Corrective /Preventative/Rectification actions
wayne.wilson7
Hi All,
I have just had a software update this last week and for some reason our non-conformance screen now has four categories
1. Reason for non-conformances
2. Root Cause.
3. Rectification.
4. Corrective action.
Previously and as per 8.5.2 and 8.5.3 we had
1. Reason for non-conformances (what's wrong).
2. Root Cause (reason why its wrong).
3. Corrective action (how can we put it right).
4. Preventative action (how can we prevent it happening again).
Would appreciate some feed back as Im' not convinced the update is the correct way
Regards
Wayne
P
PaulJSmith
Not sure what software you're using, but in general terms, Preventive Action is not a part of a Non-Conformance process. Once you have a Non-Con, it's a bit late to try to prevent it.
Hi All,
2. Root Cause.
3. Rectification.
Regards
Wayne
It seems like "rectification" is an odd way of saying "correction." This is part of, but different from, "corrective action." Correction is the immediate remedy and might include containment, rework, or other disposition of nonconforming material. Corrective action, on the other hand, would also include prevention of recurrence.
mmagargee
It looks like the update removed preventive action from your corrective action, which everyone here agrees is a good thing. So could rectification refer to "containment"? In other words, preventing the nonconforming product from being shipped before you have a chance to fix the processes responsible?
BTW, you didn't say what kind of software was updated. Was it someone in your company who updated a custom workflow, or did the CAPA software vendor update his package? The answer should direct you to which source to ask for clarification, since the state "rectification" is very fuzzy.
John Broomfield
Hi All,
2. Root Cause.
3. Rectification.
Regards
Wayne
Wayne,
Looks like your software house finally got the memo.
CAPA thinking had people stopping recurrence of nonconformity instead of doing preventive action.
Does your corrected software include risk assessment and risk treatment modules?
Does it help drive preventive action from FMEA, data analysis, setting new objectives, management reviews and planning?
John
wayne.wilson7
Thanks for the response All,
Seems this is still unclear and everyone's interpretation seems a little different.
The update was to our own manufacturing software that is owned by 5 sub-contract manufacturers.
I will try to explain why the software was developed b the 5 companies.
All the companies are no bigger than 40 employees and wanted a MRP system that works easier for Sub-contract machine shops (all companies work to customer print no design etc.) There is only 50 companies in the UK running the software but its becoming more and more popular.
Through All my BSi audits against rev c od 9100 the three auditors have been very impressed with the system but I don't want a change or wording in the NCR screen to trip us up. We had the screen designed so we could catch the ROOT, Corrective action and the preventative action all in one document.
Once the ROOT has been established the corrective action is to put right the non-con if possible or apply for concessions etc, the preventative is how we stop it happening again.
Would it be better if the section was labelled Rectification/Corrective and the last as Preventative??
Wayne
somashekar
Wilson,
We must unlearn first before learning.
CA and PA are two distinct improvement aspects
CA for a detected nonconformity
PA for potential nonconformity
When you apply a CA, the recurrence of the detected nonconformity has to be arrested.
This is the CA effectiveness.
PA starts with determining the potential nonconformity, and preventing it from happening.
You can call these actions anything you want as long as you are clear on the definitions. Semantics can be painful, but words do have meanings.
however, the main point being made here is that Corrective Action and Preventive Action are two unrelated series of events. Those who have written the standard realize that they have done a poor job of deliniating what they intended and are planning to change this in the next version. Admittedly this confusion comes primarily from those who 'interpret' the standard incorrectly...
Corrective Action begins when a nonconformance (to the standard or to product requirements) is detected. Steps taken during Corrective Action include correcting the Nonconformance, determing the cause, taking Corrective Action to prevent reoccurrence and remediation of nonconforming material that may be in inventory or at Customers.
Preventive Action begins whenever you decide it will help Prevent a non conformance from occuring in the first place. Actions include risk assessment FMEA, SPC, 5S, visual workplace, error proofing, even training. Many Lean methods are Preventive Actions...
Corrective and Preventive action should NOT be on the same record since they are NOT the same thing.
somebodyelse
You do not know how many times I tried to get this distinction through to our Lead Internal Auditor. It finally came to the point where I had to choose someone else to be the Lead Auditor. That person still insists that CA involves CA/PA.
