Cp and Cpk Chart Fundamentals
jpal20002001
Hello All,
I am in the final stages of developing an application that gathers inspection data, plots them in a chart, monitors my data for me, and is also capable of printing out a summary form as needed.
To Simplify matters, I will tell you what I know, where I'm at and how you can help me.
What I know:
MAX, MIN, MEAN, Range, Standard Deviations & Critical Limits
... are used to help me calculate my Cp, Cpu, Cpl, & Cpk
Where I'm at:
[DATA]
I have data, and I'm able to calculate the easy stuff, :D Max, Min, Mean, Range, Standard Deviations.
My Nominal & Critical limits (UCL, LCL) are given.
[CHART]
I can automatically produce a chart that plots the actual dimensions, with my Critical Limits and nominal shown. a sample is shown as an attachment named, "myBasicChart.png"
How you can help me:
I need help understanding how to take my data, and calculate my CPK, Cpu, Cpl, Cp. Once calculated, I need to fundamentally understand how to create a chart of my CPK. I have uploaded an excel form to help me to comprehend how this is all handled. In that spreadsheet, they have a Cpk sheet. and they also have data for the "Chart Setup." If you can first help me to understand the "Chart Setup" that would be a great leap in the right direction for me. The reason being, is that if i can graph something either in excel or manually, then i can create it programatically. :agree1: And that's what I'm after! Understanding the fundamentals.
[SpreadSheet]
From B37 to B237 they have a list that incrementally increases by 0.1.
For what reason?
From C37 to C237
It looks like there calculating the green box(range) for the Cpk. Does it really work out that way for every Cpk, by using the formula method they used. Very interesting... :popcorn:
Can you explain to me what's happening between D37 to D237? What calculation is that? Where are all of these formulas coming from???
Between E37 & E237, these define what the green box is doing along the y-axis. How am i supposed to know when the box jumps up as theres did?
Between E37 & E86 there y-didn't change, and then all of a sudden on E87, the chart box starts being created by rising on its y-value. How did they know to start at that point???
Re: CP, CPK Charts - Fundamentals
before we get too detailed in our many responses, may I ask why you are trying to 'program' this basic statistical and charting function?
The reason I ask is that there is a lot of very good software out there that does this work for us. It does it well, it does it quickly and it does it cheaply.
jpal20002001
I know this won't make sense to you, because it didn't to me, but here I go.
1st. We will have some software in place that will perform spc functions, but it will not be directly available in my inspection department.
2nd. By custom building this software to the company, I will be able to better provide the specific needs that this company will be requiring as we go into manufacturing high volumes of parts. Yes, there are software's out there that can do all the spc i want them to do, but when it comes down to specific tasks and the continued changes that the company undergoes as it grows, I cannot hope on another software company to make any changes I would inquire, nor is this company willing to pay all the fees associated with the demands it's asking for.
In reality, what i am doing, is providing a secondary channel of catching any potential problems that can be avoided. I will be tailoring this software to the company, as I have already done to it's sister company, which turned out extremely successful.
For the record, I did try selling the company on purchasing software,:argue: and just going that route, but there not willing to do that... at least not now. They just don't want to spend $$$ on software. Why??? I don't know. I know it doesn't make sense, because there spending money on me? :frust:
Anyhow, this will make my job a lot easier. Since I am programmer, I can develop this application to do exactly what i need it to do and also monitor and send alert notifications upon any problems that it found.
In addition to, once i get this Cpk in tact, i will be merging it with other related Cpk results to monitor parts, without user interaction.
So please help me.
Darius
I recommend:
Site's Excel posts
There is a lot of code there :D
From B37 to B237 they have a list that incrementally increases by 0.1. For what reason?
If you want to chart a function, you need to add values to it, the closser the values are, the better continuity of the data points will appear.
From C37 to C237
Because it just obtain the minimum and maximum, max-min = range
min+ range* ( from 0.5 ranges bellow to specs to 0.5 ranges above), that is strange, and sometimes will not work (if the data is far away from specs, looks a waky condition but it could happen), it could be better to use the minimum (from the data points or specs) minus a delta and add a differential until maximum (from the data points or specs) plus a delta:popcorn:
its the normal distribution function, you will find some approximations checking on this site, googling I found (not the best but the "standard" wikipedia)
Normal Distribution on Wikipedia
Easy, all the table is about moving arround the specs (+/- 0.5), when it is a the lower spec position (aka lower spec minus 0 {column B}), jump up, and when it reached the upper (aka lower spec plus (upper - lower)*1 {column B}), jump down.
