Correlation of Gage R&R Value with the Measured Value of Parts
N
nicholas_yeoh
Hi
I have done a gauge study based on MSA 3rd edition book.
However, is there a way that I can establish the uncertainty of measurement from a gauge R&R study and apply it to the measured value of parts?
If I need to be certain that all parts are within specification when measured using my equipment, can I use the results from my gauge study to calculate an uncertainty of measurement that can be applied to the drawing tolerance,
for example:
If the part specification is 10.0 ±0.5 mm
If the gauge uncertainty is 0.1 mm (based on GRR value),
then is it true that I would have to ensure that all parts measure between 9.6 and 10.4 mm to guarantee that they are within specification?
I have been involved in GRR in the last three years but I have never
understood the correlation of GRR with the measured value of parts. I have
carried out some research into the interpretation of GRR and all I can find
is the same old biblical guidelines as below:
% GRR under 10% of TV: Measurement system is acceptable
% GRR from 10% to 30% of TV: Measurement system may be acceptable based on
the application
% GRR over 30% of TV: Measurement system needs improvement
Please share your thoughts.
:thanks:
NY
jerry_Malaysia
Re: Correlation of GRR Value with the Measured Value of Parts
Hi
for example:
the application
:thanks:
NY
could you let me know how you get the gauge uncertainty to be 0.1 mm based on GRR value?
N
nicholas_yeoh
Hi jerry_Malaysia
That was just an example and has not been formulated using the proper GRR method.
Ignoring the example as posted previously, I have attached an excel document showing the actual 50 sample measurement data taken on one tab and a GRR spreadsheet on the next tab. I am trying to establish how I can relate my GRR results with the 50 sample measurement data.
1.) Is it correct for me to assume the R&R value of 0.00082 as the gauge uncertainty?
2.) If this is so, is it correct for me to apply a plus/minus R&R value of 0.00082 to the 50 sample measurement data in order to provide me with a true value of measurement?
Thanks, NY
no that would not be correct. The 50 units you measured already have measurement error incorporated into them. And at 50 units the probability that the true value of any of the parts being substantially greater or less than the 50 part min/max is miniscule...remember that standard deviations form different sources (measurement error and true part variation) do not combine linearly (you cannot perform straight forward addition on them).
When I get some time I will look at your data in more detail...unless of course Miner beats me to it! : )
By the way remember that the value 0.00082 is a single standard deviation of the measurement error.
I attached two files that will provide two different perspectives.
Open the MSA 3rd Ed. file and review the Gage Performance Curve tab. This illustrates the distribution of measurement variation, part variation and total (part + measurement) variation. In addition, it shows the probability of accepting a part depending on its true value. You can use this to establish guard band tolerances if desired. This file is based on AIAG methods.
Open the Wheeler file and review the Tolerance Analysis box of the report. This is based on Donald Wheeler's approach and shows various guard band levels. The PE value (+/- .000582) is the effective resolution of a single measurement. Follow the hyperlinks to read more on his approach.
:caution: BevD is correct. You are basing some key decisions on the standard deviation of 10 parts.
The confidence interval for SD=.00082, n=10 is:
90% CI of the SD 0.0005981 to 0.0013491
95% CI of the SD 0.0005640 to 0.0014970
99% CI of the SD 0.0005065 to 0.0018676
From GraphPad QuickCalcs
Richard Pike
Hi
for example:
the application
:thanks:
NY
If you could share your historical Process SD and Process Tolerance I would be pleased to give you a (non-biblical) alternative view point. PS I already have your R&R Data etc.
N
nicholas_yeoh
I have attached a calculation spreadsheet that determines the process SD based on 20 subgroups (5 samples per subgroup). The process SD (or known as sigma in the spreadsheet) is 0.00305 and is calculated using Hartley's constant.
I am a bit puzzled with the term 'process tolerance'. I would assume the process tolerance is 0.02 mm (as the USL = 6.91 and LSL = 6.89).
I appreciate the above advice.
One question: My gauge is calibrated externally and upon calibration, a certificate is issued. If the certificate of calibration states that the gauge uncertainty is (say 'x'), how do I incorporate the gauge uncertainty into my 50 sample measurement data and also how does this have an effect to the GRR study?