A TS 16949 Type of Corrective and Preventative Action Procedure wanted Document Control Systems, Procedures, Forms and Templates 3
M Do you use Software to Control Preventative & Corrective Actions? Quality Assurance and Compliance Software Tools and Solutions 1
C Should Preventative Action follow a Corrective Action Nonconformance and Corrective Action 27
J Corrective/Preventative Action External - Corporate Supplier Quality Responsibility ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 5
T Corrective and Preventative Action in Practice ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
P Sampling Plans for Corrective and Preventative Maintenance Service Orginizations Inspection, Prints (Drawings), Testing, Sampling and Related Topics 1
F Corrective Action and Preventative Action cover Control of Nonconformance? Nonconformance and Corrective Action 13
C Alternate Terms for NonConformance, Internal Audits, Corrective and Preventative ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 32
Q Preventative Action vs. Corrective Action - ISO 9001 Nonconformance and Corrective Action 14
J Corrective Action and Preventative Action Procedures Combined- good or bad? IATF 16949 - Automotive Quality Systems Standard 2
B NADCAP Rejection Response to Root Cause Analysis and Corrective Action. Nonconformance and Corrective Action 1
A Final quality control corrective actions ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
T Continual Improvement as Result of Corrective Action? Preventive Action and Continuous Improvement 32
3 Non-conformance Register vs Corrective Action Register ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 13
D Northern Ireland Field Safety Corrective Actions (FSCA) UK Medical Device Regulations 5
A Corrective Actions and the 5 why's Training - Internal, External, Online and Distance Learning 2
A Corrective Action Training ISO 13485:2016 - Medical Device Quality Management Systems 1
R Not every INCIDENT report will lead to a corrective action EU Medical Device Regulations 7
L Separate Corrective Action and Preventive Action Procedures ISO 13485:2016 - Medical Device Quality Management Systems 13
T AS9100D Clause 10.2.1g Supplier Corrective Action for each and every nonconformity? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
R Non conformance (NC) or Corrective & Preventive action (CAPA) CE Marking (Conformité Européene) / CB Scheme 7
D Corrective Action Timing - IATF CB Deadline IATF 16949 - Automotive Quality Systems Standard 2
R AS 9100D - Containment and Corrective action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
P Customer Corrective Action Requests in OASIS? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
C Corrective action for failure in documents control ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
G Assignable cause/corrective action list for SPC Software Statistical Analysis Tools, Techniques and SPC 3
S Can we provide training plan as corrective action for IATF 16949 Non conformity? IATF 16949 - Automotive Quality Systems Standard 9
P Corrective Action Response for Missed bumps on brake press Manufacturing and Related Processes 2
B Stakeholder Initiated Corrective and Preventive Action Misc. Quality Assurance and Business Systems Related Topics 5
B Corrective and Preventive Action (CAPA) A Key Process of the Quality Management System Dec 17... Training - Internal, External, Online and Distance Learning 0
I When exactly can a corrective action be closed? Nonconformance and Corrective Action 3
M Risk and Corrective actions - Currently no FMEA's - Car systems Risk Management Principles and Generic Guidelines 8
L What to do if a Corrective Action requires several extensions Nonconformance and Corrective Action 7
qualprod Best criteria to measure Corrective Action effectiveness - Poor Maintenance ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
Ashok sunder Is it possible to reduce Risk likelihood and impact Post control Ranking after corrective action taken for risk? FMEA and Control Plans 1
E CAR (Corrective Action Report) with questionable Root Cause ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
qualprod Do we have to document all corrections and corrective actions in ISO 9001 10.2.2 ? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 43
B How to reply NCR on ineffectiveness of corrective action during IATF external audit? This is repeated issue whereby some mistake was done. IATF 16949 - Automotive Quality Systems Standard 7
G Differences - Nonconformances vs CAPA, Corrections vs Corrective Actions ISO 13485:2016 - Medical Device Quality Management Systems 16
I AS9100D Non-conformance for 10.2.1 b 2 and 10.2.1. b 3 e and f - Corrective Action AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 10
F Vigilance Reporting - Requirements for manufacturer Field Corrective Actions (FCAs) Other Medical Device Regulations World-Wide 5
A Agenda for 8D audit on Supplier's side - Auditing Corrective Actions General Auditing Discussions 5
I Audit Nonconformances - Can reported corrective actions be incomplete? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 8
I Corrective Action Tracking for Product and Process in the same system? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 6
Ashok sunder Is it possible to reduce FMEA Occurrence and Detection Ranking after corrective action taken for customer complaints? FMEA and Control Plans 6
E ISO 9001:2105 - Are OFI or Corrective actions required? Preventive Action and Continuous Improvement 55
R CIP (Corrective Action) requirements - ISO 9001 clause 10.2 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
E CAR (Corrective Action Request) Due Dates ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 17
E Corrective Action or Customer Complaint ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 16
