Correlation and Causation - Causation seems to be Ambiguous and Slippery
optomist1
A Sea of Statistics
Good Day To All,
I've searched with little success for a post which lays out the method or methods for establishing causation.
Correlation, is not the problem, rather it is establishing causation.
I know this is one of the possible abuses of conducting correlation, as well as extending the correlation of inputs and outputs outside the observed data range.
Causation seems to be a more ambiguous and slippery effort.
Any insight would be appreciated.
Regards,
Marty
tomvehoski
My blue coffee cup is an excellent bear repellant. I have been using it for a year and have never seen a bear, therefore it must be keeping them out of my office. It also shows promise at preventing asteroid strikes, tornadoes, earthquakes and alien invasions.
You need carefully designed experiments to establish causation. Search for "Design of Experiments". Sadly most of the world does not get it as you can see by picking up any newspaper.
Sturmkind
Lol, tomvehoski!
My coffee cup is equally effective against bears but fails at repelling 'bares' at the beach which are frequently repellant all on their own.
Seriously, aside for DOE to catch interactions, one of the good contributions over the last few years has been the GM drill deep / drill wide discipline for root cause analysis and deployment of corrective action to similar product/process lines. This is an interative 5y question discipline (old school) broken out by categories of Predict / Prevent / Protect and incorporation into Lessons-Learned.
The value of the contribution is that we need to understand why our systems failed any of the categories though for some organizations, the last one should be re-titled Lessons-ReLearned, and ReLearned....
John Tukey laid out 3 requirements for claiming causation:
  1. consistency: more than 1 pair of independent samples (a min of 3 pairs)
  2. responsiveness: The cause must explain both the good & the bad result (or the high and the low) and you must be able to turn it on & off at will.
  3. mechanism: logical reason why the factor causes changes in The Y
I actually find that there are 3 large constraints to successfully determining causes and not just correlation:
  1. very few people understand the concept of independent samples and therefore too many experiments are run by holding too many factors 'constant'. They achieve a great p value and even a grat r^2 value but the variation they see in their experimental results is small compared to the total variation so the completely miss that the factor they 'chose' isn't the primary contributor.
  2. experimenters forget that you can never prove anything: you can only disprove things. Experiments should be structured with the intent of disproving things. From a practical standpoint, once you have disproven all but one of the suspect factors the factor that remains must be the causal factor
  3. the function of the process and/or product and/or system is not well understood and therefore the causal mechanism can't be understood.
optomist1
A Sea of Statistics
To All The Excellent Respondents:
Where might I find this bear or bare repellent...thanks for the well-crafted and timely levity on a dismal February day in MI.
So, it is experience, intellect, an intimate understanding of ones process inputs/outputs and above all independent samples in a properly constructed experiment...voila success!
I get the message...the keen insight and rye humor on these forums is welcome.
Finally, Tomvehoski, will this "ACME" Coffee Cup/Bear Repellent end the “Lions Legacy of Losing? Will it take them to the big dance?
Regards,
Marty
BradM
Marty,
I might also suggest that one can support causation through theory. Given some level of face validity, does it make sense that the two measured items are related?
Is there some theory where you are trying to support your case? I suggest the theory, as it will allow you to better identify if there is another variable (confounding variable) at work. Too, you might have some moderating/mediating variables.
Also, how many data points are you working with? One data point can yield really high correlation. :tg:
So,
  1. Build your theoretical case. What are the items of interest?
  2. Gather as much relevant data as possible.
  3. Lay it out and see what you get.
  4. Repeat 1-3 as much as possible, improving your measures (and theory) as you go along.
Given the data, see if you can develop a useful, predictive tool for your purpose. And.... away you go!:D
tomvehoski
optomist1;420643[COLOR=black said:
Finally, Tomvehoski, will this "ACME" Coffee Cup/Bear Repellent end the “Lions Legacy of Losing? Will it take them to the big dance? Regards,
Marty
Actually I think that one comes close to being able to prove causation. Players, coaches, stadiums, cities, uniforms, turf, anthem singers,.... have all been varied over the years. The one constant has been ownership - which I consider the cause of the problem. Can't prove it though.
optomist1
A Sea of Statistics
Well put Tom...we live in a "Land of Stark Contrasts"; the Red Wings arguably the best professional sports franchise....and the lions with little doubt over the past forty-years the worst professional sports franchise.
The common denominator...ownership, sell the Lions nows.
ncwalker Correlation vs. Causation - Why Correlation does not imply Causation Example Philosophy, Gurus, Innovation and Evolution 7
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
triathlonx13 Leak test correlation - Bubble to Air Reliability Analysis - Predictions, Testing and Standards 8
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
L Coefficient of correlation (r) and b1 Statistical Analysis Tools, Techniques and SPC 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
L ISO 9001:2015 Correlation Matrix & Change Summary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
M Correlation matrix of ISO 13485 and other country regulations Other ISO and International Standards and European Regulations 3
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
J Correlation between OEE and FMEA FMEA and Control Plans 2
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
J Correlation matrix between HSA TS-01 and 21CFR820 or ISO13485 Other Medical Device Regulations World-Wide 1
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
B Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs Using Minitab Software 2
Q Correlation Matrix and Value Stream Mapping? Quality Assurance and Compliance Software Tools and Solutions 1
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
S The relationship (correlation) of 5 Core Tools with TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
C What is difference between a t-test and Correlation Coefficient Statistical Analysis Tools, Techniques and SPC 2
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
S Correlation Study between a new Measurement Device and an existing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
O Correlation of 2 Test Devices - 2 samples (13 parameters) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
N Correlation of Gage R&R Value with the Measured Value of Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
D Improving coefficient correlation result Statistical Analysis Tools, Techniques and SPC 1
H Use SPC to Calculate Correlation Device Tolerance - Hybrid Electronic Components Capability, Accuracy and Stability - Processes, Machines, etc. 3
P Is there a correlation between Teen Violence & Video Games? Coffee Break and Water Cooler Discussions 28
D Two Gauges (Gages) - Two measurements correlation I do not know how to explain Reliability Analysis - Predictions, Testing and Standards 4
S Correlation or Mann Whitney test results? Which to use Statistical Analysis Tools, Techniques and SPC 1
V Correlation and determining the % the contribution Six Sigma 3
S When to use Intraclass Correlation Coefficient vs. Coefficient of Variance Statistical Analysis Tools, Techniques and SPC 21
R Checking Correlation Between Two Similar Gages Measuring the Same Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
J Correlation using t-test and correlation coefficient - What is the correct result? Statistical Analysis Tools, Techniques and SPC 43
A Inter laboratory correlation - Two laboratories with different methods? General Measurement Device and Calibration Topics 4
SteelMaiden Competency evaluation records - Direct correlation to EMS-related topics Miscellaneous Environmental Standards and EMS Related Discussions 7
A Correlation or Hypothesis Test? Which is approprite to use on what kind of problem? Statistical Analysis Tools, Techniques and SPC 6
D Correlation of two tests that are NOT linearly correlated? Statistical Analysis Tools, Techniques and SPC 11
H Process correlation matrix - Just how far "into the weeds" do I go? ISO 13485:2016 - Medical Device Quality Management Systems 4
S MSA (measurement systems analysis) on several CMM's - Correlation issue Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D ISO 13485, FDA's QSR, CMDR, MDD: Seeking Correlation Matrix ISO 13485:2016 - Medical Device Quality Management Systems 41