:thanx:
D Gage Correlation - I need more information General Measurement Device and Calibration Topics 5
Ron Rompen Surface Finish Correlation between Ra, Rz and Tp (bearing surface ratio) General Measurement Device and Calibration Topics 3
R Preliminary MSA and Sockets' correlation Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 0
S Significance of regression, correlation coefficient, hypothesesi, confidence interval Using Minitab Software 8
triathlonx13 Leak test correlation - Bubble to Air Reliability Analysis - Predictions, Testing and Standards 8
Ron Rompen Best Practices in CMM Correlation Studies General Measurement Device and Calibration Topics 3
L Coefficient of correlation (r) and b1 Statistical Analysis Tools, Techniques and SPC 1
Ajit Basrur MS Excel to study Correlation between Humidity & Differential Pressure Excel .xls Spreadsheet Templates and Tools 7
T Automated and Manual Measurement System Comparison (Correlation) Quality Tools, Improvement and Analysis 3
Q Correlation between ASTM & China's GB (Guobiao) / YY Standards China Medical Device Regulations 4
L ISO 9001:2015 Correlation Matrix & Change Summary ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 3
M How to find the number of required data - Correlation with 4 variables Using Minitab Software 2
M Correlation matrix of ISO 13485 and other country regulations Other ISO and International Standards and European Regulations 3
Q Correlation Matrix of ISO 9001:2008 and ISO 9001: Wanted ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 2
M Is correlation matrix required for Customer Specific Requirements in Quality Manual? IATF 16949 - Automotive Quality Systems Standard 3
R Compression Spring Force measurement correlation with Supplier Capability, Accuracy and Stability - Processes, Machines, etc. 7
N Correlation vs. Causation - Why Correlation does not imply Causation Example Philosophy, Gurus, Innovation and Evolution 7
J Correlation between OEE and FMEA FMEA and Control Plans 2
W Zero setting of correlation graph when plotting best fit linear regression Statistical Analysis Tools, Techniques and SPC 7
A Statistical Correlation between ordered SKUs Statistical Analysis Tools, Techniques and SPC 8
C Test Correlation - Moving Test Equipment to a New Location Manufacturing and Related Processes 7
J Correlation matrix between HSA TS-01 and 21CFR820 or ISO13485 Other Medical Device Regulations World-Wide 1
P How to do Nonlinear Regression and generate a Correlation Statistical Analysis Tools, Techniques and SPC 14
B Correlation Coefficient and Industry Standards - Corrrelation between two of my CMMs Using Minitab Software 2
Q Correlation Matrix and Value Stream Mapping? Quality Assurance and Compliance Software Tools and Solutions 1
V Identifying Significant Factors - Regression Analysis vs Correlation vs ANOVA vs DOE Quality Tools, Improvement and Analysis 7
S The relationship (correlation) of 5 Core Tools with TS 16949 IATF 16949 - Automotive Quality Systems Standard 9
C What is difference between a t-test and Correlation Coefficient Statistical Analysis Tools, Techniques and SPC 2
optomist1 Correlation and Causation - Causation seems to be Ambiguous and Slippery Quality Tools, Improvement and Analysis 7
M Correlation between 2 Variables - Potential X's that might affect yield percentage Quality Tools, Improvement and Analysis 5
S Correlation Study between a new Measurement Device and an existing Device Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 18
M Correlation Production Time Study on a Process on an Assembly Line Manufacturing and Related Processes 3
O Correlation of 2 Test Devices - 2 samples (13 parameters) Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6
K Definition Correlation - The meaning of correlation and and its application in data analysis Definitions, Acronyms, Abbreviations and Interpretations Listed Alphabetically 4
Q ISO 13485, FDA's QSR, CMDR, MDD: Seeking Internal Audit Correlation Matrix Various Other Specifications, Standards, and related Requirements 3
D Improving coefficient correlation result Statistical Analysis Tools, Techniques and SPC 1
H Use SPC to Calculate Correlation Device Tolerance - Hybrid Electronic Components Capability, Accuracy and Stability - Processes, Machines, etc. 3
P Is there a correlation between Teen Violence & Video Games? Coffee Break and Water Cooler Discussions 28
D Two Gauges (Gages) - Two measurements correlation I do not know how to explain Reliability Analysis - Predictions, Testing and Standards 4
S Correlation or Mann Whitney test results? Which to use Statistical Analysis Tools, Techniques and SPC 1
V Correlation and determining the % the contribution Six Sigma 3
S When to use Intraclass Correlation Coefficient vs. Coefficient of Variance Statistical Analysis Tools, Techniques and SPC 21
R Checking Correlation Between Two Similar Gages Measuring the Same Parts Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 14
J Correlation using t-test and correlation coefficient - What is the correct result? Statistical Analysis Tools, Techniques and SPC 43
A Inter laboratory correlation - Two laboratories with different methods? General Measurement Device and Calibration Topics 4
SteelMaiden Competency evaluation records - Direct correlation to EMS-related topics Miscellaneous Environmental Standards and EMS Related Discussions 7
A Correlation or Hypothesis Test? Which is approprite to use on what kind of problem? Statistical Analysis Tools, Techniques and SPC 6
D Correlation of two tests that are NOT linearly correlated? Statistical Analysis Tools, Techniques and SPC 11
H Process correlation matrix - Just how far "into the weeds" do I go? ISO 13485:2016 - Medical Device Quality Management Systems 4