:topic:note: I don't know how you obtained the variation estimate, if the calculation is to obtain Cp/Cpk you need not to use stdev but the calculation according to the sample size (the size does matter!)
jpal20002001
Makes sense!
Now, I have a question about the formula for Sigma Estimator. I have attached an image for clarification. You will probably need to look at it, for my question to make sense.
In regards for a subgroup size between 1 to 4, what are the referring to as the sample size???
So let's say I inspected 20 parts, then another 20 then another 20.
So now i have 3 groups, and each group contains 20 parts. Is that my d2? 20???
Darius
The sample size is how many groups are made, the Subgroup size is being redundant = "Subgroup size", the SPC constants are assigned acoording to the subgroup size, so if the subgroup size is 20, then the constant is the constant for 20, is strange a subgroup size so huge:mg:, the most common subgroup size is 1 (moving range), 3 or 5, but the subgroup size MUST be assigned rationally (there must be a reason, not just because many uses 5), so you must seek about "rational subgroups" on SPC.
Remember that you chart the subgroups, so..., what do you think when you see a chart with just 3 points?:lmao:, many experts recommend to calculate control limits (and of course the indicators) with at least 20 subgroups (magically, 5*20=100 data points) in order to achive some stability with the statistics (the tables to determine normality are until 70 as I remember), :truce:there is no harm calculating it with less, but aiming to deal with more data points..., call it "early estimates".
by the way.. d2(20) = 3.735, but if you are using a subgroup size that big must use c4
if you want to calculate c4
c4 Excel calculation
jpal20002001
Thanks for clearing up my terminology. :thanx: I didn't know that sample size and Subgroup Size were used interchangeably.
You also mentioned the having enough data to determine normality. By 70, I a supposing you were referring to 70 groups.
ie;
group1: 20 parts
group2: 20 parts
group3: 20 parts
group70: 20 parts <<< At this point, normality can be determined.
:agree:
Also, thank you for the code submission that you shared on the other link. I will study the code and will definitely be using it.
Do you have code or explanation for d2
Darius
ie;
group1: 20 parts
group2: 20 parts
group3: 20 parts
Nop :nope:, the 70 is for individuals (for other kind of tests but I try to show that 70 measurements is a "nice" sample, IMHO if you subgroup the measurements or leave them as individuals, the statistical are robust as the number of measures taken), as it is stated in other posts, the SPC control limits (and their variation estimate) don't depend on "normality", but the chebyshev theorem (and work even if the distribution show "non-normality" <not talking about control rules>), but if you are using the mean (even in the indicators), you are asuming "normality".
:2cents:Are you sure 20 is a rational sample??, to be able to do it, doesn't mean you need to do it.
jpal20002001
I saw your other posting for the actual formulas
"Formulas for Factors d2 and d3 for range charts"
I really wanted you to know that, so that you know I am reading as much of the other threads as i can find.
