original draft taking into consideration qusys helpful feedback.
Scope
This procedure covers the process for initiating, requessting, implementing, and verifying effectivenss of corrective and preventive actions, and applies to preventing and correcting noncompliance related to customer complaint, products (e.g. home, condos/condohotel, mid-rise buildings, townships, country clubs, residential resort communities, etc), materials, any deviations from objectives and targets, procedures, and actual individual or group outputs.
Policy
1.Corrective actions shall be issued for chronic customer complaints (can be product, process or quality system)
2. Corrective Action shall be determined by the Department Head or Supervisor or any person’s from the area the Corrective/Preventive Action Report affects.
Responsibility
The All Employees are responsible for following this procedure once noncompliance and potential problem was detected.
Supervisors and Department Heads are responsible for ensuring that this procedure is followed for all corrective and preventive actions.
Distribution
All Departments
Ownership
Activity Preface
These tasks are performed whenever a problem (e.g. chronic customer complaint, deviation to a procedure, etc) takes place.
Concerned Department
1. Receive customer complaint escalated by Customer Service Representative (or identify potential problem).
If Valid complaint? (or potential problem?), goto task #2. Otherwise, goto task #6.
2. Determine and document root cause; and evaluates feasibility based on magnitude of problem and risk involved. (Refer to Root Cause Analysis Procedure)
3. Implements Corrective Action.
4. Department Head/Supervisor (or QA?) monitors the progress, verifies effectiveness of corrective action within an appropriate Turn-Around Time and document the same. (Refer to: Severity Level and Turn-Around Time Determination Worksheet)
If Effective?, goto task #5. Otherwise, goto task #2.
5. Inform Customer Service Representative on the resolution made.
End of activity.
6. Advice Customer Service Representative and document results for trend analysis.
End of activity.
qusys
Scope
Policy
Responsibility
Distribution
All Departments
Ownership
Activity Preface
End of activity.
End of activity.
Hi ,
I have seen at first glance.
My advice is to share the procedure within the process owners and who shall apply it within your organization.
I think you can start from putting in place the process for corrective and preventive action and then documenting it.
You can apply several technicques, for example BPM depicting the activity " as-is" and then go versus "should be".
Try to get consensus among the stakeholders.
I think you are on the right way:bigwave:
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
Q Recover a Damaged CAPA (Corrective and Preventive Action) Project Preventive Action and Continuous Improvement 6
P FDA Part 820 Clause 820.100 Corrective and Preventive Action 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 3
C Corrective Action and Preventive Action for Operator Error (Cosmetic - Handling) Preventive Action and Continuous Improvement 15
B Questions regarding Non-Conformance, Corrective Action and Preventive Action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7
E CAPA (Corrective and Preventive Action) Plan Templates Nonconformance and Corrective Action 5
M CAPA (Corrective and Preventive Action) Standards & Templates for Tier 1 Supplier IATF 16949 - Automotive Quality Systems Standard 4
kedarg6500 Horizontal Deployment of Corrective Action - is it Preventive Action? Nonconformance and Corrective Action 21
W Are CAPAs (Corrective Action Preventive Action) Input or Outputs ISO 13485:2016 - Medical Device Quality Management Systems 6
Q CAPA (Corrective Action and Preventive Action) after Correction always? Nonconformance and Corrective Action 10
Q CAPA (Corrective Action Preventive Action) NC recommended for IT, HR, ACC.? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
Icy Mountain Continual Improvement, Preventive Action and Corrective Action Database Quality Tools, Improvement and Analysis 23
Q Calibration Failure - CAPA (Corrective and Preventive Action) General Measurement Device and Calibration Topics 3
P When is an issue a CAPA (Corrective and Preventive Action) request? Nonconformance and Corrective Action 6
C FDA - CAPA (Corrective Action and Preventive Action) & Complaint Database 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
T Suggestions for a CAPA (Corrective and Preventive Action) Software Program Quality Assurance and Compliance Software Tools and Solutions 17
Q CAPA (Corrective and Preventive Action) Guidance Needed 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
P Issue Tracking and CAPA (Corrective and Preventive Action) Management Nonconformance and Corrective Action 6
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
A When to take Corrective / Preventive Action and Continuous Improvements ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4
Q Corrective and Preventive Action (CAPA), 820.100 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 4
W Corrective Action, not Preventive Action? Nonconformance and Corrective Action 10
V CAR (Corrective Action Request) vs. PAR (Preventive Action Request) ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
D CAPA (Corrective Preventive Action) Form for critique ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
Rameshwar25 Difference between corrective action impact and preventive actions. IATF 16949 - Automotive Quality Systems Standard 2
