Correlation of 2 Test Devices - 2 samples (13 parameters)
O
oen28
Hello all,
I'm Test Engineer in Thailand. I've got to setup the tester for electrical characteristics dc test for optoelectronic device.
I got 2 samples from customer to try whether my tester can test those samples to get the same result as their tester did. Is there anyone out there can suggest how to do correlation with only 2 samples ( 13 parameters) ?
Thanks and regards,
Chawalit
the best you can do right now is plot your results vs their results on a scatter diagram with a 45 degree line. This is called a Youden plot (some call it an isoplot. one plot for each characteristic - don't combine them. then post your results here and we can look at them. I do recommend that you measure each unit twice on your tester to ensure that your tester is repeatable. did they measure the parts more than once?
the other advice I'd give you is that if it is important that this tester corelate to the other one get more samples. You can read up on Miner's blogs...
In the future it is always good to develop your study design before collecting units and data. While I understand that you were probably just a victim in all this it's a good point to drive home with others.
Bev D is referring to this blog entry: Comparison of two gauges.
Darius
I'm not sure, I understand the question:confused:, but with some basic math.
being
Y1 = DEVICE1 MEASUREMENT1
Y2 = DEVICE1 MEASUREMENT2
X1 = DEVICE2 MEASUREMENT1
X2 = DEVICE2 MEASUREMENT2
NOTE: MEASUREMENT IS ONE CHARACTERISTIC
Y1 = SLOPE * X1 + INTERCEPT
Y2 = SLOPE * X2 + INTERCEPT
Y1-Y2 = SLOPE (X1-X2)
SLOPE = (Y1-Y2)/(X1-X2)
INTERCEPT = Y1 - SLOPE * X1
DEVICE1 = SLOPE * DEVICE2 + INTERCEPT
To do it work more perfect, you will need, the expected minimum and maximum value, too close to a point in a line, only the blackness (the color of the point) could be seen (no trends).
sorry Darius, but regression is NOT appropriate for measurement systems analysis. and with only two parts even appropriate 'correlation' analysis will be highly suspect.
Darius
Agree with regression not being an MSA analysis, but as you said I would suspect about any analysis done with 2 samples.
Sorry Brev, but also, IMHO, the only thing that can be done is to "traduce" the customer gauges to your own measurement, and regression is right for such task, even is a normal procedure to calibrate an instrument. But here I am to learn, and are specting to see the Youden plot in action, as I woud said "nec scire fas est omnia".
triathlonx13 Leak test correlation - Bubble to Air Reliability Analysis - Predictions, Testing and Standards 8
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
C What is difference between a t-test and Correlation Coefficient Statistical Analysis Tools, Techniques and SPC 2
S Correlation or Mann Whitney test results? Which to use Statistical Analysis Tools, Techniques and SPC 1
J Correlation using t-test and correlation coefficient - What is the correct result? Statistical Analysis Tools, Techniques and SPC 43
A Correlation or Hypothesis Test? Which is approprite to use on what kind of problem? Statistical Analysis Tools, Techniques and SPC 6
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
L Coefficient of correlation (r) and b1 Statistical Analysis Tools, Techniques and SPC 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
L ISO 9001:2015 Correlation Matrix & Change Summary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
M Correlation matrix of ISO 13485 and other country regulations Other ISO and International Standards and European Regulations 3
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
N Correlation vs. Causation - Why Correlation does not imply Causation Example Philosophy, Gurus, Innovation and Evolution 7
J Correlation between OEE and FMEA FMEA and Control Plans 2
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
J Correlation matrix between HSA TS-01 and 21CFR820 or ISO13485 Other Medical Device Regulations World-Wide 1
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
B Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs Using Minitab Software 2
Q Correlation Matrix and Value Stream Mapping? Quality Assurance and Compliance Software Tools and Solutions 1
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
S The relationship (correlation) of 5 Core Tools with TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
optomist1 Correlation and Causation - Causation seems to be Ambiguous and Slippery Quality Tools, Improvement and Analysis 7
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
S Correlation Study between a new Measurement Device and an existing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
N Correlation of Gage R&R Value with the Measured Value of Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
D Improving coefficient correlation result Statistical Analysis Tools, Techniques and SPC 1
H Use SPC to Calculate Correlation Device Tolerance - Hybrid Electronic Components Capability, Accuracy and Stability - Processes, Machines, etc. 3
P Is there a correlation between Teen Violence & Video Games? Coffee Break and Water Cooler Discussions 28
D Two Gauges (Gages) - Two measurements correlation I do not know how to explain Reliability Analysis - Predictions, Testing and Standards 4
V Correlation and determining the % the contribution Six Sigma 3
S When to use Intraclass Correlation Coefficient vs. Coefficient of Variance Statistical Analysis Tools, Techniques and SPC 21
R Checking Correlation Between Two Similar Gages Measuring the Same Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
A Inter laboratory correlation - Two laboratories with different methods? General Measurement Device and Calibration Topics 4
SteelMaiden Competency evaluation records - Direct correlation to EMS-related topics Miscellaneous Environmental Standards and EMS Related Discussions 7
D Correlation of two tests that are NOT linearly correlated? Statistical Analysis Tools, Techniques and SPC 11
H Process correlation matrix - Just how far "into the weeds" do I go? ISO 13485:2016 - Medical Device Quality Management Systems 4
S MSA (measurement systems analysis) on several CMM's - Correlation issue Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