I Best way to Chart an On-Going CPK Requirement Capability, Accuracy and Stability - Processes, Machines, etc. 4
C How to Calculate and Generate a Cpk Chart Statistical Analysis Tools, Techniques and SPC 4
P Individual & MR chart - Ppk or Cpk? Capability, Accuracy and Stability - Processes, Machines, etc. 9
C Control Chart out of control? Cpk - Process Out of Control Statistical Analysis Tools, Techniques and SPC 26
M Small Lot, Large Part Run Chart - Expressing Cp / Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 1
D What Tool(s) to Use to Create a Cpk Chart from Data Capability, Accuracy and Stability - Processes, Machines, etc. 2
H How can I calculate Cp & Cpk and make a control chart for maintenance activities? Capability, Accuracy and Stability - Processes, Machines, etc. 3
F Cpk 1.99 But Out of Specification Measurement Detected in Control Chart Reliability Analysis - Predictions, Testing and Standards 36
K What should be the best control chart? Cpk study for assembly length Capability, Accuracy and Stability - Processes, Machines, etc. 2
S Control Chart CpK dilemma - Defect Per Unit data on a single production line Capability, Accuracy and Stability - Processes, Machines, etc. 16
R Cp, Cpk calculation for np chart - No USL or LSL - SMT Production Capability, Accuracy and Stability - Processes, Machines, etc. 16
A Cpk for Individual Chart Capability, Accuracy and Stability - Processes, Machines, etc. 1
D Tolerance definition based on expected Cp/cpk Reliability Analysis - Predictions, Testing and Standards 13
K Analysis variation among the lots during cpk calculation. Design and Development of Products and Processes 1
S Recommendation for user friendly Gaga R&R and Cpk software Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 10
A How to set up Continuous CpK monitoring of an injection mold process Reliability Analysis - Predictions, Testing and Standards 7
A Interpretation with regards to Ppk > Cpk Capability, Accuracy and Stability - Processes, Machines, etc. 14
U Cpk Calculation - I analyse a double seam cans Manufacturing and Related Processes 15
Proud Liberal Cp / Cpk on position using multiple MMC bonuses Capability, Accuracy and Stability - Processes, Machines, etc. 2
I Can we use pin gauges to measure an accurate Cpk ? Capability, Accuracy and Stability - Processes, Machines, etc. 9
T Final process capability results - What I am supposed to present? Cp and CpK? APQP and PPAP 11
F CpK on a manufactured assembly? Reliability Analysis - Predictions, Testing and Standards 7
M How is the Cmk and Cpk calculated? Statistical Analysis Tools, Techniques and SPC 0
O Cpk for Unilateral Tolerance Capability, Accuracy and Stability - Processes, Machines, etc. 7
B How to calculate CPK with n = 1 Manufacturing and Related Processes 2
O CPK with a P value less than 0.005 Manufacturing and Related Processes 8
A Cpk Formula seems off, need help!? Capability, Accuracy and Stability - Processes, Machines, etc. 11
D Cp/Cpk on Gages for MSA (vs. Cg/Cgk) Capability, Accuracy and Stability - Processes, Machines, etc. 21
E Questions regarding Cpk Calculation - Should we be using LSL/USL or LCL/UCL? Capability, Accuracy and Stability - Processes, Machines, etc. 5
B Maximum Material Condition with Bonus - Determine Cpk for this one kpc Measurement Uncertainty (MU) 2
T Calculating LCL, UCL, Cp, and Cpk in an Excel Spreadsheet Statistical Analysis Tools, Techniques and SPC 3
Proud Liberal Cpk on Position w/ MMC on Location and Size Capability, Accuracy and Stability - Processes, Machines, etc. 3
S Track Cpk trend Statistical Analysis Tools, Techniques and SPC 5
M Cp & Cpk about a diameter measured with min.,max. and average values. Capability, Accuracy and Stability - Processes, Machines, etc. 13
P Non-normal Data Cpk Statistical Analysis Tools, Techniques and SPC 5
alonFAI Cpk for Solder Paste Height Statistical Analysis Tools, Techniques and SPC 5
I As a part of validation, should i include the acceptance criteria of CPk index >1.33? Qualification and Validation (including 21 CFR Part 11) 4
T Cpk for 0 as Ideal Value Statistical Analysis Tools, Techniques and SPC 1
P Profile Tolerance and CPK Manufacturing and Related Processes 3
V When to use Cp Cpk and Pp Ppk Capability, Accuracy and Stability - Processes, Machines, etc. 4
M Calculating Cpk when sample size equals to 1 Capability, Accuracy and Stability - Processes, Machines, etc. 12
S CpK in Minitab when 0.0 is the lower spec limit Statistical Analysis Tools, Techniques and SPC 7
U Cpk for Contaminant Mass - Washing Parts Capability, Accuracy and Stability - Processes, Machines, etc. 6
G Help with Cpk procedure Capability, Accuracy and Stability - Processes, Machines, etc. 3
J Calculation of σ within subgroups for Cpk in Minitab Using Minitab Software 1
Sean Kelley Value of Ppk or Cpk when targeting thinner material Statistical Analysis Tools, Techniques and SPC 4
B How to validate Microsoft Excel Spreadsheet Calculations for the Cpk value Capability, Accuracy and Stability - Processes, Machines, etc. 9
