COTS Items CoC for FAI Documentation
NDesouza
Hello All,.
Does anyone know how a supplier could provide CoCs for COTS items when a sub tier vender refuses or cannot provide one? I have a case where my supplier was issued a SCAR for not providing a CoC for a COTS item after being directed by the customer that we did not need to provide a CoC for a COTS item as long as a packing slip was provided.
I am new to this supplier but I am aware that there is variation in the customer's requirements on COTS items. It kind of depends on who is receiving the material and the FAI documentation as to whether they will write a QN or a SCAR. This is pretty troublesome. Instead of relying on the current punitive system, I think it is best to come of with a CYOA process that is effective and prevents any further confusion on this issue.
1. Couldn't we provide our own internal CoC for the COTS item?
or
2. Could we provide a template for our sub tier venders to write in the information they do have on the item and say why they could not provide a CoC?
kind of grasping at straws here :blowup:
thanks for any help or ideas you can provide.
yodon
I'm not in aerospace so maybe this isn't applicable. What aspect of conformance are you needing? Raw materials, production process? Obviously, you couldn't attest to those aspects.
Who issued the SCAR (and where does the requirement for the CoC come from)?
outdoorsNW
I am not sure I understand the problem. The original post says "I have a case where my supplier was issued a SCAR for not providing a CoC for a COTS item after being directed by the customer that we did not need to provide a CoC for a COTS item as long as a packing slip was provided." The part I bolded in the quote seems to negate any need for a COTS CoC as long as you have a packing slip. Right now it sounds like one person at the supplier is not aware of what someone else at the supplier has said.
NDesouza
The problem is that although the supplier was given the directive that no CoC was needed, they did not get it in writing. Now we have a SCAR. I want to prevent this type of thing from happening again. My thought is that if we institute a plan of action for COTS items, we won't run into this again.
Ninja
Looking for Reality
In my experience (mainly auto, a little aero...NOT AS9100)...
COTS and CoC/CoA rarely go hand in hand. COTS negates the availability of CoC in most cases I've seen.
That said, consider all aspects of making your own CoC, including assumption of liability.
I buy from Home Depot, the part is defective, the CoC was made by me...I'm on the hook, not Home Depot.
Same situation, with no CoC...I still have the Home Depot's fault open to me...though I'm still on the hook with them for using it.
Making your own CoC fills the gap generating SCARs...but can have other baggage attached. Look all the way around it.
Another aspect: If the supplier was told "don't send CoC", and they don't have it in writing...how do you know they were actually told that?
"Some guy named Paul told me not to bother back in 1991" doesn't fly very far.
If it isn't in writing, it doesn't exist.
Verify whether or not needed, put/get it in writing both for you and the supplier...then the pain stops.
HTH
NDesouza
HTH
Thanks very much :)
Tagin
I would think that you need to have some plan to provide written direction to suppliers for all your requirements. Somehow, you are informing them to provide CoCs. Can't you use the same mechanism to inform them:
  • If component is COTS, provide CoC or a packing slip at minimum
  • Otherwise, provide CoC and packing slip
Can this be placed on each PO? On supplier agreement? Etc.?
Ninja
Looking for Reality
@Tagin 's idea is the right direction.... but consider also the liklihood that the supplier will comply.
From the description above, it seems like they could send a CoC, but were told not to bother...tell them otherwise.
Most (all for me) COTS suppliers will just say "No" in my experience and you'd have to find another way.
John Predmore
The traditional CoC states words to the effect that the supplier "certifies" that the furnished material meets all customer specifications. With a commercial-off-the-shelf item, the immediate supplier may be a distributor, not the manufacturer. I can understand reluctance to certify a statement with no first-hand knowledge or evidence of customer requirements or test results.
I do know the aerospace industry is rightfully concerned about the huge risk of counterfeit parts in the supply chain. Maybe the analogy of a packing slip suggests an acceptable compromise which would work in your situation.
Would it be acceptable to the customer for the distributor of a COTS part to offer a "certificate of conformity" stating only that the furnished part was
- procured from a known reputable source,
- the part number provided is an exact match for the p/n on the purchase order, and
- to the supplier's knowledge, the part provided is of virgin quality (no salvaged or re-manufactured parts).
I think those 3 items are assertions that the distributor could realistically attest to and might serve as an acceptable document to the customer.
Johnnymo62
Haste Makes Waste
I have recent experience providing a defense customer with assemblies using COTS hardware.
My customer required the COC to list all of the requirements from the drawing to be listed on the COC, whether it is from the sub-supplier or my company. The distributors could not get anything near adequate, mainly because most of the hardware originated in foreign countries.
This required my company to pay for all of the testing listed on the hardware drawings and specs.
Fortunately, I PPAPed every thing before my customer changed their drawing and listed all of the properties for Loctite.
