Count NDC from Graphik Sample Range vs R chart
Rio BP Simbolon
I already executed MSA Outside for Collar body with spec 8,3 -8,5 mm, used caliper.
NDC = 11
my question, Can NDC be counted from graph? how can it be?
please your comment about our MSA graph (attached)
Question for Moderator
Why file mini-tab can't be uploaded?
best regards
Rio BPS
Re: Count NDC from Graphik Sampel Range vs R chart
NDC can be calculated from a graph but not the standard Minitab / gage R&R graphs.
you need a youden plot. this is a square plot with a 45 degree line eminating from 0:0.
plot the points as a scatter diagram with the first reading on the X axis and the second reading on the Y axis
you draw a rectangle parrallel to the 45 degree line that just fits around all of the points. using your ruler, you measure the width of the short end of the rectangle (that is perpindicular to the 45 degree line). this is the measurement error range.
you then count how many of these widths can fit in the long portion of the rectangle (parallel to the 45 degree line)
Rio BP Simbolon
Thanks Bev D
"on the X axis and the second reading on the Y axis", what point are X and Y?
Rio BP Simbolon
Thanks for your explanation..
my next question: "on the X axis and the second reading on the Y axis", what point are X and Y?
a scatter diagram plots two values as a single data point. for MSA we take two readings of the same part. the first reading is the x value and the second reading is the y value
Minitab files
.mtw files only contain the raw data. Minitab also uses .mpj files that contain .mtw files, analyses and graphics.
H Microbiology count test failure Other Medical Device Related Standards 1
B Cycle Count Audit Discrepancy Supplier Quality Assurance and other Supplier Issues 1
P ISO Class 8 particle count (annual certification vs monitoring) ISO 13485:2016 - Medical Device Quality Management Systems 4
A AQL - How to count samples with defects for each defect class AQL - Acceptable Quality Level 17
M Viable count Measurement ISO Standard Other Medical Device Related Standards 1
supadrai How does the FDA count violations of, for example, misbranding? (Medical Devices) Other US Medical Device Regulations 1
M How to count the number of employees? Other Medical Device and Orthopedic Related Topics 4
M ISO 14644 Airborne Particle Count Testing Requirements Miscellaneous Environmental Standards and EMS Related Discussions 6
A Difference between Discrimination and Least Count IATF 16949 - Automotive Quality Systems Standard 2
W Legality of selling parts by count - Counting Scales Quality Manager and Management Related Issues 6
C Do Emails count as a Document/Record Document Control Systems, Procedures, Forms and Templates 6
S Head Count for Employees and Contract Workers Misc. Quality Assurance and Business Systems Related Topics 6
C What is an acceptable bioburden level or count when working in cleanroom ISO class7 ISO 13485:2016 - Medical Device Quality Management Systems 1
F Excel I want to use the count I get in another formula Excel .xls Spreadsheet Templates and Tools 13
N Requirements for the Classification of Cleanrooms other than the Particle Count Other ISO and International Standards and European Regulations 5
D Pls hlep me understand the "Total Anaerobic Plate Count" Food Safety - ISO 22000, HACCP (21 CFR 120) 1
T Significance Test for Count Data Statistical Analysis Tools, Techniques and SPC 8
M Setting Solid Dose Drug Fill Count Ranges Pharmaceuticals (21 CFR Part 210, 21 CFR Part 211 and related Regulations) 8
S Do Medical Sterile Drapes count as MOPP? IEC 60601 - Medical Electrical Equipment Safety Standards Series 2
I Bioburden Count Question - Bioburden is above the alert limit >1 CFU/component avg. 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
L GB15980-2003 Bioburden Count Trend on Operator Hands Other ISO and International Standards and European Regulations 1
S Count (Bolts and Nuts) Scale - Class of Calibration Weights Calibration and Metrology Software and Hardware 3
K Preventing Shortage of Product Quantity - Hand Count and Scale Count Manufacturing and Related Processes 13
D 510K Approval Guidelines and Marketing in the US - CD4 Count Reagent 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 1
R While Measuring Filter Face, Why We Count From Dead Area? HEPA Filter Related Manufacturing and Related Processes 3
Y Environmental Monitoring - Setting for Particulate Count ISO 13485:2016 - Medical Device Quality Management Systems 3
L Labeling and Count/Part Reconciliation Manufacturing and Related Processes 8
B Does this count as a 510(k) Medical Device Modification 21 CFR Part 820 - US FDA Quality System Regulations (QSR) 14
M Devices with Measuring Function - Do rulers and calipers count? EU Medical Device Regulations 7
B Minitab Gage R&R using Defect Count per Unit Area Using Minitab Software 1
L Do "Informal" Internal Audits count? Internal Auditing 18
S How to count the number of NCs in an Internal Audit? General Auditing Discussions 18
smryan Count by weight statistical analysis Quality Tools, Improvement and Analysis 24
C Do Newsletter articles count towards recertification? Professional Certifications and Degrees 1
T Does a years worth of prototype manufacturing "count" for TS 16949? IATF 16949 - Automotive Quality Systems Standard 6
A Class 8 100,00 Cleanroom - Airborne Microbial Count ISO 13485:2016 - Medical Device Quality Management Systems 6
Q Latest count of ISO 9001 Registration Certificates world wide ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 22
S The Logic behind Tolerance vs. Least Count 1/10 Ratio General Measurement Device and Calibration Topics 11
N Auditing Inventory Levels - Computer Count vs. Physical Inventory ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 40
B R&R Study in Microbiological Testing - Aerobic Plate Count, Coliform, and Salmonella Food Safety - ISO 22000, HACCP (21 CFR 120) 4
Jim Wynne Vista Deathwatch - Is the new Microsoft OS down for the count? World News 30
Jen Kirley How to count two criteria at once in Excel Excel .xls Spreadsheet Templates and Tools 17
G Count By Weight Scale - Calibration within specification, but not linear General Measurement Device and Calibration Topics 8
Manix MTTF Prediction for Customer Requirements - Parts-count MTTF prediction for the part Reliability Analysis - Predictions, Testing and Standards 2
V Minitab Pareto - Trying to plot a relation of Count and Cycle Time Using Minitab Software 5
J Cumulative Count of Conforming Control Chart (CCC) - Calculating UCL and LCL Statistical Analysis Tools, Techniques and SPC 8
S Attribute GRR - Cross tab - Kappa - What does "Expected Count" mean? Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 3
M Can multiple procedures count as one? Different aspects of document control system Document Control Systems, Procedures, Forms and Templates 6
T 3rd party audit time - Does working lunch count as audit time? General Auditing Discussions 66
Wes Bucey At the end of the day, only votes count! World News 5
