Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs
Brad Gover
Hi all, I just calculated the corrrelation between two of my cmms. my Pearson product moment correlation coefficient value is 0.727. My p value is 0.000. I have rejected the null hypotheses (CL = 95%). With regards to the coefficient (0.727) which indicates the strength of the correlation, are there any industrial standarda or AIAG standards? Is there something like we have in AIAG for GR&R 0 - 10% error - Gage system O.K.; 10% to 30% May be acceptable...?
Stijloor
Re: Correlation Coefficient and Industry Standards - Corrrelation between two of my C
A Quick Bump!
Can someone help Brad with his question?
Thank you!
Stijloor.
The pearson statistic isn't appropriate for assessing measurement systems.
The pearson statistic is for the correlation of a dependent variable with an independent variable. Measurement systems (whether assessign within system repeatability or between system reproducibility/bias) have two independent variables. The first measurement is not dependent on the replicated measurement; One system is not dependent on the other. Additionally, this type of correlation ignores bias. A very critical element of assessments between systems.
If two systems are equal, there will be a 1:1 correlation. If there is error it will appear as variation scattered perpindicular to a 45 degree line. If there is bias the scatter of variation will not be centered on the 45 degree line.
The approach that should be taken is to calculate the Intra Class Correlation Coefficient. The data are plotted on a Youden plot with a square representing the specification.
There is no 'industry standard' for the amount of variation vs the specification. This one of those cases where we are better off plotting the data adn looking at it to assess its usability.
The formulas are in the attached file. I have also attached a spreadsheet that will do the math and graph for you....
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
L Coefficient of correlation (r) and b1 Statistical Analysis Tools, Techniques and SPC 1
C What is difference between a t-test and Correlation Coefficient Statistical Analysis Tools, Techniques and SPC 2
D Improving coefficient correlation result Statistical Analysis Tools, Techniques and SPC 1
S When to use Intraclass Correlation Coefficient vs. Coefficient of Variance Statistical Analysis Tools, Techniques and SPC 21
J Correlation using t-test and correlation coefficient - What is the correct result? Statistical Analysis Tools, Techniques and SPC 43
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
triathlonx13 Leak test correlation - Bubble to Air Reliability Analysis - Predictions, Testing and Standards 8
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
L ISO 9001:2015 Correlation Matrix & Change Summary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
M Correlation matrix of ISO 13485 and other country regulations Other ISO and International Standards and European Regulations 3
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
ncwalker Correlation vs. Causation - Why Correlation does not imply Causation Example Philosophy, Gurus, Innovation and Evolution 7
J Correlation between OEE and FMEA FMEA and Control Plans 2
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
J Correlation matrix between HSA TS-01 and 21CFR820 or ISO13485 Other Medical Device Regulations World-Wide 1
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
Q Correlation Matrix and Value Stream Mapping? Quality Assurance and Compliance Software Tools and Solutions 1
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
S The relationship (correlation) of 5 Core Tools with TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
optomist1 Correlation and Causation - Causation seems to be Ambiguous and Slippery Quality Tools, Improvement and Analysis 7
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
S Correlation Study between a new Measurement Device and an existing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
O Correlation of 2 Test Devices - 2 samples (13 parameters) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
N Correlation of Gage R&R Value with the Measured Value of Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
H Use SPC to Calculate Correlation Device Tolerance - Hybrid Electronic Components Capability, Accuracy and Stability - Processes, Machines, etc. 3
P Is there a correlation between Teen Violence & Video Games? Coffee Break and Water Cooler Discussions 28
D Two Gauges (Gages) - Two measurements correlation I do not know how to explain Reliability Analysis - Predictions, Testing and Standards 4
S Correlation or Mann Whitney test results? Which to use Statistical Analysis Tools, Techniques and SPC 1
V Correlation and determining the % the contribution Six Sigma 3
R Checking Correlation Between Two Similar Gages Measuring the Same Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A Inter laboratory correlation - Two laboratories with different methods? General Measurement Device and Calibration Topics 4
SteelMaiden Competency evaluation records - Direct correlation to EMS-related topics Miscellaneous Environmental Standards and EMS Related Discussions 7
A Correlation or Hypothesis Test? Which is approprite to use on what kind of problem? Statistical Analysis Tools, Techniques and SPC 6
D Correlation of two tests that are NOT linearly correlated? Statistical Analysis Tools, Techniques and SPC 11
H Process correlation matrix - Just how far "into the weeds" do I go? ISO 13485:2016 - Medical Device Quality Management Systems 4
S MSA (measurement systems analysis) on several CMM's - Correlation issue Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
D ISO 13485, FDA's QSR, CMDR, MDD: Seeking Correlation Matrix ISO 13485:2016 - Medical Device Quality Management Systems 41