J Are items with a NSN considered COTS Items? Manufacturing and Related Processes 2
S Not accepting Flowdowns for COTS Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 3
A Commerical off the shelf items (COTS) in DFMEA's (Design FMEAs) FMEA and Control Plans 5
R COTS & DFARS 252.225-7009 Manufacturing and Related Processes 4
P Qualifying commercial off the shelf (COTS) external suppliers ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
S Validation of COTS Equipment plus Software Qualification and Validation (including 21 CFR Part 11) 12
Q Buy American Act - COTS confusion Manufacturing and Related Processes 7
M Conformal Coating & AS9102 - Is conformal coating material a COTS part AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 8
B AS9102 COTS Form 1 vs. 2 AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 5
E AS9102 FAI - What makes a COTS modified? (PCB assemblies) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 11
R Control of COTS (Commercial Off The Shelf) Specifications ISO 13485:2016 - Medical Device Quality Management Systems 2
C Risk Analysis for COTS/OTS Risk Management Principles and Generic Guidelines 4
S COTS (commercial off-the-shelf) Validation FDA Requirements Software Quality Assurance 4
R Re-validating revised Medical Device and Aerospace Product COTS software ISO 13485:2016 - Medical Device Quality Management Systems 2
K COTS Validation: Should we validate Windows after each Update? IEC 62304 - Medical Device Software Life Cycle Processes 3
K Method to qualify COTS Suppliers into AVL (Approved Vendor List) AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
R Only Commissioning Software? COTS, GAMP Category 3 Software Validation Requirements IEC 62304 - Medical Device Software Life Cycle Processes 7
Al Rosen AS9102 for Electronic Circuit Card Assembly that contains COTS Components AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 6
L COTS (Commercial Off-The-Shelf) Parts with AS9102 FAI? AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 16
N COTS (commercial off-the-shelf) Computers - Warranty return rate? Benchmarking 3
V Approach towards defining/documenting Requirements COTS vs. New-Product Software Quality Assurance 1
A Packaging Commercial off-the-shelf (COTS) Products as a Single System Design and Development of Products and Processes 2
A Process for receiving functions - COTS (commercial off the shelf) vs Custom parts. Document Control Systems, Procedures, Forms and Templates 6
M Customer PPm (CPPM) on Pass-Thru Items Statistical Analysis Tools, Techniques and SPC 0
R Using Scrapped NC items for training Medical Device and FDA Regulations and Standards News 15
S Drawing Requirements for Catalog Items (Class II Medical Device) US Food and Drug Administration (FDA) 3
G Common items : which iso 9001 are common to all areas? ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 10
C Items used for Design Verification Design and Development of Products and Processes 7
John C. Abnet Terms- Different Items in a system ISO 26262 - Road vehicles – Functional safety 0
A ISO 13485 procedure change and reflect to legacy manufacture items ISO 13485:2016 - Medical Device Quality Management Systems 2
K IEC 62304 - Functional and performance requirements for SOUP items IEC 62304 - Medical Device Software Life Cycle Processes 2
K Verify Software Architecture - supporting interfaces between items IEC 62304 - Medical Device Software Life Cycle Processes 2
C Contract Review with Multiple Line items ISO 13485:2016 - Medical Device Quality Management Systems 7
G ISO 17025-2017 Management Review reporting items - Inputs ISO 17025 related Discussions 14
nadhar2 Classification of Action Items Misc. Quality Assurance and Business Systems Related Topics 3
DuncanGibbons Best practice for identifying "items" of parts for DFMEA analysis AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
F IEC 62304 - Segregation and communication between software items IEC 62304 - Medical Device Software Life Cycle Processes 1
M IEC 62304 - Develop an Architecture for the Interfaces of Software Items IEC 62304 - Medical Device Software Life Cycle Processes 8
C AS9100 8.3.5.e Design and Development Outputs - Key Characteristics / Critical Items AS9100, IAQG, NADCAP and Aerospace related Standards and Requirements 2
D Supplier Scorecard, Assessment of Pass Through Items From Sub Tier Suppliers Supplier Quality Assurance and other Supplier Issues 4
C Per IEC 62304, are DHF documents Configuration Items? IEC 62304 - Medical Device Software Life Cycle Processes 8
J APQP Requirements - What is meant by "among other items" IATF 16949 - Automotive Quality Systems Standard 2
N Timing for Closing High FMEA RPN Items FMEA and Control Plans 4
R Polypropylene Packaging for Food items Design and Development of Products and Processes 2
J Software and Methods for Tracking CAPA (Corrective and Preventive Action) items US Food and Drug Administration (FDA) 3
K What technical documents need to be maintained for "manufactured for" items 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 8
D NQA-1 Standard Applied to Services rather than Items for Nuclear Power Various Other Specifications, Standards, and related Requirements 3
