Corrective and Preventive Actions aligned to design related defects.
In 21 CFR 820.100 in the code of regulations, it has a checklist in the back of the book as auditing questions for the various processes. A few of the questions are "Is there a documented and properly implemented procedure for the collection and processing of design-related defects? Does the procedure explain the decision process to pursue the investigation and corrective action of the root cause? Also, " Are appropriate statistical techniques applied to analyze design-related defect data to identify opportunities for corrective or preventative action and to detect recurring problems? 21 CFR 820. 100 (a). With all of this being said, does an organization have to include design defects in their CAPA system or can it be completed through change control? Also, does the CAPA system have to align with the design control process according to the 21 CFR 820.100 clause?
chris1price
My understanding of these statements is that when evaluating defects, you should consider design related issues and use appropriate statistical trending, and not just consider manufacturing non-conformance or other post-design issues. So this is using CAPA to feedback into design; and not trying to embed CAPA into the design process.
Out of interest, which book are you referring to?
Tagin
820.100 is rather short, and does not refer explicitly to Design. Instead, as chris1price notes, when analysis of "processes, work operations, concessions, quality audit reports, quality records, service records, complaints, returned product, and other sources of quality data" leads to "identifying the action(s) needed to correct and prevent recurrence of nonconforming product and other quality problems", and those actions happen to be design-related, then a CAPA raised and design actions taken. Depending on your QMS, I would think that the CAPA feeds into your change control system. That is, the CAPA 'actions to be taken' acts as an input to change control, not supplanting the change control system. Just my view.
Ed Panek
QA RA Small Med Dev Company
FDA expects failures in devices through the lifecycle of the product. Can you capture those failures? How?
FDA is using Remote Regulatory Assesments for low risk devices. CAPA and another subsytems are ALWAYS chosen bare minumum. You need solid processes and CAPA system to show them.
yodon
There's no "checklist" in the regulation. Are you maybe talking about the QSIT Guide?
As several said, the CAPA process can certainly feed the change process but ALSO, the defect analysis should feed the CAPA system. Not every defect should be thrown into the CAPA pool - that's only going to bog the system down. Instead, look for trends that may indicate a process issue. That's the real intent for the CAPA system. 1 bug: fix the problem; a trend: fix the process (as well as the problems).
Chris, the book I am referring to is the code of Federal Regulations GMP Auditor's Basic Handbook for part 21 CFR 820 in the QSR audit checklist section in the back of the book. I think we are both thinking the same way. not actually embedding CAPA into the design process but just as feedback into the design so when changes are made in the design process it can be captured with a cause and a justification for the change which would feed into the corrective action. Thanks for your input.
H Corrective and Preventive Actions Process Examples IATF 16949 - Automotive Quality Systems Standard 2
O Corrective Actions identifed as Preventive Actions Nonconformance and Corrective Action 10
J Methods to control Efficiency of Corrective and Preventive Actions Quality Manager and Management Related Issues 9
J Corrective and Preventive Actions Database in Excel Document Control Systems, Procedures, Forms and Templates 16
M Free webinar on Corrective and Preventive Actions on Thu, Mar 7, 2013 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
S Scoring the "Quality" of Planned & Executed Corrective & Preventive Actions? Benchmarking 3
Q Corrective and Preventive Actions and Management Reviews ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Q "Closing Out" Corrective and Preventive Actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
C Identifying Response Times for CAPAs (Corrective and Preventive Actions) Nonconformance and Corrective Action 2
D Question About CAPAs (Corrective and Preventive Actions)? Preventive Action and Continuous Improvement 2
N Nonconformance and Corrective Actions vs. Preventive Action - Problem Supplier Nonconformance and Corrective Action 24
G Corrective and Preventive Actions - ISO 9001 Clauses 8.5.2 & 8.5.3 Preventive Action and Continuous Improvement 39
S How to evaluate the Effectiveness of Corrective and Preventive Actions Nonconformance and Corrective Action 3
A Analyzing Corrective/Preventive Actions and How to Track Due Dates Preventive Action and Continuous Improvement 16
Q CAPA - What criteria should be used to initiate Corrective and Preventive Actions ISO 13485:2016 - Medical Device Quality Management Systems 8
Rameshwar25 Difference between corrective action impact and preventive actions. IATF 16949 - Automotive Quality Systems Standard 2
Q CAPA (Corrective and Preventive Actions) - Open for how long in Medical Device field? Nonconformance and Corrective Action 4
A Are two separate procedures required for Corrective action and preventive actions Document Control Systems, Procedures, Forms and Templates 38
a_bardi Corrective and preventive actions in telecommunication services ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
L Need examples of Preventive and Corrective Actions (Need to correct audit findings) Preventive Action and Continuous Improvement 19
Claes Gefvenberg Ford Focus recalls. An opportunity to discuss preventive and corrective actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
J If Corrective and Preventive Action were truly Effective IATF 16949 - Automotive Quality Systems Standard 3
K CAPA (Corrective and Preventive Action) - ISO 13485 Nonconformance and Corrective Action 1
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
A Preventive Action or Corrective Action - Paper cuts Nonconformance and Corrective Action 14
H Combined Procedure - Control of Non-conforming Product, Corrective and Preventive Document Control Systems, Procedures, Forms and Templates 14
M Corrective and Preventive Action - Prevent Recurrence is not Preventive Action? Nonconformance and Corrective Action 24
K Definition Correction, Corrective Action and Preventive Action - Definition of terms Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 28
F Software recommendations for corrective and preventive action Quality Assurance and Compliance Software Tools and Solutions 2
K Corrective and preventive action for Non Conformance on PFMEA FMEA and Control Plans 30
W Compliance to 8.5.2 Corrective action 8.5.3 Preventive action ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
J Is a Procedure required for Corrective, Preventive, and Non Conformities ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 9
T Corrective Action and Preventive Action in a Holding Company Nonconformance and Corrective Action 6
M What is Preventive Action taken as part of a Corrective Action? Nonconformance and Corrective Action 5
C The prudence of combining non-conformance reports with corrective/preventive action Nonconformance and Corrective Action 10
N Corrective and Preventive Action in 8D Problem Solving Nonconformance and Corrective Action 21
D CAPA (Corrective and Preventive Action) Flow Chart example wanted Preventive Action and Continuous Improvement 3
J Can Corrective Action be the same as Preventive Action? Nonconformance and Corrective Action 33
sagai Preventive Action vs. Corrective Action as defined by 21CFR820 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 10
C Nonconformance, Corrective and Preventive Action Procedure(s)? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 12
Q Recommendations for criteria on creating a CAPA (Corrective and Preventive Action) ISO 13485:2016 - Medical Device Quality Management Systems 8
L How to deal with too many CARs (Corrective Action Requests), PARs (Preventive Action) Nonconformance and Corrective Action 25
N Combining both Corrective Action and Preventive action procedures into one SOP Nonconformance and Corrective Action 4
sagai Should Corrective Action be segregated from Preventive Action? ISO 13485:2016 - Medical Device Quality Management Systems 10
B Electronic Corrective/Preventive Action Report for our Customer Service Department Nonconformance and Corrective Action 9
