Correlation between OEE and FMEA
There is some correlation between OEE and FMEA?
  • Yes
    Votes: 0 0.0%
  • No
    Votes: 1 100.0%
  • Maybe
    Votes: 0 0.0%
  • I prefer not to opine
    Votes: 0 0.0%
  • Total voters
    1
  • Poll closed .
Jason Volney
Hi, Everyone.
There is some correlation between OEE and FMEA? Mainly regarding to occurrence. How I can use this to determine the occurrence?
Jason :agree1:
while some defects will effect OEE calculations not all will. OEE is not in the same units as defect rate so there is no real direct correlation.
what kind of FMEA are you trying to do? if it is only machine fmea then there is a more direct effect of failure/defect on the OEE calculation than there is if it is a general process or product fmea.
in genreal the occurence rate can only be known through actual testing. if the thing is new then occurence is only a guess (opinion) until at least validation is completed. if the thing is not new then past performance of may be of use in determining occurence.
Jason Volney
Ok, Bev D.
I understand you. In this case is a process Fmea.
My question is due the one answer for the last audit that I participated. The auditor made a correlation with the real occurrence of process and occurrence on Fmea.
He was until the factory and told some pieces with one determinate fail, and after this he took the total amount of the production sheet, he calculated the PPM and spoke that the Fmea must have reflected the same occurrence of process. I received a non-compliance for this. Until today we not have one solving for this problem.
I believe that I can to use the data of the OEE (amount of defects), for try give an answer in the next assessment on 29th december. Please, I need you help.
Thanks,
Jason
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
J Correlation matrix between HSA TS-01 and 21CFR820 or ISO13485 Other Medical Device Regulations World-Wide 1
B Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs Using Minitab Software 2
C What is difference between a t-test and Correlation Coefficient Statistical Analysis Tools, Techniques and SPC 2
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
S Correlation Study between a new Measurement Device and an existing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
P Is there a correlation between Teen Violence & Video Games? Coffee Break and Water Cooler Discussions 28
R Checking Correlation Between Two Similar Gages Measuring the Same Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 15
T Correlation Analysis - Internal Audits AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 4
R MSA Multi System Correlation Capability, Accuracy and Stability - Processes, Machines, etc. 21
M Measurment model correlation Measurement Uncertainty (MU) 0
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
triathlonx13 Leak test correlation - Bubble to Air Reliability Analysis - Predictions, Testing and Standards 8
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 8
L Coefficient of correlation (r) and b1 Statistical Analysis Tools, Techniques and SPC 1
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
L ISO 9001:2015 Correlation Matrix & Change Summary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
M Correlation matrix of ISO 13485 and other country regulations Other ISO and International Standards and European Regulations 3
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
N Correlation vs. Causation - Why Correlation does not imply Causation Example Philosophy, Gurus, Innovation and Evolution 7
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
Q Correlation Matrix and Value Stream Mapping? Quality Assurance and Compliance Software Tools and Solutions 1
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
S The relationship (correlation) of 5 Core Tools with TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
optomist1 Correlation and Causation - Causation seems to be Ambiguous and Slippery Quality Tools, Improvement and Analysis 7
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
O Correlation of 2 Test Devices - 2 samples (13 parameters) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
N Correlation of Gage R&R Value with the Measured Value of Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
D Improving coefficient correlation result Statistical Analysis Tools, Techniques and SPC 1
H Use SPC to Calculate Correlation Device Tolerance - Hybrid Electronic Components Capability, Accuracy and Stability - Processes, Machines, etc. 3
D Two Gauges (Gages) - Two measurements correlation I do not know how to explain Reliability Analysis - Predictions, Testing and Standards 4
S Correlation or Mann Whitney test results? Which to use Statistical Analysis Tools, Techniques and SPC 1
V Correlation and determining the % the contribution Six Sigma 3
S When to use Intraclass Correlation Coefficient vs. Coefficient of Variance Statistical Analysis Tools, Techniques and SPC 21
J Correlation using t-test and correlation coefficient - What is the correct result? Statistical Analysis Tools, Techniques and SPC 43
A Inter laboratory correlation - Two laboratories with different methods? General Measurement Device and Calibration Topics 4
SteelMaiden Competency evaluation records - Direct correlation to EMS-related topics Miscellaneous Environmental Standards and EMS Related Discussions 7
A Correlation or Hypothesis Test? Which is approprite to use on what kind of problem? Statistical Analysis Tools, Techniques and SPC 6
